E100/E110
Revision as of 13:11, 30 April 2016 by Ettus (Talk | contribs)
USRP E100
  • Designed for embedded applications (runs a full distribution of Linux)
  • 720 MHz OMAP3 (ARM Cortex A8 processor & TI C64x+ DSP)
  • 512MB RAM
  • 4GB microSD Card
  • 100 Mbit Ethernet connectivity
  • Motherboard has one RTX daughterboard slot (1 RX + 1 TX connectors)
  • Onboard FPGA processing
  • FPGA: Xilinx Spartan XC3SD1800A
  • ADCs: 12-bits 64 MS/s
  • DACs: 14-bits 128 MS/s
  • TCXO Frequency Reference (~2.5ppm)
  • Flexible clocking from 10 MHz to 64 MHz
USRP E110
  • 512MB RAM
  • 4GB microSD Card
  • FPGA: Xilinx Spartan XC3SD3400A
Basic Hardware Setup
Spec Sheet
FAQ
What is the default password for the USRP E100 series?
The default username and password for the USRP E100 and USRP E110 of the Embedded Series is:
  • Username: root
  • Password: usrpe
What are the available resources on the FPGA?
The available resources on the FPGA will vary depending on the code written for it. Based on the 27 March 2012 FPGA code build, the following resources are available:
USRP E110 (Xilinx Spartan 3A DSP - XC3SD3400A FPGA)
  • General Logic:
    • Flip Flops: 69% free
    • LUTs: 78% free
  • Memory: 50% free
  • DSP Resources: 78% free
USRP E100 (Xilinx Spartan 3A-1400 FPGA)
  • General Logic:
    • Flip Flops: 29% free
    • LUTs: 6% free
  • Memory: 10% free
  • DSP Resources: 13% free
Proper Care and Handling
  • Never apply more than -15 dBm of power into any RF input.
  • Always use at least 30dB attenuation if operating in loopback configuration
Technical support for USRP hardware is available through email only. If the product arrived in a non­functional state or you require technical assistance, please contact s​[email protected]​. Please allow 24 to 48 hours for response by email, depending on holidays and weekends, although we are often able to reply more quickly than that.
Discussions involving the USRP hardware and the UHD software itself are best addressed through the u​srp­-users ​mailing list at http://usrp-users.ettus.com/.
Discussions involving the use of GNU Radio with USRP hardware and UHD software are best addressed through the d​iscuss­gnuradio​mailing list at https://lists.gnu.org/mailman/listinfo/discuss­gnuradio​.
Discussions involving the use of OpenBTS® with USRP hardware and UHD software are best addressed through the o​penbts­discuss​mailing list at https://lists.sourceforge.net/lists/listinfo/openbts­discuss​.​
The support page on our website is located at h​ttp://www.ettus.com/support​. The Knowledge Base is located at ​http://www.ettus.com/kb​.
Legal Considerations
Sales and Ordering Support
If you have any non­technical questions related to your order, then please contact us by email at [email protected]​, or by phone at +1­408­610­6399 (Monday­Friday, 8 AM 5 PM, Pacific Time). Please be sure to include your order number and the serial number of your USRP.
Terms and Conditions of Sale
