BasicTX/BasicRX Getting Started Guides
Revision as of 15:45, 26 June 2026 by MichaelDickens (Talk | contribs)
Kit Contents
  • BasicRX or BasicTX Daughterboard
  • Screws
USRP Compatibility
BasicRX
  • N or X Series
BasicTX
  • N or X Series
Hardware Setup
For complete step by step instructions to installing a daughterboard, please see the USRP N Series Quick Start (Daughterboard Installation) or USRP X Series Quick Start (Daughterboard Installation) guides.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The BasicTX/BasicRX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the BasicTX/BasicRX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Never apply more than +10 dBm of power into any RF input.
