N200/N210
Revision as of 17:14, 13 April 2016 by Ettus (Talk | contribs) (Datasheets)
The USRP Network Series offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP Network Series allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP Network an ideal candidate for software defined radio systems with demanding performance requirements.
N200
  • Xilinx® Spartan® 3A-DSP 1800 FPGA
  • 14 bit 100 MS/s dual ADC
  • 16 bit 400 MS/s dual DAC
  • Frequency range: DC - 6 GHz with suitable daughterboard
  • Up to 50 MS/s in both directions
  • Fully-Coherent MIMO Capability
  • Optional GPSDO
  • Gigabit Ethernet connectivity
N210
  • Xilinx® Spartan® 3A-DSP 3400 FPGA
  • Optional GPSDO
Compatible Daughterboards
  • SBX-40
  • UBX-40
  • WBX-40
  • CBX-40
  • LFRX / LFTX
  • BasicRX / BasicTX
  • TVRX2
  • DBSRX2
RF Performance (with WBX)
  • Phase Noise 1.8 GHz 10kHz -80 dBc/Hz
  • Phase Noise 1.8 GHz 100kHz -100 dBc/Hz
  • Phase Noise 1.8 GHz 1MHz -137 dBc/Hz
  • Power Output 15 dBm
  • IIP3 (@ typ NF) 0 dBm
  • Typical Noise Figure 5 dB
Physical Specifications
Dimensions
22 x 16 x 5 cm
Environmental Specifications
  • N200/N210 0-40 °C
N200/N210
N200/N210 Schematics
Datasheets
  • Dual Channel, 16-Bit DAC - AD9777
  • AD56x3
  • Clock Distribution IC - AD9510
  • Gigabit Ethernet Transceiver - ET1011C2
Mechanical Info
Weight
1.2 kg
Drawings
FPGA
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Interfaces and Connectivity
N200/N210
  • Gigabit Ethernet
Downloads (FPGA images, E310 images, etc.)
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
Application Notes
FAQ
