OBX Getting Started Guides
Revision as of 14:25, 2 September 2025 by DylanCaswell (Talk | contribs) (Created page with "==Kit Contents== * OBX Daughterboard * OBX Installation Hardware (Washers, Nuts, Screws, Torx Key) * 2x SMA F to SMPM F Cables * SMPM Insertion/Extraction Tool * Standoff Remo...")
Kit Contents
  • OBX Daughterboard
  • OBX Installation Hardware (Washers, Nuts, Screws, Torx Key)
  • 2x SMA F to SMPM F Cables
  • SMPM Insertion/Extraction Tool
  • Standoff Removal Wrench
  • Safety, Environmental, and Regulatory Information (SERI)
  • OBX QR Code Weblink Insert (Links to this page)
USRP Compatibility
OBX-160
  • X Series only
Hardware Setup
Installation instructions pending
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The UBX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the UBX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
