Changes related to "Category:Application Notes"
This is a list of changes made recently to pages linked from a specified page (or to members of a specified category). Pages on your watchlist are bold.
Recent changes options
Legend:
N
This edit created a new page (also see list of new pages)
m
This is a minor edit
b
This edit was performed by a bot
(±123)
The page size changed by this number of bytes
Show last 50 | 100 | 250 | 500 changes in last 1 | 3 | 7 | 14 | 30 days
Hide minor edits | Show bots | Hide anonymous users | Hide registered users | Hide my edits
Show new changes starting from 07:59, 5 September 2026
Page name:
30 August 2026
     15:47  Getting Started with DPDK and UHD‎‎ (36 changes | history) . . (+5,281). . [MichaelDickens‎ (36×)]
     15:47 (cur | prev) . . (+365). . MichaelDickens (Talk | contribs) (Abstract: a little more depth)
     15:41 (cur | prev) . . (+86). . MichaelDickens (Talk | contribs) (Regular Data Transport Issues on multi-CPU Systems using NUMA nodes: link taskset to that section)
     15:40 (cur | prev) . . (+84). . MichaelDickens (Talk | contribs) (Regular Data Transport Issue on multi-CPU Systems: clarifying)
     15:37 (cur | prev) . . (+221). . MichaelDickens (Talk | contribs) (Regular Overflows on multi-CPU Systems: clarifying)
     15:24 (cur | prev) . . (-130). . MichaelDickens (Talk | contribs) (UHD 4.x: remove redundant note)
     15:22 (cur | prev) . . (+18). . MichaelDickens (Talk | contribs) (Preparing your UHD Configuration File)
     15:22 (cur | prev) . . (+16). . MichaelDickens (Talk | contribs) (Enable hugepages)
     15:21 (cur | prev) . . (+9). . MichaelDickens (Talk | contribs) (Enable hugepages)
     15:18 (cur | prev) . . (+29). . MichaelDickens (Talk | contribs) (USRPs)
     15:17 (cur | prev) . . (+45). . MichaelDickens (Talk | contribs) (Abstract: rewording)
     15:15 (cur | prev) . . (+286). . MichaelDickens (Talk | contribs) (Abstract: general tweaks)
     14:54 (cur | prev) . . (+135). . MichaelDickens (Talk | contribs) (update history)
     14:01 (cur | prev) . . (+64). . MichaelDickens (Talk | contribs) (USRPs: more concise pagination)
     13:59 (cur | prev) . . (-253). . MichaelDickens (Talk | contribs) (UHD DPDK Version Dependencies: remove NOTE because it's the next section anyway)
     13:58 (cur | prev) . . (+1). . MichaelDickens (Talk | contribs) (UHD DPDK Version Dependencies)
     13:58 (cur | prev) . . (-198). . MichaelDickens (Talk | contribs) (References: reduce and make generic ... fewer updates in the future!)
     13:55 (cur | prev) . . (+17). . MichaelDickens (Talk | contribs) (Dependencies: tweak title)
     13:54 (cur | prev) . . (+134). . MichaelDickens (Talk | contribs) (Installing DPDK: elaborate on UHD + DPDK for updated NIC drivers)
     13:51 (cur | prev) . . (+89). . MichaelDickens (Talk | contribs) (Installing DPDK: tweaks)
     13:48 (cur | prev) . . (+253). . MichaelDickens (Talk | contribs) (Dependencies: add NOTE)
 m   13:33 (cur | prev) . . (+33). . MichaelDickens (Talk | contribs) (Increasing num_recv_frames)
 m   13:33 (cur | prev) . . (-1). . MichaelDickens (Talk | contribs) (Increasing num_recv_frames)
     13:32 (cur | prev) . . (+220). . MichaelDickens (Talk | contribs) (Stopping Extraneous Processes: add NOTE)
     13:29 (cur | prev) . . (+147). . MichaelDickens (Talk | contribs) (Limit Execution CPUs/Cores: add DPDK control core)
     13:28 (cur | prev) . . (+46). . MichaelDickens (Talk | contribs) (Streaming on Multiple Channels using 1 Thread Per Stream: add throughput note)
     13:27 (cur | prev) . . (+195). . MichaelDickens (Talk | contribs) (Disable System Interrupts on Cores/CPUs: add not about context switching)
     13:25 (cur | prev) . . (+295). . MichaelDickens (Talk | contribs) (Disable System Interrupts on Cores/CPUs: add note about core isolation and taskset)
     13:24 (cur | prev) . . (+230). . MichaelDickens (Talk | contribs) (Isolate Cores/CPUs: add NOTE about using isolated cores)
     13:21 (cur | prev) . . (+277). . MichaelDickens (Talk | contribs) (Streaming on Multiple Channels using 1 Thread Per Stream: add info about UHD-based application)
     13:17 (cur | prev) . . (+61). . MichaelDickens (Talk | contribs) (Disable System Interrupts on Cores/CPUs)
     13:16 (cur | prev) . . (-54). . MichaelDickens (Talk | contribs) (Isolate Cores/CPUs)
     13:16 (cur | prev) . . (+2,026). . MichaelDickens (Talk | contribs) (Isolate Cores/CPUs: much deeper info)
     12:50 (cur | prev) . . (+92). . MichaelDickens (Talk | contribs) (Increasing num_recv_frames)
     12:49 (cur | prev) . . (+132). . MichaelDickens (Talk | contribs) (Increasing num_recv_frames)
     12:45 (cur | prev) . . (+313). . MichaelDickens (Talk | contribs) (Increasing num_recv_frames: Correct value info)
 m   12:38 (cur | prev) . . (-2). . MichaelDickens (Talk | contribs) (Running UHD Applications with DPDK)
     14:31  USRP Host Performance Tuning Tips and Tricks‎‎ (12 changes | history) . . (+866). . [MichaelDickens‎ (12×)]
 m   14:31 (cur | prev) . . (+4). . MichaelDickens (Talk | contribs) (whitespace)
     14:30 (cur | prev) . . (+259). . MichaelDickens (Talk | contribs) (Application Note Number: add history comment)
     14:05 (cur | prev) . . (-48). . MichaelDickens (Talk | contribs) (DPDK: change link to KB AN)
     14:04 (cur | prev) . . (+41). . MichaelDickens (Talk | contribs) (DPDK)
     14:03 (cur | prev) . . (+6). . MichaelDickens (Talk | contribs) (Adjust Ethernet MTU)
     13:45 (cur | prev) . . (+14). . MichaelDickens (Talk | contribs) (Disable KPTI Protections for Spectre/Meltdown: tweak note to be consistent with other same notes)
     13:44 (cur | prev) . . (+83). . MichaelDickens (Talk | contribs) (Disable KPTI Protections for Spectre/Meltdown: kernel 5 versus 6)
     13:43 (cur | prev) . . (+99). . MichaelDickens (Talk | contribs) (Increasing Ring Buffers: NIC limits & exhaustive compressed USRP list)
     13:41 (cur | prev) . . (-46). . MichaelDickens (Talk | contribs) (Adjust Network Buffers: compressed exhaustive list)
     13:41 (cur | prev) . . (+14). . MichaelDickens (Talk | contribs) (Adjust Ethernet MTU: exhaustive USRP list)
     13:40 (cur | prev) . . (+260). . MichaelDickens (Talk | contribs) (Adjust Network Buffers: exhaustive list of ENET based USRPs. Add larger setting)
     13:36 (cur | prev) . . (+180). . MichaelDickens (Talk | contribs) (CPU Governor: add note about cpupower)
29 August 2026
     15:16  Getting Started with DPDK and UHD‎‎ (2 changes | history) . . (+877). . [MichaelDickens‎ (2×)]
     15:16 (cur | prev) . . (+877). . MichaelDickens (Talk | contribs) (Additional Host Configuration for NIC Vendors: update VFIO-PCI info)
     14:55 (cur | prev) . . (0). . MichaelDickens (Talk | contribs) (Running UHD Applications with DPDK)
