B200/B210/B200mini/B205mini/B206mini Getting Started Guides
Revision as of 08:10, 25 August 2025 by AbhishekVerma (Talk | contribs) (AbhishekVerma moved page B200/B210/B200mini/B205mini Getting Started Guides to B200/B210/B200mini/B205mini/B206mini Getting Started Guides: Renamed to include B206mini to the file name)
Kit Contents
  • USRP B200 / B210 / B200mini / B205mini / B206mini
  • USB 3.0 Cable
  • Universal power supply (B210 only)
You Will Need
  • A host computer with an available USB 2.0 or 3.0 port to use the USRP B2xx.
Proper Care and Handling
  • Always properly terminate the transmit port with an antenna or 50 Ohms load.
Getting Started with B206mini Tutorials
To learn how to set up the USRP Hardware Driver (UHD), and use UHD to acquire an RF spectrum using the B206 follow the Getting Started with USRP Products tutorials.
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. The following minimum USRP Hardware Driver, UHD, versions are required:
  • The USRP B2xx other than B206mini require UHD version 3.8.4 or above.
  • The USRP B206mini requires UHD version 4.9 or above.
It is recommended to use the latest stable version of UHD that is available.
Connect the USRP to the Host Computer
The included USB 3.0 cable provides power and data connectivity for the USRP Bus Series. The shipping kits include appropriate USB 3 cables to connect the B200/B210, B200mini, or B205mini to an available USB 3.0 (or 2.0) Type-A port on the host computer. The B206mini shipping kit includes a USB 3.2 Gen 1 Type-C cable, designed for connection to USB 3 Type-C ports on the host computer. It also features a USB Type-C connector with a locking screw, which when used with the optional enclosure and matching threaded insert, provides added strain relief for secure and stable operation.
Note: If a GPSDO module is installed (B200/210 only) or when using USB 2.0, an external DC power supply or a cable designed to pull power from 2 USB ports (USB 2.0 dual A to micro-B or B) must be used.
Note: The cables for the B200-Series USRP have different device side USB connectors. Before attempting to use custom 3rd party USB 3 cables ensure they have the required device side USB connector:
Device Device side USB connector
B200/B210 USB Type B connector
B200mini/B205mini USB Micro B Superspeed connector
B206mini USB Type C connector
Test and Verify the Operation of the USRP
Once the software tools are installed on the host computer, verify the correct operation of the USRP by running the utility programs on the host computer. More information is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
Please contact Technical Support, for any questions or issues with your USRP.
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
