SBX
[hide]Device Overview
- Frequency Range: 400MHz - 4.4GHz
- Versions: 40MHz / 120MHz
- Power Output: 100mW
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Environmental Specifications
- 0-40 °C
SBX
Key Components
Datasheets
Mechanical Info (size, weight, drawings)
Interfaces and Connectivity
