OBX Getting Started Guides
Revision as of 16:02, 26 June 2026 by MichaelDickens (Talk | contribs)
Kit Contents
  • OBX-160 Daughterboard
  • OBX-160 Installation Hardware (Washers, Nuts, Screws, Torx Key)
  • 2x SMA F to SMPM F Cables
  • SMPM Insertion/Extraction Tool
  • Standoff Removal Wrench
  • Safety, Environmental, and Regulatory Information (SERI)
USRP Compatibility
OBX-160
  • X Series only
Hardware Setup
OBX-160 Installation Instructional Video
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The UBX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the UBX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
