OBX
Revision as of 15:32, 2 September 2025 by DylanCaswell (Talk | contribs)
The OBX 160 daughterboard is a full-duplex wideband transceiver that covers frequencies from 10 MHz to 8.4 GHz with up to 160 MHz* of instantaneous bandwidth. Coherent and phase-aligned operation across multiple OBX daughterboards enables users to explore MIMO and direction finding applications. The OBX 160 daughterboard works interchangeably with other USRP daughterboards and is compatible with the USRP X300 Series devices.
The OBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications.
  • Frequency Range: 10 MHz - 8.4 GHz
  • Versions: 160MHz
  • RF shielding
  • Full duplex operation with independent TX and RX frequencies
  • Synthesizer synchronization for applications requiring coherent or
Daughterboard Specifications
Features
  • 2 quadrature frontends (1 transmit, 1 receive)
    • Defaults to direct conversion
    • Can be used in low IF mode through lo_offset with uhd::tune_request_t
  • Independent receive and transmit LO's and synthesizers
    • Allows for full-duplex operation on different transmit and receive frequencies
    • Can be set to use Integer-N tuning for better spur performance with uhd::tune_request_t
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
  • Frontend 0: Complex baseband signal for selected antenna
  • Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a UBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
  • Transmit Gains: PGA0, Range: 0-31.5dB
  • Receive Gains: PGA0, Range: 0-31.5dB
Bandwidths
  • OBX-160: 160 MHz, RX & TX
  • Note: The UBX 160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
Sensors
  • lo_locked: boolean for LO lock state
LEDs
  • LOCK: Synthesizer Lock Detect
  • TX/RX TXD: Transmitting on TX/RX antenna port
  • TX/RX RXD: Receiving on TX/RX antenna port
  • RX2 RXD: Receiving on RX2 antenna port
See: SPEC URL
Input/Output Impedance
  • All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
  • The maximum input power for the OBX is -15 dBm.
Hardware Specifications
OBX-160
  • Minimum version of UHD required for OBX: 3.9.0
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
Phase Synchronization
The OBX daughterboard is capable of phase-synchronous operation, and is recommended for phase-coherent applications. The SBX and TwinRX daughterboards are also recommended for phase-coherent applications.
If you are operating the OBX at frequencies below 1 GHz and need phase synchronization, then it is necessary to select a 20 MHz daughterboard clock rate, instead of using the default 50 MHz rate. Note that this is only required for phase synchronization below 1 GHz. The UBX can still operate below 1 GHz without setting this lower daughterboard clock rate, but it will operate without any phase synchronization capability.
If you're using a UHD program, then you can specify the lower daughterboard clock rate on the command line of the program, with --args="dboard_clock_rate=20e6".
If you're using the UHD API from a C++ program, then you can include "dboard_clock_rate=20e6" in the device arguments parameter when first invoking multi_usrp::make().
If you're using GNU Radio, then you can add "dboard_clock_rate=20e6" to the "Device Arguments" field of the properties for the UHD Sink and UHD Source blocks.
OBX
TBD
Key Component Datasheets
MAX2871 Fractional/Integer-N Synthesizer/VCO U3 (3); U9 (5); U19 (7); U23 (9)
ADL5375-05 Quadrature Modulator U22 (8)
LFCN-2250+ Low Pass Filter F1 (3); F24 (7); F34, F35 (10)
LTC5510 Active Mixer U15 (6)
LFCN-490+ Low Pass Filter F12 (5); F15 (6); F26 (7); F31 (9); F33, F36 (10)
HMC624LP4E ATTENUATOR U16 (6)
NBB-400 Amplifier U13 (6); U30 (11)
PHA-1+ Amplifier U31 (11)
ADA4927-2 Differential ADC Driver U6 (4)
ADL5380 Quadrature Demodulator U8 (4)
MGA-62563 Low Noise Amplifier U36 (11)
LFCN-1700+ Low Pass Filter F41 (11)
VMMK-3603 Low Noise Amplifier U34 (11)
LFCN-2600+ Low Pass Filter F14, F17 (6)
855916 SAW Filter F16 (6)
LTC5510 Active Mixer U15 (6); U28 (10)
LFCN-2600+ Low Pass Filter F14, F17 (10)
TCM1-63AX+ RF Transformer T1 (3); T2, T3 (4); T7 (8)
AD8591 Operational Amplifiers U7 (4)
ZXTC2062E6 TRANSISTORS Q1 (6)
HMC624ALP4E ATTENUATOR U16 (6); U29 (10)
LFCN-800+ Low Pass Filter F2 (3); F25 (7)
ADP7104-3.3 CMOS LDO U4, U5 (3); U10, U11 (5); U20, U21 (7); U24, U25 (9); U48 (13)
LTC5510 Active Mixer U28 (10)
24LC024 EEPROM U38, U39 (12)
ADP7104-5.0 CMOS LDO U41, U42, U43, U44, U45, U46, U47 (13)
ZXTC2062E6 TRANSISTORS Q2, Q3, Q4, Q5 (13)
Mechanical Information
Drawings
RF Connectors
  • The UBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
China RoHS
Chinese Customers
Certificate of Volatility
UBX-40/UBX-160
Important Notes
  • A larger 24W (6V, 4A) power supply is required when using a UBX-40 daughterboard and integrated GPS Disciplined Oscillator accessory together in a USRP2, USRP N200, or USRP N210 device.
  • The UBX-160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
