E310/E312
Revision as of 16:25, 29 April 2016 by Ettus (Talk | contribs) (Certifications)
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment. The flexible 2x2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest.
E310
  • Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 667 MHz dual-core processor
  • 2x2 MIMO transceiver
  • Up to 10 MS/s sample data transfer rate to ARM processor
  • RX, TX filter banks
  • Integrated GPS receiver
  • 9-axis inertial measurement unit
  • RF Network on Chip (RFNoC™) FPGA development framework support
E312
  • Battery Operated
  • Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 866 MHz dual-core processor
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typ NF) -20dBm
  • Typical Noise Figure <8dB
Clocks and Samples Rates
  • FIXME NEEL
Physical Specifications
Dimensions
  • 133 x 68 x 26.4 mm
Environmental Specifications
  • E310 0-40 °C
E310
E310 Schematics
E310 DB
Datasheets
TXS02612RTWR
XC7Z020-1CLG484CES9919
USB3340-EZK-TR
AK4571VQP
FT230XQ-R
88E1512
24LC024/SN
DS1339,SM
ADT7408
MPU-9150
BMP180
BQ24192
TPS54478
MAX6510HAUT-T
ATTINY88-MU
TPS61253YFF
AD9361 Product Page
Xilinx Zynq Product Page
InvenSense MPU-9150 Product Page
Request a detailed whitepaper covering features and components from [email protected]
Mechanical Info
Weight
  • Partial Enclosure 225 g
  • Full Enclosure 375 g
Drawings
FPGA (MB only)
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum
Interfaces and Connectivity
  • 10/100/1000 BASE-T Ethernet
  • Stereo audio out, mono mic in
  • Host USB support
  • 9-axis IMU
Certificate of Volatility
  • E310/E312
Downloads
FPGA Images
FPGA Images Read Me
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
Application Notes
FAQ
