UBX Getting Started Guides
Revision as of 15:50, 26 June 2026 by MichaelDickens (Talk | contribs)
Kit Contents
- UBX Daughterboard
- Screws
USRP Compatibility
UBX-40
- N or X Series
UBX-160
- X Series only
Hardware Setup
For complete step by step instructions to installing a daughterboard, please see the USRP N Series Quick Start (Daughterboard Installation) or USRP X Series Quick Start (Daughterboard Installation) guides.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The UBX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the UBX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
| Never apply more than -15 dBm of power into any RF input. | |
