CBX
- 1 Device Overview
- 2 Key Features
- 4 RF Specifications
- 5 RF Performance Data
- 6 Hardware Specifications
- 8 USRP Compatibility
- 9 Phase Synchronization
- 10 Schematics
- 11 Key Component Datasheets
- 12 Drawings
- 13 RF Connectors
- 14 Certifications
- 15 Certificate of Volatility
- 16 Downloads
The CBX is a full-duplex, wideband transceiver that covers a frequency band from 1.2 GHz to 6 GHz with a instantaneous bandwidth of 40 MHz or 120 MHz. The CBX can serve a wide variety of application areas, including WiFi research, cellular base stations, cognitive radio research, and RADAR. The CBX daughterboard is supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
The CBX does not provided phase coherent operation, and therefore is not recommended for MIMO and Phased Array applications.
Features
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
- Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a CBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
- Transmit Gains: PGA0, Range: 0-31.5dB
Bandwidths
- CBX: 40 MHz, RX & TX
- CBX-120: 120 MHz, RX & TX
Sensors
LEDs
- All LEDs flash when daughterboard control is initialized
- TX LD: Transmit Synthesizer Lock Detect
- TX/RX: Receiver on TX/RX antenna port (No TX)
- RX LD: Receive Synthesizer Lock Detect
- RX1/RX2: Receiver on RX2 antenna port
Freq Range
- 1.2GHz - 6GHz
Noise Figure
- 5 - 7.5 dB @ (1.2GHz ~ 5GHz)
- 7.5dB - 10 dB (5GHz ~ 6GHz)
RX IIP3 (Max)
- 8 - 10 dBm
RX IQ Imbalance
- -20 dBc
TX Power (Max)
- 22 dBm @ (1.2GHz ~ 3GHz)
- 12 ~ 22 dBm @ (3GHz ~ 6GHz)
TX OIP3
- 30 - 32 dBm @ (1.2GHz ~ 5GHz)
- 26 ~ 30 dBm @ (5GHz ~ 6GHz)
TX IQ Imbalance
- -20 dBc
Input/Output Impedance
- All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
- The maximum input power for the CBX is -15 dBm.
RF Performance Data
CBX
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
USRP Compatibility
CBX-40
- N or X Series
CBX-120
- X Series only
The CBX daughterboard is not capable of phase-synchronous operation. The SBX, UBX, TwinRX daughterboards are recommended for phase-coherent applications.
Schematics are available for legitimate reasons under NDA; please submit a request via NI Support.
| VMMK-3603 | Low Noise Amplifier | U1, U5 (1) |
| AS225-313LF | SPDT Switch | U3, U6 (1) |
| HMC624LP4E | ATTENUATOR | U7, U2 (1) |
| MGA82563 | Amplifier | U4 (1) |
| GVA-84+ | Amplifier | U9 (1) |
| PHA-1+ | Amplifier | U8 (1) |
| ADL5380ACPZ | Quadrature Demodulator | U11 (2) |
| ADA4927-2YCPZ | Differential ADC Driver | U10 (2) |
| AD8591ARTZ-REEL | Amplifiers | U31 (2) |
| NC7WZ04P6X | Dual Inverter | U26 (3); U15, U16 (4); U21 (5); U27 (6) |
| MAX2870ETJ+ | Fractional/Integer-N Synthesizer | U23 (3); U24 (6) |
| SKY13267-321 | Diversity Switch | U12 (3); U25 (6) |
| LFCN-2000+ | Low Pass Filter | FL13 (3); FL12 (6) |
| LP3878MR-ADJ | Voltage Regulator | U13, U14 (4); U19, U20 (5) |
| 24LC024 | EEPROM | U17 (4); U22 (5) |
| ADL5375-05 | Quadrature Modulator | U18 (5) |
Drawings
RF Connectors
- The CBX daughterboard features female SMA connectors for both the TX/RX and RX2 connectors.
China RoHS
Chinese Customers
