N200/N210
- 1 End-of-Life (EOL)
- 2 Device Overview
- 3 Key Features
- 4 Compatible Daughterboards
- 5 RF Specifications
- 6 Hardware Specifications
- 7 Physical Specifications
- 8 Environmental Specifications
- 9 Schematics
- 10 Key Component Datasheets
- 11 FPGA
- 13 Certifications
- 14 Letter of Volatility
- 15 Recovering the N200/N210
- 16 Downloads
End-of-Life (EOL)
Please note that this product is now End-of-Life (EOL) and is no longer available for sale through Ettus Research. It is not recommended for use in new designs or in new projects.
The USRP Network Series offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP Network Series allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP Network an ideal candidate for software defined radio systems with demanding performance requirements.
N200
N210
- SBX-40
- UBX-40
- WBX-40
- CBX-40
- LFRX / LFTX
- BasicRX / BasicTX
- DBSRX2 (EOL)
- RFX Series (EOL)
- TVRX2 (EOL)
RF Performance Data (with WBX)
- Phase Noise 1.8 GHz 10kHz -80 dBc/Hz
- Phase Noise 1.8 GHz 100kHz -100 dBc/Hz
- Phase Noise 1.8 GHz 1MHz -137 dBc/Hz
- Power Output 15 dBm
- IIP3 (@ typ NF) 0 dBm
- Typical Noise Figure 5 dB
N200
- Current Hardware Revision: 4
N210
Dimensions
22 x 16 x 5 cm
Weight
1.2 kg
Drawings
CAD/STP Models
N2xx
N2xx Enclosure
- N200/N210: 25 °C
Operating Humidity Range
- 10% to 90% non-condensing
N200/N210
| AD9777 | Dual Channel, 16-Bit DAC | U3 (1) |
| ADS62P4X | Dual Channel, 14-Bit ADC | U2 (1) |
| XC3SD3400AFG676 | FPGA | U1 (2,8,9,10,11,12) |
| AD9510 | Clock Distribution IC | U9 (4) |
| ET1011C2 | Gigabit Ethernet Transceiver | U12 (6) |
| CY7C1354C | Pipelined SRAM | U19 (7) |
| MAX232 | Drivers/Receiver | U25 (10) |
FPGA
N200
Device utilization summary:
Selected Device : 3sd1800afg676-5
Number of Slices: 18356 out of 16640 110% (*)
Number of Slice Flip Flops: 20466 out of 33280 61%
Number of 4 input LUTs: 32968 out of 33280 99%
Number used as logic: 28511
Number used as Shift registers: 3945
Number used as RAMs: 512
Number of IOs: 338
Number of bonded IOBs: 331 out of 519 63%
IOB Flip Flops: 342
Number of BRAMs: 41 out of 84 48%
Number of GCLKs: 6 out of 24 25%
Number of DCMs: 1 out of 8 12%
Number of DSP48s: 31 out of 84 36%
N210
Selected Device : 3sd3400afg676-5
Number of Slices: 18349 out of 23872 76%
Number of Slice Flip Flops: 20475 out of 47744 42%
Number of 4 input LUTs: 32986 out of 47744 69%
Number used as logic: 28529
Number of IOs: 338
Number of bonded IOBs: 331 out of 469 70%
IOB Flip Flops: 342
Number of BRAMs: 41 out of 126 32%
Number of DSP48s: 31 out of 126 24%
N200/N210
- Gigabit Ethernet
China RoHS
Chinese Customers
Found on the NI Product Certifications lookup tool here.
For a detailed guide to recovering the N200/N210, please see the N200/N210 Device Recovery application note.
