BasicTX/BasicRX
Revision as of 15:17, 25 June 2026 by MichaelDickens (Talk | contribs) (Schematics: per direction from the powers that be)
The BasicRX/BasicTX daughterboards are low-cost daughterboards that provides direct access to the ADC inputs. The boards accept real-mode only signals on both antennas from 1 to 250 MHz. The BasicRX/BasicTX is ideal for applications using an external front end providing relatively clean signals within operable bandwidth. Wideband transformers couple each RF input to a single channel of the USRP device's ADC. The signals sampled by the ADC are manipulated in the FPGA and the outputs can be processed independently resulting in real signals or as a single I/Q pair. The BasicTX/BasicRX daughterboards are supported by the USRP Hardware Driver™ (UHD) software API for seamless integration into existing applications.
  • 1-250 MHz coverage
  • Real or Complex sampling
Daughterboard Specifications
Frontends
BasicRX
The BasicRX has 4 frontends:
  • Frontend A: real signal on antenna RXA
  • Frontend B: real signal on antenna RXB
  • Frontend AB: quadrature frontend using both antennas (IQ)
  • Frontend BA: quadrature frontend using both antennas (QI)
BasicTX
The BasicTX has 4 frontends:
  • Frontend A: real signal on antenna TXA
  • Frontend B: real signal on antenna TXB
Gains
BasicRX
  • The BasicRX has no tunable elements or programmable gains. Through the magic of aliasing, you can down-convert signals greater than the Nyquist rate of the ADC.
BasicTX
  • The BasicTX has no tunable elements or programmable gains. Through the magic of aliasing, you can up-convert signals greater than the Nyquist rate of the DAC.
Bandwidths
BasicRX
  • For Real-Mode (A or B frontend): 250 MHz
  • For Complex (AB or BA frontend): 500 MHz
BasicTX
Input/Output Impedance
  • All RF Ports are matched to 50 Ohm with -10dB or better return loss.
Input Power Levels
  • The maximum input power for the BasicRX is +10 dBm.
Hardware Specifications
BasicRX
  • Minimum version of UHD required: 3.8.0
BasicTX
Environmental Specifications
  • 0-40 °C
Operating Humidity Range
  • 10% to 90% non-condensing
USRP Compatibility
BasicRX
  • N or X Series
BasicTX
  • N or X Series
Schematics are available for legitimate reasons under NDA; please submit a request via NI Support.
Key Component Datasheets
24LC025B EEPROM U1 (1); U52 (1)
ADT1−1WT RF Transformer T1 (1); T2 (1); T50 (1); T51 (1)
Mechanical Information
Drawings
RF Connectors
  • The BasicTX/RX daughterboard features female SMA connectors for both the RX and TX connectors.
China RoHS
Chinese Customers
Certificate of Volatility
BasicRX / BasicTX Letter of Volatility
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
