Revision as of 18:25, 7 April 2016 by Ettus (Talk | contribs) (Enclosures (B-series only))
B200
  • Optional Board Mounted GPSDO (TCXO)
B210
B200mini
B200mini-i
B205mini-i
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typ NF) -20dBm
  • Typical Noise Figure <8dB
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Dimensions
Environmental Specifications
  • B200mini 0-40 °C
  • B200mini-i 0-45 °C
  • B205mini-i 0-45 °C
  • B200 0-40 °C
  • B210 0-40 °C
B200mini
B200mini Schematics
B210
B210 Schematics
Key Components
AD9364
AD9361
Spartan-6
Xilinx Spartan-6 Product Page
B200mini VXTCXO
M9107 GPSDO
ADF4001 Frequency Synthesizer
XC6SLX75 / XC6SLX150
CYUSB3014
SKY13317
BD3150L50100A00
PGA−102+
Datasheets
B200mini-i/B200mini
B200/B210
Mechanical Info
Weight
  • B200mini 24.0 g
  • B200/B210 350 g
Drawings
Enclosures
  • Full Steel Enclosure
USRP B Series Enclosure
FPGA
B200
Slice Logic Utilization
Used Total Percent
Number of Slice Registers 12007 93296 12%
Number of Slice LUTs 17149 46648 36%
Number used as Logic 14889 46648 31%
Number used as Memory 2260 11072 20%
Number used as RAM 336
Number used as SRL 1924
Slice Logic Distribution
Used Total Percent
Number with an unused Flip Flop 8325 20332 40%
Number with an unused LUT 3183 20332 15%
Number of fully used LUT-FF pairs 8824 20332 43%
Number of LUT Flip Flop pairs used 20332
Number of unique control sets 301
IO Utilization
Used Total Percent
Number of bonded IOBs 156 280 55%
IOB Flip Flops/Latches 138
Number of IOs 172
Specific Feature Utilization
Used Total Percent
Number of Block RAM/FIFO 144 172 83%
Number of BUFG/BUFGCTRLs 5 16 31%
Number of DSP48A1s 16 132 12%
Number using Block RAM only 144
B210
Used Total Percent
Number of Slice Registers 21608 184304 11%
Number of Slice LUTs 30782 92152 33%
Number used as Logic 27069 92152 29%
Number used as Memory 3713 21680 17%
Number used as RAM 480
Number used as SRL 3233
Used Total Percent
Number with an unused Flip Flop 15225 36833 41%
Number with an unused LUT 6051 36833 16%
Number of fully used LUT-FF pairs 15557 36833 42%
Number of LUT Flip Flop pairs used 36833
Number of unique control sets 461
IO Utilization
Used Total Percent
Number of bonded IOBs 156 338 46%
IOB Flip Flops/Latches 154
Number of IOs 172
Used Total Percent
Number of Block RAM/FIFO 186 268 69%
Number of DSP48A1s 32 180 17%
Number using Block RAM only 186
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
