E310/E312
[hide]Device Overview
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment. The flexible 2x2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest.
E310
E312
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
Hardware Specifications
E310
- Required version on the host computer must match what is running on the E310
E312
- Minimum version of UHD required: 3.8.5
- Required version on the host computer must match what is running on the E312
Physical Specifications
Dimensions
- 133 x 68 x 26.4 mm
Environmental Specifications
- E310 0-40 °C
E310
Key Component Datasheets
Motherboard | ||
TXS02612RTWR | SDIO PORT EXPANDER | U23 (2) |
XC7Z020-1CLG484CES9919 | FPGA | U11 (2,3,4,8,11,13) |
Xilinx Zynq Product Page | FPGA | - |
USB3340-EZK-TR | ULPI Transceiver | U33 (5) |
AK4571VQP | Audio CODEC | U30 (6) |
FT230XQ-R | UART Interface | U32 (6) |
88E1512 | Gigabit Ethernet Transceiver | U13 (7) |
24LC024/SN | EEPROM | U5 (9) |
DS1339,SM | Real-Time Clock | U6 (9) |
ADT7408 | Temperature Sensor | U8 (9) |
MPU-9150 | Motion Processing Unit | U3 (9) |
InvenSense MPU-9150 Product Page | Motion Processing Unit | U3 (9) |
BMP180 | Digital pressure sensor | U4 (9) |
BQ24192 | Adapter Charger | U1 (10) |
TPS54478 | Step-Down Switcher | U20 (10) |
MAX6510HAUT-T | Temperature Switches | U35 (10) |
ATTINY88-MU | Microcontroller | U18 (10) |
TPS61253YFF | Step-Up Converter | U19 (10) |
Daughterboard | ||
AD9361 Product Page | 2 x 2 RF Agile Transceiver | U8 (3) |
24AA256 | EEPROM | U15 (2) |
TC-1-43A+ | RF Transformer | T6 (3); T5 (3); T4 (3) |
TC1-1-13M+ | RF Transformer | T7 (3); T10 (3); T1 (3) |
TPS62140 | Step-Down Converter | U19 (4) |
ADP1753ACPZ-R7 | Linear Regulator | U17 (4); U18 (4) |
SGA-4563Z | MMIC AMPLIFIER | U12 (5); U4 (5) |
SKY13418-485LF | Antenna Switch | U13 (5); U3 (5); U16 (5); U2 (5); U10 (6); U5 (6) |
SKY13373-460LF | SP3T Switch | U11 (6); U9 (6); U6 (6); U7 (6); SW4 (7); SW1 (7) |
MGA-81563 | Amplifier | U14 (5); U1 (5) |
LFCN-5850+ | Low Pass Filter | FL32 (5); FL1 (5) |
LFCN-2750+ | Low Pass Filter | FL37 (5); FL4 (5) |
LFCN-2250+ | Low Pass Filter | FL23 (6); FL20 (6) |
LFCN-1700+ | Low Pass Filter | FL40 (5); FL2 (5) |
LFCN-1575+ | Low Pass Filter | FL25 (6); FL17 (6) |
LFCN-1000+ | Low Pass Filter | FL33 (5); FL9 (5); FL27 (6); FL15 (6) |
LFCN-575+ | Low Pass Filter | FL36 (5); FL5 (5) |
LFCN-530+ | Low Pass Filter | FL29 (6); FL13 (6) |
LFCN-400+ | Low Pass Filter | FL38 (5); FL3 (5); FL30 (6); FL11 (6) |
LFCN-225 | Low Pass Filter | FL39 (5); FL6 (5) |
LFCN-160+ | Low Pass Filter | FL34 (5); FL8 (5) |
LFCN-80+ | Low Pass Filter | FL35 (5); FL7 (5) |
HFCN-1600+ | High Pass Filter | FL22 (6); FL19 (6) |
HFCN-1100+ | High Pass Filter | FL24 (6); FL16 (6) |
HFCN-650+ | High Pass Filter | FL26 (6); FL14 (6) |
HFCN-440+ | High Pass Filter | FL28 (6); FL12 (6) |
BFCN-2435+ | Bandpass Filter | FL21 (6); FL18 (6) |
FDG6301N | Dual N-Channel, Digital FET | Q8 (7); Q5 (7) |
HSMS-8202 | Mixer Diodes | CR1 (7); CR2 (7); CR3 (7); CR4 (7) |
LP5900TL | Linear Regulator | U25 (8) |
ADP150AUJZ-3.0 | Linear Regulator | U22 (8) |
AD5662RBJ | 16-Bit nanoDAC | U21 (8) |
SN74AUP1T57 | Voltage Translator | U27 (8); U28 (8); U29 (8) |
Request a detailed whitepaper covering features and components from info@ettus.com
Mechanical Information
Weight
- Partial Enclosure 225 g
- Full Enclosure 375 g
Drawings
- E310 Drawings - File:E310 Dimensional Sketches.pdf
FPGA
- Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
E310/E312
1. Slice Logic -------------- +----------------------------+-------+-----------+-------+ | Site Type | Used | Available | Util% | +----------------------------+-------+-----------+-------+ | Slice LUTs | 36203 | 53200 | 68.05 | | LUT as Logic | 28108 | 53200 | 52.83 | | LUT as Memory | 8095 | 17400 | 46.52 | | LUT as Distributed RAM | 870 | | | | LUT as Shift Register | 7225 | | | | Slice Registers | 36562 | 106400 | 34.36 | | Register as Flip Flop | 36562 | 106400 | 34.36 | | Register as Latch | 0 | 106400 | 0.00 | | F7 Muxes | 376 | 26600 | 1.41 | | F8 Muxes | 125 | 13300 | 0.93 | +----------------------------+-------+-----------+-------+ 3. Memory --------- +-------------------+------+-----------+-------+ | Site Type | Used | Available | Util% | +-------------------+------+-----------+-------+ | Block RAM Tile | 97 | 140 | 69.28 | | RAMB36/FIFO* | 90 | 140 | 64.28 | | RAMB36E1 only | 90 | | | | RAMB18 | 14 | 280 | 5.00 | | RAMB18E1 only | 14 | | | +-------------------+------+-----------+-------+ * Note: Each Block RAM Tile only has one FIFO logic available and therefore can accommodate only one FIFO36E1 or one FIFO18E1. However, if a FIFO18E1 occupies a Block RAM Tile, that tile can still accommodate a RAMB18E1 4. DSP ------ +----------------+------+-----------+-------+ | Site Type | Used | Available | Util% | +----------------+------+-----------+-------+ | DSPs | 120 | 220 | 54.54 | | DSP48E1 only | 120 | | | +----------------+------+-----------+-------+
Interfaces and Connectivity
- 10/100/1000 BASE-T Ethernet
- Stereo audio out, mono mic in
- Integrated GPS receiver
- Host USB support
- 9-axis IMU
