How to Upgrade X410-X440 MCU Firmware
Revision as of 11:39, 16 July 2024 by MichaelDickens (Talk | contribs) (→‎Abstract)
AN-111 by Michael Dickens (draft of 2024-07-15)
This document details how to download, extract, and install the X410/X440 USRP microcontroller ("MCU") firmware updates. This specific guide shows how to do the update to MCU firmware version 0.0.13823-82c52e33a for any revision X410/X440 USRP (currently 5, 6, or 7).
The actual Procedure can be done from a Linux host computer/server or on the USRP itself assuming the X410/X440 USRP boots and can stay active and running for a minimum of 20 minutes. Both are covered here; select the one that matches your current X410/X440 USRP situation.
Procedure from Linux Host
  1. Make sure openocd is installed on the Linux host computer/server. The following command works for Ubuntu / aptitude-based: sudo apt-get -y install openocd.
  2. Make sure the USRP and host computer are connected via the USB cable as noted in (b) above.
  3. Use screen to access the MCU on serial port 2:
    sudo screen /dev/serial/by-id/usb-Digilent_Digilent_USB_Device_XXXX-if02-port0 115200
    NOTE: XXXX will be some unique string for this specific serial device and Linux configuration, for example 25163520B2FE. If you copy/paste the first part of the command, up to usb- and then press the <tab> key once or twice then all the options will be listed; use the entry for if02 and then finish off the command as noted with 115200.
  4. Press the <return> key and the prompt > should appear; assuming it does then enter the command:
    eepromdump mb
    NOTE: The first few lines of output will look something like the following
    For an X410 USRP:
    cache hit mb
    usrp_eeprom_board_info (0x10) pid: 0x0410, rev: 0x0005, compat_rev: 0x0005, serial: 320B2FE
    usrp_eeprom_module_info (0x11) pid: 0xa410, rev: 0x0003, serial: 32190B4
    For an X440 USRP:
    cache hit mb
    usrp_eeprom_board_info (0x10) pid: 0x0440, rev: 0x0006, compat_rev: 0x0006, serial: 3284FCB
    usrp_eeprom_module_info (0x11) pid: 0xa440, rev: 0x0004, serial: 32896F8
  5. Note the compat_rev part of usrp_eeprom_board_info, in this case for the X410 USRP 5 and for the X440 USRP 6; this value can currently be 5, 6, or 7 and, in the future, higher numbers.
  6. Detach from screen via pressing the keys ^a (<control> then a) then \, then for the prompt (at the bottom) press the y key, which will come back to the usual shell prompt.
  7. Download and extract the archive to the Linux host computer to the ~/Downloads directory and then go into that directory (watch line wrap on the first command):
    curl -o ~/Downloads/upgrade_mcu_titanium_v0.0.13823-82c52e33a.tar.gz https://files.ettus.com/binaries/misc/upgrade_mcu_titanium_v0.0.13823-82c52e33a.tar.gz
    cd ~/Downloads
    tar zxf upgrade_mcu_titanium_v0.0.13823-82c52e33a.tar.gz
    cd upgrade_mcu_titanium_v0.0.13823-82c52e33a
  8. Run the MCU updater script:
    sudo ./flash-firmware-from-host.sh
    NOTE: This script will print the following:
    This script updates the microcontroller firmware (RO and RW). The change is persistent across power cycles for the RO part. Running this script incorrectly can brick the device. This script may take upto a minute to run successfully.
    Ensure that only one X410/X440 device is connected to the host machine at a time.
    Steps:
    1. Power off the X410/X440 device by running "shutdown -h now" or "poweroff" command from the Linux console. But leave the power connected and turned on.
    2. Connect your X410/X440 device using the USB JTAG port to the host machine using a USB cable.
    3. Ensure that only one X440/X410 device is connected at a time. No other USRP device should be connected.
    4. Run this script.
    5. Do not disconnect USB cable while the script is running as it may result in bricking of the device.
    6. Power cycle the device after script has completed running successfully.
    Updating the microcontroller firmware (RO part) is only required if the Ettus
    Research support told you to do so.
    Press "y" to continue
  9. Press the y key; the script will print:
    Please enter the motherboard compat_rev number:
  10. Enter the # from the compat_rev info from step (5) (in this case 5 for the X410 USRP or 6 for the X440 USRP but use whatever you determined & the printout below will change accordingly), then press the <return> key. The script will now print: The compat_rev 5 is within the supported range.
    Hardare Rev: 5
    Will use firmware file /home/uhd/Desktop/upgrade_mcu_titanium_v0.0.13823-82c52e33a/ec-titanium-rev5.bin
  11. Press the y key; the script will now print out something like the following then terminate as well as try to boot the USRP:
    Flashing ec-titanium-rev5.bin on hardware...
    Open On-Chip Debugger 0.11.0
    Licensed under GNU GPL v2
    For bug reports, read
    http://openocd.org/doc/doxygen/bugs.html
    titanium
    DEPRECATED! use 'adapter driver' not 'interface'
    DEPRECATED! use 'adapter speed' not 'adapter_khz'
    Info : clock speed 2000 kHz
    Info : JTAG tap: stm32f4x.cpu tap/device found: 0x4ba00477 (mfg: 0x23b (ARM Ltd), part: 0xba00, ver: 0x4)
    Info : JTAG tap: stm32f4x.bs tap/device found: 0x06441041 (mfg: 0x020 (STMicroelectronics), part: 0x6441, ver: 0x0)
    Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
    Info : stm32f4x.cpu: external reset detected
    Info : starting gdb server for stm32f4x.cpu on 3121
    Info : Listening on port 3121 for gdb connections
    target halted due to debug-request, current mode: Thread
    xPSR: 0x01000000 pc: 0x080001f8 msp: 0x20000400
    Info : device id = 0x30006441
    Info : flash size = 512 kbytes
    shutdown command invoked
  12. After the USRP shuts down, power it back up. Repeat command (3) then at the > prompt issue the command version>/code>; the output should look like the following for when the <code>compat_rev is 5; the # rev5 will match that from Step (5):
    Chip: stm stm32f412
    Board: 0
    RO: titanium-rev5_v0.0.13823-82c52e
    RW: titanium-rev5_v0.0.13823-82c52e
    Build: titanium-rev5_v0.0.13823-82c52e
    2024-03-04 15:58:54 @c09af2c5ef57
  13. Power on the USRP if it did not automatically do so after Step (12).
  14. Make sure that the USRP is connected to the host computer via a QSFP28 10/100 GbE link and/or the RJ-45 1 GbE link and that the networking is configured for your desired use-case, then run the following and see if the device comes up:
    uhd_find_devices
    NOTE:
    1. If you followed Steps (1) through (12) and if this command successfully finds the USRP then you are done! Congratulations on successfully upgrading the MCU firmware on your X410 or X440 USRP!
    2. If you jumped here without following Steps (1) through (12) because the USRP boots and is capable , or if this command does not succeed in finding the USRP, then proceed to the next Steps.
