N200/N210 Getting Started Guides
Revision as of 14:40, 26 June 2026 by MichaelDickens (Talk | contribs)
End-of-Life (EOL)
Please note that this product is now End-of-Life (EOL) and is no longer available for sale through Ettus Research. It is not recommended for use in new designs or in new projects.
Kit Contents
  • USRP N200/N210
  • 1 Gigabit Ethernet Cable
  • Power Supply
  • 2 SMA-Bulkhead Cables
You Will Need
  • A host computer with an available 1-GigE port
Proper Care and Handling
Assembly
The USRP N200/N210 and compatible RF daughterboards are shipped separately. To operate the device you will need to install the RF daughterboards and supplied bulkhead cables. This can be accomplished by removing the top plate of the USRP N200/N210, which is secured with two screws. After installation, the daughterboards and cables should be secured with the hardware provided. The device must be powered off when installing daughterboards to avoid potential damage. For detailed step-by-step instructions on assembling up your USRP N200/N210, see the USRP N Series Quick Start (Daughterboard Installation) page.
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes. Release 3.8.4 or later of the USRP Hardware Driver, UHD, is required. It is recommended to use the latest stable version of UHD that is available.
Test and Verify the Operation of the USRP
Once the software tools are installed on the host computer, or using the Live SDR Environment, verify the correct operation of the USRP by running the utility programs on the host computer. More information is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
