E310/E312
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment. The flexible 2x2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest.
E310
- Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 667 MHz dual-core processor
- Analog Devices AD9361 RFIC direct-conversion transceiver
- Frequency range: 70 MHz - 6 GHz
- Up to 56 MHz of instantaneous bandwidth
- 2x2 MIMO transceiver
- Up to 10 MS/s sample data transfer rate to ARM processor
- RX, TX filter banks
- Integrated GPS receiver
- 9-axis inertial measurement unit
- RF Network on Chip (RFNoC™) FPGA development framework support
E312
- Battery Operated
- Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 866 MHz dual-core processor
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
Clocks and Samples Rates
- Add Clock and Sample Rates
Physical Specifications
Dimensions
- 133 x 68 x 26.4 mm
Environmental Specifications
- E310 0-40 °C
E310
Datasheets
InvenSense MPU-9150 Product Page
Request a detailed whitepaper covering features and components from [email protected]
Mechanical Info
Weight
- Partial Enclosure 225 g
- Full Enclosure 375 g
Drawings
- E310 Drawings - File:E310 Dimensional Sketches.pdf
FPGA (MB only)
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Interfaces and Connectivity
- 10/100/1000 BASE-T Ethernet
- Stereo audio out, mono mic in
- Host USB support
- 9-axis IMU
Downloads
