USRP1
Revision as of 13:46, 26 June 2026 by MichaelDickens (Talk | contribs) (remove unnecessary information)
End-of-Life (EOL)
Please note that this product is now End-of-Life (EOL), and is no longer available for sale through Ettus Research, and is not recommended for use in new designs or in new projects.
- 16 MHz of RF bandwidth with 8 bit samples
- 8 MHz of RF bandwidth with 16 bit samples (RX Only)
- USB 2.0 high speed connectivity
- MIMO with a single USRP device the motherboard has two daughterboard slots (2 RX + 2 TX connectors)
- FPGA: Altera Cyclone
- ADCs: 12-bits 64 MS/s
- DACs: 14-bits 128 MS/s
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The USRP1 is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP1 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
| Never apply more than -15 dBm of power into any RF input. | |
