Instructions for System Setup and Configuration
Revision as of 16:17, 24 January 2026 by Ettus (Talk | contribs) (Step 13: Apply the USB udev rules)
Author
Neel Pandeya
Introduction
This document provides instructions for attendees to setup and configure their laptop or desktop computer system for use with the hands-on exercises and labs for the "USRP Open-Source Toolchain: UHD and GNU Radio" Workshop/Tutorial.
This document assumes that you are using a USRP B200/B210 radio, although the USRP X300/X310, N300, N310, N320, N321, X410 may also be used as well.
In some sessions, the radio will be provided to you, but in other sessions you will need to provide your own radio. Check this with the organizer of your session.
Your laptop or desktop computer should be no more than about seven years old, with an Intel i5, i7, or i9 CPU, or AMD equivalent, running at a 3.5 GHz clock speed or higher, with 8 GB memory, and at least one USB 3.0 port (for USRP B200/B210 radios) and one RJ-45 Ethernet port (for other USRP radios). You will need about 30 GB of free disk space for the Linux installation. You will need to have internet access during the entire installation, set-up, and configuration process.
Also note that all of this is optional. You only have to do this if you want to use the USRP in the workshop to do the hands-on exercises, and actually use the USRP radio. If you do not want to do this, and if you simply want to sit back and watch the instructor's presentation, then you can skip all of this, and just come to the workshop with a cup of coffee.
Step 1: Install Xubuntu 24.04.3
Install Xubuntu 24.04.3. You may also install Ubuntu itself, or any other Ubuntu flavor, such as Kubuntu, Lubuntu, Cinnamon, MATE, or Linux Mint. We recommend using Xubuntu because it is very light-weight, and the user-interface is easy-to-use and intuitive, and it runs fast on older or resource-constrained hardware.
https://ubuntu.com/desktop/flavors
Please install on-the-metal, not in a Virtual Machine (VM). Please install specifically version 24.04.3.
If you already have an existing Windows or Linux installation on your computer, then you can install Ubuntu or Xubuntu alongside your already-existing operating system, in a dual-boot configuration. The installer will ask you about this, and it supports installing in a dual-boot configuration. However, note that there can be some challenges when dual-booting with Windows 11, and this may not be easy to set up and may not work well.
You can download the ISO images for Xubuntu from the links below. Write the ISO image to a USB 3.0 drive, and boot from it, and install Xubuntu.
https://xubuntu.org/download/
https://cdimage.ubuntu.com/xubuntu/releases/noble/release/
Step 2: Installation Settings
During the Ubuntu/Xubuntu installation process, set the username to be "ettus". This is not strictly necessary, but if you do this, then it will make all the commands in the installation instructions and in the exercises work more easily. The hostname does not matter. Do not use any disk encryption. Do not enable any volume management.
Step 3: Apply Updates
Once the installation is complete, boot into it, and open a terminal window, and apply updates. Run the commands listed below, in a terminal window.
   sudo apt update
   sudo apt upgrade
Step 4: Install Dependencies
Install the package dependencies for UHD, GNU Radio, and other tools. Run the commands listed below, in a terminal window.
   sudo apt install openssh-server htop tree lshw meld git libfftw3-bin ncurses-bin libncurses6 libncursesw6 net-tools ethtool aptitude screen hwloc inxi wireshark wireshark-doc wireshark-dev tshark build-essential ntp doxygen gnome-disk-utility
   sudo apt-get install autoconf automake build-essential ccache cmake cpufrequtils doxygen ethtool g++ git inetutils-tools libboost-all-dev libncurses6 libncurses-dev libusb-1.0-0 libusb-1.0-0-dev libusb-dev python3-dev python3-mako python3-numpy python3-requests python3-scipy python3-setuptools python3-ruamel.yaml
   sudo apt install git cmake g++ libboost-all-dev libgmp-dev swig python3-numpy python3-mako python3-sphinx python3-lxml doxygen libfftw3-dev libsdl1.2-dev libgsl-dev libqwt-qt5-dev libqt5opengl5-dev python3-pyqt5 liblog4cpp5-dev libzmq3-dev python3-yaml python3-click python3-click-plugins python3-zmq python3-scipy python3-gi python3-gi-cairo gir1.2-gtk-3.0 libcodec2-dev libgsm1-dev libusb-1.0-0 libusb-1.0-0-dev libudev-dev python3-setuptools python3-pygccxml python3-thrift libqwt-qt5-6 libqwt-qt5-dev python3-pyqt5.qwt python3-qwt3d-qt5 libspdlog-dev libspdlog1.12 pybind11-dev python3-cppimport python3-pybind11 python3-pybindgen
Step 5: Create a folder for GIT repositories
Create a folder to hold all the GIT repositories. Run the commands listed below, in a terminal window.
   mkdir $HOME/git
Step 6: Create a work area folder
Create a folder to hold workshop materials and for running exercises. Run the commands listed below, in a terminal window.
   mkdir $HOME/workarea
Step 7: Download the slides and materials
Download the slides and materials for the workshop. Run the commands listed below, in a terminal window.
   wget -P $HOME/workarea https://kb.ettus.com/images/a/ab/Workshop_GnuRadio_Materials_20171212.tar.gz
   wget -P $HOME/workarea https://kb.ettus.com/images/f/fd/Workshop_GnuRadio_Slides_20250802.pdf
Step 8: Unzip the materials
Unzip the workshop materials file. Run the commands listed below, in a terminal window.
   cd $HOME/workarea
   tar zxvf Workshop_GnuRadio_Materials_20171212.tar.gz
Step 9: Install UHD 4.9
Install UHD version 4.9, and download all the USRP FPGA image files. Run the commands listed below, in a terminal window.
   cd $HOME/git
   cd uhd/host
   mkdir build
   cd build
   git checkout v4.9.0.0
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
   sudo uhd_images_downloader
Step 10: Install VOLK
Install the VOLK library. This used to be bundled with GNU Radio, but now it's broken out as a separate library. Run the commands listed below, in a terminal window.
   git clone --recursive https://github.com/gnuradio/volk.git
   cd volk
   mkdir build
   cd build
   git checkout v3.2.0
   cmake -DCMAKE_BUILD_TYPE=Release -DPYTHON_EXECUTABLE=/usr/bin/python3 ../
   make -j4
   sudo make install
   sudo ldconfig
Step 11: Install GNU Radio 3.10.12
Install GNU Radio version 3.10.12. Run the commands listed below, in a terminal window.
   cd $HOME/git
   git clone http://github.com/gnuradio/gnuradio.git
   cd gnuradio
   mkdir build
   cd build
   git checkout v3.10.12.0
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
Step 12: Update the Bash shell file
Add the following lines the end of your $HOME/.bashrc file. You can use a graphical text editor such as Gedit or Mousepad.
First, open the file using either the Gedit or Mousepad text editor.
   mousepad $HOME/.bashrc
   gedit $HOME/.bashrc
Next, add the two lines listed below to the very end of the file, and save it.
   export PYTHONPATH=/usr/local/lib/python3.12/dist-packages:/usr/local/lib/python3.12/site-packages:$PYTHONPATH
Then, exit and close the text editor, and exit and close the terminal window, and open a brand-new terminal window.
Apply the USB udev rules for the USRP B200/B210. If you are not using a USRP B200/B210, but some other Ethernet-based radio, then you can skip this step, although it is still good to do. Run the commands listed below, in a terminal window.
   cd /usr/local/lib/uhd/utils
   sudo cp uhd-usrp.rules /etc/udev/rules.d/
   sudo udevadm trigger
Step 14: Install gr-osmosdr
Install the gr-osmosdr Out-Of-Tree (OOT) module. Run the commands listed below, in a terminal window.
   cd $HOME/git
   git clone https://github.com/osmocom/gr-osmosdr
   cd gr-osmosdr
   mkdir build
   cd build
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
Step 15: Install gr-rds
Install the gr-rds Out-Of-Tree (OOT) module. Run the commands listed below, in a terminal window.
   cd $HOME/git
   git clone https://github.com/bastibl/gr-rds
   cd gr-rds
   mkdir build
   cd build
   git checkout maint-3.10
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
Step 16: Install GQRX
Install GQRX. You will also need to install two more package dependencies. Run the commands listed below, in a terminal window.
   sudo apt-get install libqt5svg5 libqt5svg5-dev
   cd $HOME/git
   git clone https://github.com/gqrx-sdr/gqrx
   cd gqrx
   mkdir build
   cd build
   git checkout v2.17.7
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
Step 17: Install gr-paint
Install gr-paint. Run the commands listed below, in a terminal window.
   cd $HOME/git
   git clone https://github.com/drmpeg/gr-paint
   cd gr-paint
   mkdir build
   cd build
   cmake ../
   make -j4
   sudo make install
   sudo ldconfig
Test the Installation
If you did not see any errors in any of the previous steps, then your installation and configuration should now be complete. You can run a few simple and quick tests to verify that your system is running correctly and is ready for the workshop/tutorial.
First, run the commands below, even if you do not have any USRP radio connected to your computer.
   uhd_find_devices
   uhd_usrp_probe
You should see output similar to what is listed below.
   ettus@lenovo-t480s:~$ uhd_find_devices
   [INFO] [UHD] linux; GNU C++ version 13.3.0; Boost_108300; UHD_4.9.0.HEAD-0-g9ec1f582
   No UHD Devices Found
   ettus@lenovo-t480s:~$ uhd_usrp_probe
   Error: LookupError: KeyError: No devices found for ----->
   Empty Device Address
Second, you can run the GNU Radio Companion (GRC) tool. Run the commands below, and verify that the GRC window appears.
   gnuradio-companion
Conclusion
If the simple tests of the installation listed above worked without any errors, then you are now finished, and you are now ready for the workshop/tutorial.
If you have any questions or problems, you can contact the author via email at [email protected]
We look forward to seeing you in the workshop/tutorial.
