USRP Host Performance Tuning Tips and Tricks
Revision as of 14:31, 30 August 2026 by MichaelDickens (Talk | contribs) (whitespace)
AN-088
This application note provides various tips and tricks for tuning your host computer for best performance when working with USRP devices.
CPU Governor
NOTE: use of cpufrequtils noted below should be limited to Linux kernel 5. The utility cpupower should be used in Linux kernel 6 and newer.
Ensure your CPU governor is set to performance. This can be done with the Linux utility cpufrequtils.
Install cpufrequtils with the command below:
   sudo apt install cpufrequtils
You can then set the CPU governor to performance per core by issuing the command:
   sudo cpufreq-set -c $core_number -g performance
To set the CPU governor to performance for all cores:
   for ((i=0;i<$(nproc --all);i++)); do sudo cpufreq-set -c $i -r -g performance; done
You can then verify that the CPU governor has been set by running the command:
   cpufreq-info
Thread Priority Scheduling
UHD Warning:
To address this issue, non-privileged (non-root) users need to be given special permission to change the scheduling priority. This can be enabled by creating a group usrp, adding your user to it, and then appending the line @usrp - rtprio 99 to the file /etc/security/limits.conf.
   sudo groupadd usrp
   sudo usermod -aG usrp $USER
Then add the line below to end of the file /etc/security/limits.conf:
   @usrp - rtprio  99
You must log out and log back into the account for the settings to take effect. In most Linux distributions, a list of groups and group members can be found in the /etc/group file.
Adjust Network Buffers
This applies to USRP devices connected via 10 GbE or 100 GbE Ethernet: N2xx, N3xx, X3xx, E320, X4xx
Note that these settings will not persist across a reboot.
   sudo sysctl -w net.core.wmem_max=33554432
   sudo sysctl -w net.core.wmem_default=33554432
   sudo sysctl -w net.core.rmem_default=33554432
To make these settings persistent, set or add the following in /etc/sysctl.conf:
NOTE: You may choose to use a larger setting such as 250000000 to guarantee these settings work for any USRP. Larger numbers require memory allocation but with modern hardware this memory is generally available with plenty of spare.
Adjust Ethernet MTU
This applies to Ethernet connected USRPs: N2xx, N3xx, X3xx, E31x, E320, X4xx
For 1 GbE links, the MTU should be set to 1500.
For 10 GbE and 100 GbE links, the MTU should be set to 9000.
It is important to set the value and not leave it in the default: automatic
Increasing Ring Buffers
This applies to Ethernet connected USRPs using a 10 GbE or 100 GbE interface: N2xx, N3xx, X3xx, E320, X4xx
Increasing the Ring Buffers on the NIC may help prevent flow control errors at higher rates. For example:
To see the NIC limits, use
   sudo ethtool -g <interface>
DPDK
DPDK is supported on USRPs with 10 Gbe (SFP+) and 100 GbE (QSFP28) links. DPDK replaces the traditional Linux networking stack and NIC driver with a low overhead user-land based driver. See the DPDK AppNote for specifics.
Disable Hyper-threading
Disable KPTI Protections for Spectre/Meltdown
In some cases, disabling the KPTI protections for the Linux Kernel can increase performance by 10-15%. It is important to note the ramification making this modification can have. This modification is only recommended for systems that absolutely require the best performance and are not connected to the internet.
Disabling KPTI protections can be done by adding the lines below to your /etc/default/grub file at GRUB_CMDLINE_LINUX_DEFAULT="".
For Linux kernel 5:
   pti=off spectre_v2=off l1tf=off nospec_store_bypass_disable no_stf_barrier
For Linux kernel 6 or higher:
   mitigations=off
NOTE: After saving the GRUB_CONFIG file, execute sudo update-grub and then reboot the computer for the changes to take effect.
