B100
Revision as of 14:28, 8 June 2016 by Ettus (Talk | contribs) (→‎Proper Care and Handling)
USRP B100
  • (EOL – this product is no longer available for sale through Ettus Research)
  • 16 MHz of RF bandwidth with 8 bit samples
  • 8 MHz of RF bandwidth with 16 bit samples
  • USB 2.0 high speed connectivity
  • Motherboard has one RTX daughterboard slot (1 RX + 1 TX connectors)
  • Onboard FPGA processing
  • FPGA: Xilinx Spartan 3A-1400 FPGA
  • ADCs: 12-bits 64 MS/s
  • DACs: 14-bits 128 MS/s
  • Ability to lock to external 5 or 10 MHz clock reference
  • TCXO Frequency Reference (~2.5ppm)
  • Flexible clocking from 10 MHz to 64 MHz
  • FPGA code can be changed with Xilinx® ISE® WebPACK™ tools
FPGA
  • Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
B100
Device utilization summary:
Selected Device : 3s1400aft256-4
 Number of Slices:                    10238  out of  11264    90%
 Number of Slice Flip Flops:          12136  out of  22528    53%
 Number of 4 input LUTs:              18184  out of  22528    80%
    Number used as logic:             15003
    Number used as Shift registers:    2605
    Number used as RAMs:                576
 Number of IOs:                         150
 Number of bonded IOBs:                 148  out of    161    91%
    IOB Flip Flops:                     140
 Number of BRAMs:                        31  out of     32    96%
 Number of MULT18X18SIOs:                20  out of     32    62%
 Number of GCLKs:                         2  out of     24     8%
All Ettus Research products are individually tested before shipment. The USRP B100 is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP B100 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
