Instructions for System Setup and Configuration
Revision as of 12:20, 24 January 2026 by Ettus (Talk | contribs)
Author
Neel Pandeya
Introduction
This document provides instructions for attendees to setup and configure their laptop or desktop computer system for use with the hands-on exercises and labs for the "USRP Open-Source Toolchain: UHD and GNU Radio" Workshop/Tutorial.
This document assumes that you are using a USRP B200/B210 radio, although the USRP X300/X310, N300, N310, N320, N321, X410 may also be used as well.
In some sessions, the radio will be provided to you, but in other sessions you will need to provide your own radio. Check this with the organizer of your session.
Your laptop or desktop computer should be no more than about seven years old, with an Intel i5, i7, or i9 CPU, or AMD equivalent, running at a 3.5 GHz clock speed or higher, with 8 GB memory, and at least one USB 3.0 port (for USRP B200/B210 radios) and one RJ-45 Ethernet port (for other USRP radios). You will need about 30 GB of free disk space for the Linux installation. You will need to have internet access during the entire installation, set-up, and configuration process.
Also note that all of this is optional. You only have to do this if you want to use the USRP in the workshop to do the hands-on exercises, and actually use the USRP radio. If you do not want to do this, and if you simply want to sit back and watch the instructor's presentation, then you can skip all of this, and just come to the workshop with a cup of coffee.
Step 1: Install Ubuntu 24.04.3 or Xubuntu 24.04.3
Install Ubuntu 24.04.3 or Xubuntu 24.04.3. Please install on-the-metal, not in a Virtual Machine (VM). Please install specifically version 22.04.5. If you already have an existing Windows or Linux installation on your laptop computer, then you can install Ubuntu or Xubuntu alongside your already-existing operating system, in a dual-boot configuration. The Ubuntu or Xubuntu installer will ask you about this, and it supports installing in a dual-boot configuration. I recommend using Xubuntu, because it is a light-weight desktop environment, and it will run faster than Ubuntu, especially on older laptop computers, and also the user interface is somewhat easier to use. You can download the ISO images for Ubuntu and Xubuntu from the links below. Write the ISO image to a USB 3.0 drive, and boot from it, and install Ubuntu or Xubuntu.
https://ubuntu.com/download/desktop
https://xubuntu.org/download/
https://cdimage.ubuntu.com/xubuntu/releases/noble/release/
