B200/B210/B200mini/B205mini
[hide]Device Overview
B200
- Xilinx Spartan 6 XC6SLX75 FPGA
- Analog Devices AD9364 RFIC direct-conversion transceiver
- Frequency range: 70 MHz - 6 GHz
- Up to 56 MHz of instantaneous bandwidth
- Full duplex, SISO (1 Tx & 1 Rx)
- Fast and convenient bus-powered USB 3.0 connectivity
- Optional Board Mounted GPSDO (TCXO)
B210
- Xilinx Spartan 6 XC6SLX150 FPGA
- Analog Devices AD9361 RFIC direct-conversion transceiver
- Up to 56 MHz of instantaneous bandwidth (61.44MS/s quadrature)
- Full duplex, MIMO (2 Tx & 2 Rx)
B200mini
- Xilinx Spartan-6 XC6SLX75 FPGA
B200mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX75 FPGA
B205mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX150 FPGA
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Dimensions
- B200mini/B205mini 5.0 x 8.4 cm
- B200/B210 9.7 x 15.5 x 1.5 cm
Environmental Specifications
- B200mini 0-40 °C
- B200mini-i 0-45 °C
- B205mini-i 0-45 °C
- B200 0-40 °C
- B210 0-40 °C
B200mini
B210
Key Components
AD9364
AD9361
Spartan-6
Datasheets
B200mini-i/B200mini
B200/B210
Mechanical Info
Weight
- B200mini 24.0 g
- B200/B210 350 g
Drawings
- B200mini Media:B200mini_drawing.png
- B200 [ ADD ]
- B210 [ ADD ]
Enclosures
- Full Steel Enclosure
- Compatible with green USRP B200 and B210 devices (revision 6 or later)
- Front and rear K-Slots for anti-theft protection
FPGA
B200
Slice Logic Utilization | |||||
Used | Total | Percent | |||
Number of Slice Registers | 12007 | 93296 | 12% | ||
Number of Slice LUTs | 17149 | 46648 | 36% | ||
Number used as Logic | 14889 | 46648 | 31% | ||
Number used as Memory | 2260 | 11072 | 20% | ||
Number used as RAM | 336 | ||||
Number used as SRL | 1924 |
Slice Logic Distribution | |||||
Number with an unused Flip Flop | 8325 | 20332 | 40% | ||
Number with an unused LUT | 3183 | 20332 | 15% | ||
Number of fully used LUT-FF pairs | 8824 | 20332 | 43% | ||
Number of LUT Flip Flop pairs used | 20332 | ||||
Number of unique control sets | 301 |
IO Utilization | |||||
Number of bonded IOBs | 156 | 280 | 55% | ||
IOB Flip Flops/Latches | 138 | ||||
Number of IOs | 172 |
Specific Feature Utilization | |||||
Number of Block RAM/FIFO | 144 | 172 | 83% | ||
Number of BUFG/BUFGCTRLs | 5 | 16 | 31% | ||
Number of DSP48A1s | 16 | 132 | 12% | ||
Number using Block RAM only | 144 |
B210
Number of Slice Registers | 21608 | 184304 | 11% | ||
Number of Slice LUTs | 30782 | 92152 | 33% | ||
Number used as Logic | 27069 | 92152 | 29% | ||
Number used as Memory | 3713 | 21680 | 17% | ||
Number used as RAM | 480 | ||||
Number used as SRL | 3233 |
Number with an unused Flip Flop | 15225 | 36833 | 41% | ||
Number with an unused LUT | 6051 | 36833 | 16% | ||
Number of fully used LUT-FF pairs | 15557 | 36833 | 42% | ||
Number of LUT Flip Flop pairs used | 36833 | ||||
Number of unique control sets | 461 |
Number of bonded IOBs | 156 | 338 | 46% | ||
IOB Flip Flops/Latches | 154 | ||||
Number of Block RAM/FIFO | 186 | 268 | 69% | ||
Number of DSP48A1s | 32 | 180 | 17% | ||
Number using Block RAM only | 186 |
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Downloads
FAQ
This is a list of frequently asked questions on the USRP B200/B210/B200mini. If you have questions that are not answered in this document, please contact us - info@ettus.com.
