E310/E312
[hide]- 1 Device Overview
- 2 Key Features
- 3 RF Specifications
- 4 Hardware Specifications
- 5 Clocks and Samples Rates
- 6 Physical Specifications
- 8 Schematics
- 9 Key Component Datasheets
- 10 Mechanical Info
- 11 FPGA
- 13 Multiple Device Configuration
- 14 Certifications
- 15 Certificate of Volatility
- 16 Downloads
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment. The flexible 2x2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest.
E310
E312
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
E310
- Details
E312
- Details
- FIXME NEEL
Dimensions
- 133 x 68 x 26.4 mm
- E310 0-40 °C
E310
TXS02612RTWR | SDIO PORT EXPANDER | U23 (2) |
XC7Z020-1CLG484CES9919 | FPGA | U11 (2,3,4,8,11,13) |
USB3340-EZK-TR | ULPI Transceiver | U33 (5) |
AK4571VQP | Audio CODEC | U30 (6) |
FT230XQ-R | UART Interface | U32 (6) |
88E1512 | Gigabit Ethernet Transceiver | U13 (7) |
24LC024/SN | EEPROM | U5 (9) |
DS1339,SM | Real-Time Clock | U6 (9) |
ADT7408 | Temperature Sensor | U8 (9) |
MPU-9150 | Motion Processing Unit | U3 (9) |
BMP180 | Digital pressure sensor | U4 (9) |
BQ24192 | Adapter Charger | U1 (10) |
TPS54478 | Step-Down Switcher | U20 (10) |
MAX6510HAUT-T | Temperature Switches | U35 (10) |
ATTINY88-MU | Microcontroller | U18 (10) |
TPS61253YFF | Step-Up Converter | U19 (10) |
AD9361 Product Page | 2 x 2 RF Agile Transceiver | U8 (3) |
Xilinx Zynq Product Page | FPGA | - |
InvenSense MPU-9150 Product Page | Motion Processing Unit | U3 (9) |
Request a detailed whitepaper covering features and components from info@ettus.com
Mechanical Info
Weight
- Partial Enclosure 225 g
- Full Enclosure 375 g
Drawings
- E310 Drawings - File:E310 Dimensional Sketches.pdf
FPGA
- Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
E310/E312
1. Slice Logic -------------- +----------------------------+-------+-----------+-------+ | Site Type | Used | Available | Util% | +----------------------------+-------+-----------+-------+ | Slice LUTs | 36203 | 53200 | 68.05 | | LUT as Logic | 28108 | 53200 | 52.83 | | LUT as Memory | 8095 | 17400 | 46.52 | | LUT as Distributed RAM | 870 | | | | LUT as Shift Register | 7225 | | | | Slice Registers | 36562 | 106400 | 34.36 | | Register as Flip Flop | 36562 | 106400 | 34.36 | | Register as Latch | 0 | 106400 | 0.00 | | F7 Muxes | 376 | 26600 | 1.41 | | F8 Muxes | 125 | 13300 | 0.93 | +----------------------------+-------+-----------+-------+ 3. Memory --------- +-------------------+------+-----------+-------+ | Site Type | Used | Available | Util% | +-------------------+------+-----------+-------+ | Block RAM Tile | 97 | 140 | 69.28 | | RAMB36/FIFO* | 90 | 140 | 64.28 | | RAMB36E1 only | 90 | | | | RAMB18 | 14 | 280 | 5.00 | | RAMB18E1 only | 14 | | | +-------------------+------+-----------+-------+ * Note: Each Block RAM Tile only has one FIFO logic available and therefore can accommodate only one FIFO36E1 or one FIFO18E1. However, if a FIFO18E1 occupies a Block RAM Tile, that tile can still accommodate a RAMB18E1 4. DSP ------ +----------------+------+-----------+-------+ | Site Type | Used | Available | Util% | +----------------+------+-----------+-------+ | DSPs | 120 | 220 | 54.54 | | DSP48E1 only | 120 | | | +----------------+------+-----------+-------+
- 10/100/1000 BASE-T Ethernet
- Stereo audio out, mono mic in
- Integrated GPS receiver
- Host USB support
- 9-axis IMU
- [ADD]
