B200
- Xilinx Spartan 6 XC6SLX75 FPGA
- Analog Devices AD9364 RFIC direct-conversion transceiver
- Frequency range: 70 MHz - 6 GHz
- Up to 56 MHz of instantaneous bandwidth
- Full duplex, SISO (1 Tx & 1 Rx)
- Fast and convenient bus-powered USB 3.0 connectivity
- Optional Board Mounted GPSDO (TCXO)
B210
- Xilinx Spartan 6 XC6SLX150 FPGA
- Analog Devices AD9361 RFIC direct-conversion transceiver
- Up to 56 MHz of instantaneous bandwidth (61.44MS/s quadrature)
- Full duplex, MIMO (2 Tx & 2 Rx)
B200mini
- Xilinx Spartan-6 XC6SLX75 FPGA
B200mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX75 FPGA
B205mini-i
- Industrial-grade Xilinx Spartan-6 XC6SLX150 FPGA
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
Physical Specifications
Dimensions
- B200mini/B205mini 5.0 x 8.4 cm
- B200/B210 9.7 x 15.5 x 1.5 cm
Environmental Specifications
- B200mini 0-40 °C
- B200mini-i 0-45 °C
- B205mini-i 0-45 °C
- B200 0-40 °C
- B210 0-40 °C
B200mini
B210
Datasheets
- Transceiver - Analog Devices AD9364
- Transceiver - Analog Devices AD9361
- FPGA - XC6SLX75 / XC6SLX150
- VXTCXO - B200mini VXTCXO
- GPSDO - M9107
- Frequency Synthesizer - ADF4001
- FX3: SuperSpeed USB Controller - CYUSB3014
- Antenna Switch - SKY13317
- Balun - BD3150L50100A00
- Amplifier - PGA−102+
Mechanical Info
Weight
- B200mini 24.0 g
- B200/B210 350 g
Drawings
- B200mini Media:B200mini_drawing.png
- B200 [ ADD ]
- B210 [ ADD ]
Enclosures
- Full Steel Enclosure
- Compatible with green USRP B200 and B210 devices (revision 6 or later)
- Front and rear K-Slots for anti-theft protection
FPGA
B200
| Slice Logic Utilization | |||||
| Used | Total | Percent | |||
| Number of Slice Registers | 12007 | 93296 | 12% | ||
| Number of Slice LUTs | 17149 | 46648 | 36% | ||
| Number used as Logic | 14889 | 46648 | 31% | ||
| Number used as Memory | 2260 | 11072 | 20% | ||
| Number used as RAM | 336 | ||||
| Number used as SRL | 1924 | ||||
| Slice Logic Distribution | |||||
| Number with an unused Flip Flop | 8325 | 20332 | 40% | ||
| Number with an unused LUT | 3183 | 20332 | 15% | ||
| Number of fully used LUT-FF pairs | 8824 | 20332 | 43% | ||
| Number of LUT Flip Flop pairs used | 20332 | ||||
| Number of unique control sets | 301 | ||||
| IO Utilization | |||||
| Number of bonded IOBs | 156 | 280 | 55% | ||
| IOB Flip Flops/Latches | 138 | ||||
| Number of IOs | 172 | ||||
| Specific Feature Utilization | |||||
| Number of Block RAM/FIFO | 144 | 172 | 83% | ||
| Number of BUFG/BUFGCTRLs | 5 | 16 | 31% | ||
| Number of DSP48A1s | 16 | 132 | 12% | ||
| Number using Block RAM only | 144 | ||||
B210
| Number of Slice Registers | 21608 | 184304 | 11% | ||
| Number of Slice LUTs | 30782 | 92152 | 33% | ||
| Number used as Logic | 27069 | 92152 | 29% | ||
| Number used as Memory | 3713 | 21680 | 17% | ||
| Number used as RAM | 480 | ||||
| Number used as SRL | 3233 | ||||
| Number with an unused Flip Flop | 15225 | 36833 | 41% | ||
| Number with an unused LUT | 6051 | 36833 | 16% | ||
| Number of fully used LUT-FF pairs | 15557 | 36833 | 42% | ||
| Number of LUT Flip Flop pairs used | 36833 | ||||
| Number of unique control sets | 461 | ||||
| Number of bonded IOBs | 156 | 338 | 46% | ||
| IOB Flip Flops/Latches | 154 | ||||
| Number of Block RAM/FIFO | 186 | 268 | 69% | ||
| Number of DSP48A1s | 32 | 180 | 17% | ||
| Number using Block RAM only | 186 | ||||
Interfaces and Connectivity
B200/B210/B200mini - USB 3.0
Downloads
Application Notes
FAQ
This is a list of frequently asked questions on the USRP B200/B210/B200mini. If you have questions that are not answered in this document, please contact us - [email protected].
