B100
Revision as of 03:18, 14 May 2016 by Ettus (Talk | contribs) (→‎Legal Considerations)
USRP B100
  • (EOL – this product is no longer available for sale through Ettus Research)
  • 16 MHz of RF bandwidth with 8 bit samples
  • 8 MHz of RF bandwidth with 16 bit samples
  • USB 2.0 high speed connectivity
  • Motherboard has one RTX daughterboard slot (1 RX + 1 TX connectors)
  • Onboard FPGA processing
  • FPGA: Xilinx Spartan 3A-1400 FPGA
  • ADCs: 12-bits 64 MS/s
  • DACs: 14-bits 128 MS/s
  • Ability to lock to external 5 or 10 MHz clock reference
  • TCXO Frequency Reference (~2.5ppm)
  • Flexible clocking from 10 MHz to 64 MHz
  • FPGA code can be changed with Xilinx® ISE® WebPACK™ tools
FPGA
  • Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
B100
Device utilization summary:
Selected Device : 3s1400aft256-4
 Number of Slices:                    10238  out of  11264    90%
 Number of Slice Flip Flops:          12136  out of  22528    53%
 Number of 4 input LUTs:              18184  out of  22528    80%
    Number used as logic:             15003
    Number used as Shift registers:    2605
    Number used as RAMs:                576
 Number of IOs:                         150
 Number of bonded IOBs:                 148  out of    161    91%
    IOB Flip Flops:                     140
 Number of BRAMs:                        31  out of     32    96%
 Number of MULT18X18SIOs:                20  out of     32    62%
 Number of GCLKs:                         2  out of     24     8%
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The BasicTX/BasicRX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the BasicTX/BasicRX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Sales and Ordering Support
Terms and Conditions of Sale
