E310/E312
[hide]- 1 Device Overview
- 2 Key Features
- 4 RF Specifications
- 5 Hardware Specifications
- 6 Physical Specifications
- 8 Schematics
- 9 Key Component Datasheets
- 10 Mechanical Information
- 11 FPGA
- 13 E312 Battery
- 14 Certifications
- 15 Certificate of Volatility
- 16 SD Card Images
- 17 Additional Resources
- 18 Downloads
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment. The flexible 2x2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest.
E310
E312
E310 MIMO XCVR board
Tuning
Gains
LO lock status
// assumes 'usrp' is a valid uhd::usrp::multi_usrp::sptr instance
// get status for rx frontend
usrp->get_rx_sensor("lo-locked");
// get status for tx frontend
usrp->get_tx_sensor("lo-locked");
Filter and Antenna Switches
Source code related to controlling the filter band and antenna switches resides in e300_impl.c
. Specifically, refer to methods e300_impl::_update_bandsel
, e300_impl::_update_atrs
, e300_impl::_update_gpio
, and e300_impl::_update_enables
. Generally, these methods set the switches depending on the state of transmit and receive streams.
The following sections provide switch setting tables for antenna and filter selection for frontends A & B receive and transmit paths. For futher details refer to the schematics.
Side A Filter and Antenna Switches
Receive
RX Port | RX Filter (MHz) | VCTXRX2_V1,V2 | VCRX2_V1,V2 | RX2_BANDSEL[2:0] | RX2B_BANDSEL[1:0] | RX2C_BANDSEL[1:0] |
TRX-A | < 450 | 01 | 10 | 101 | XX | 01 |
TRX-A | 450 – 700 | 01 | 10 | 011 | XX | 11 |
TRX-A | 700 – 1200 | 01 | 10 | 001 | XX | 10 |
TRX-A | 1200 – 1800 | 01 | 10 | 000 | 01 | XX |
TRX-A | 1800 – 2350 | 01 | 10 | 010 | 11 | XX |
TRX-A | 2350 – 2600 | 01 | 10 | 100 | 10 | XX |
TRX-A | 2600 – 6000 | 01 | 01 | XXX | XX | XX |
RX2-A | 70 – 450 | TT | 01 | 101 | XX | 01 |
RX2-A | 450 – 700 | TT | 01 | 011 | XX | 11 |
RX2-A | 700 – 1200 | TT | 01 | 001 | XX | 10 |
RX2-A | 1200 – 1800 | TT | 01 | 000 | 01 | XX |
RX2-A | 1800 – 2350 | TT | 01 | 010 | 11 | XX |
RX2-A | 2350 – 2600 | TT | 01 | 100 | 10 | XX |
RX2-A | >= 2600 | TT | 10 | XXX | XX | XX |
Transmit
TX Port | TX Filter (MHz) | VCTXRX2_V1,V2 | TX_ENABLE2A,2B | TX_BANDSEL[2:0] |
TRX-A | < 117.7 | 10 | 01 | 111 |
TRX-A | 117.7 – 178.2 | 10 | 01 | 110 |
TRX-A | 178.2 – 284.3 | 10 | 01 | 101 |
TRX-A | 284.3 – 453.7 | 10 | 01 | 100 |
TRX-A | 453.7 – 723.8 | 10 | 01 | 011 |
TRX-A | 723.8 – 1154.9 | 10 | 01 | 010 |
TRX-A | 1154.9 – 1842.6 | 10 | 01 | 001 |
TRX-A | 1842.6 – 2940.0 | 10 | 01 | 000 |
TRX-A | >= 2940.0 | 11 | 10 | XXX |
Side B Filter and Antenna Switches
Receive
RX Port | RX Filter (MHz) | VCTXRX1_V1,V2 | VCRX1_V1,V2 | RX1_BANDSEL[2:0] | RX1B_BANDSEL[1:0] | RX1C_BANDSEL[1:0] |
TRX-B | < 450 | 10 | 01 | 100 | XX | 10 |
TRX-B | 450 – 700 | 10 | 01 | 010 | XX | 11 |
TRX-B | 700 – 1200 | 10 | 01 | 000 | XX | 01 |
TRX-B | 1200 – 1800 | 10 | 01 | 001 | 10 | XX |
TRX-B | 1800 – 2350 | 10 | 01 | 011 | 11 | XX |
TRX-B | 2350 – 2600 | 10 | 01 | 101 | 01 | XX |
TRX-B | 2600 – 6000 | 10 | 10 | XXX | XX | XX |
RX2-B | 70 – 450 | TT | 10 | 100 | XX | 10 |
RX2-B | 450 – 700 | TT | 10 | 010 | XX | 11 |
RX2-B | 700 – 1200 | TT | 10 | 000 | XX | 01 |
RX2-B | 1200 – 1800 | TT | 10 | 001 | 10 | XX |
RX2-B | 1800 – 2350 | TT | 10 | 011 | 11 | XX |
RX2-B | 2350 – 2600 | TT | 10 | 101 | 01 | XX |
RX2-B | >= 2600 | TT | 01 | XXX | XX | XX |
Transmit
TX Port | TX Filter (MHz) | VCTXRX1_V1,V2 | TX_ENABLE1A,1B | TX1_BANDSEL[2:0] |
TRX-B | < 117.7 | 00 | 01 | 111 |
TRX-B | 117.7 – 178.2 | 00 | 01 | 110 |
TRX-B | 178.2 – 284.3 | 00 | 01 | 101 |
TRX-B | 284.3 – 453.7 | 00 | 01 | 100 |
TRX-B | 453.7 – 723.8 | 00 | 01 | 011 |
TRX-B | 723.8 – 1154.9 | 00 | 01 | 010 |
TRX-B | 1154.9 – 1842.6 | 00 | 01 | 001 |
TRX-B | 1842.6 – 2940.0 | 00 | 01 | 000 |
TRX-B | >= 2940.0 | 11 | 10 | XXX |
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
E310
- Required version on the host computer must match what is running on the E310
E312
- Minimum version of UHD required: 3.8.5
- Required version on the host computer must match what is running on the E312
Dimensions
- 133 x 68 x 26.4 mm
- E310 0-40 °C
- E312 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
E310
Motherboard | ||
TXS02612RTWR | SDIO PORT EXPANDER | U23 (2) |
XC7Z020-1CLG484CES9919 | FPGA | U11 (2,3,4,8,11,13) |
Xilinx Zynq Product Page | FPGA | - |
USB3340-EZK-TR | ULPI Transceiver | U33 (5) |
AK4571VQP | Audio CODEC | U30 (6) |
FT230XQ-R | UART Interface | U32 (6) |
88E1512 | Gigabit Ethernet Transceiver | U13 (7) |
24LC024/SN | EEPROM | U5 (9) |
DS1339,SM | Real-Time Clock | U6 (9) |
ADT7408 | Temperature Sensor | U8 (9) |
MPU-9150 | Motion Processing Unit | U3 (9) |
InvenSense MPU-9150 Product Page | Motion Processing Unit | U3 (9) |
BMP180 | Digital pressure sensor | U4 (9) |
BQ24192 | Adapter Charger | U1 (10) |
TPS54478 | Step-Down Switcher | U20 (10) |
MAX6510HAUT-T | Temperature Switches | U35 (10) |
ATTINY88-MU | Microcontroller | U18 (10) |
TPS61253YFF | Step-Up Converter | U19 (10) |
AMY-6M | GPS Module | U12 (6) |
Daughterboard | ||
AD9361 Product Page | 2 x 2 RF Agile Transceiver | U8 (3) |
24AA256 | EEPROM | U15 (2) |
TC-1-43A+ | RF Transformer | T6 (3); T5 (3); T4 (3) |
TC1-1-13M+ | RF Transformer | T7 (3); T10 (3); T1 (3) |
TPS62140 | Step-Down Converter | U19 (4) |
ADP1753ACPZ-R7 | Linear Regulator | U17 (4); U18 (4) |
SGA-4563Z | MMIC AMPLIFIER | U12 (5); U4 (5) |
SKY13418-485LF | Antenna Switch | U13 (5); U3 (5); U16 (5); U2 (5); U10 (6); U5 (6) |
SKY13373-460LF | SP3T Switch | U11 (6); U9 (6); U6 (6); U7 (6); SW4 (7); SW1 (7) |
MGA-81563 | Amplifier | U14 (5); U1 (5) |
LFCN-5850+ | Low Pass Filter | FL32 (5); FL1 (5) |
LFCN-2750+ | Low Pass Filter | FL37 (5); FL4 (5) |
LFCN-2250+ | Low Pass Filter | FL23 (6); FL20 (6) |
LFCN-1700+ | Low Pass Filter | FL40 (5); FL2 (5) |
LFCN-1575+ | Low Pass Filter | FL25 (6); FL17 (6) |
LFCN-1000+ | Low Pass Filter | FL33 (5); FL9 (5); FL27 (6); FL15 (6) |
LFCN-575+ | Low Pass Filter | FL36 (5); FL5 (5) |
LFCN-530+ | Low Pass Filter | FL29 (6); FL13 (6) |
LFCN-400+ | Low Pass Filter | FL38 (5); FL3 (5); FL30 (6); FL11 (6) |
LFCN-225 | Low Pass Filter | FL39 (5); FL6 (5) |
LFCN-160+ | Low Pass Filter | FL34 (5); FL8 (5) |
LFCN-80+ | Low Pass Filter | FL35 (5); FL7 (5) |
HFCN-1600+ | High Pass Filter | FL22 (6); FL19 (6) |
HFCN-1100+ | High Pass Filter | FL24 (6); FL16 (6) |
HFCN-650+ | High Pass Filter | FL26 (6); FL14 (6) |
HFCN-440+ | High Pass Filter | FL28 (6); FL12 (6) |
BFCN-2435+ | Bandpass Filter | FL21 (6); FL18 (6) |
FDG6301N | Dual N-Channel, Digital FET | Q8 (7); Q5 (7) |
HSMS-8202 | Mixer Diodes | CR1 (7); CR2 (7); CR3 (7); CR4 (7) |
LP5900TL | Linear Regulator | U25 (8) |
ADP150AUJZ-3.0 | Linear Regulator | U22 (8) |
AD5662RBJ | 16-Bit nanoDAC | U21 (8) |
SN74AUP1T57 | Voltage Translator | U27 (8); U28 (8); U29 (8) |
Request a detailed whitepaper covering features and components from info@ettus.com
Weight
- Partial Enclosure 225 g
- Full Enclosure 375 g
Drawings
E310
- File:E310 Dimensional Sketches.pdf
- File:cu e310 motherboard cca.pdf
- File:cu E310 daughtercard cca.pdf
- File:cu usrp-e310.pdf
E312
FPGA
E310/E312
1. Slice Logic -------------- +----------------------------+-------+-----------+-------+ | Site Type | Used | Available | Util% | +----------------------------+-------+-----------+-------+ | Slice LUTs | 36203 | 53200 | 68.05 | | LUT as Logic | 28108 | 53200 | 52.83 | | LUT as Memory | 8095 | 17400 | 46.52 | | LUT as Distributed RAM | 870 | | | | LUT as Shift Register | 7225 | | | | Slice Registers | 36562 | 106400 | 34.36 | | Register as Flip Flop | 36562 | 106400 | 34.36 | | Register as Latch | 0 | 106400 | 0.00 | | F7 Muxes | 376 | 26600 | 1.41 | | F8 Muxes | 125 | 13300 | 0.93 | +----------------------------+-------+-----------+-------+ 3. Memory --------- +-------------------+------+-----------+-------+ | Site Type | Used | Available | Util% | +-------------------+------+-----------+-------+ | Block RAM Tile | 97 | 140 | 69.28 | | RAMB36/FIFO* | 90 | 140 | 64.28 | | RAMB36E1 only | 90 | | | | RAMB18 | 14 | 280 | 5.00 | | RAMB18E1 only | 14 | | | +-------------------+------+-----------+-------+ * Note: Each Block RAM Tile only has one FIFO logic available and therefore can accommodate only one FIFO36E1 or one FIFO18E1. However, if a FIFO18E1 occupies a Block RAM Tile, that tile can still accommodate a RAMB18E1 4. DSP ------ +----------------+------+-----------+-------+ | Site Type | Used | Available | Util% | +----------------+------+-----------+-------+ | DSPs | 120 | 220 | 54.54 | | DSP48E1 only | 120 | | | +----------------+------+-----------+-------+
- 10/100/1000 BASE-T Ethernet
- Stereo audio out, mono mic in
- Integrated GPS receiver
- Host USB support
- 9-axis IMU
Front Panel
Rear Panel
GPIO
Pin Mapping
- Please see the E3x0/X3x0 GPIO API for information on configuring and using the GPIO bus.
Audio
E312 Battery
The USRP E312 is equipped with an integrated 3.7V, 3200mAh lithiumion battery cell. After unboxing the USRP E312 , plug in the power adapter to an AC power source and fully charge the battery. This process with take approximately 2 hours. Do not leave the USRP E312 unit plugged in for more than 24 hours.
The status LED in the power button indicates the power and charge status of the battery:
Off: Indicates device is off and not charging.
- Slow Blinking Green: Indicates device is off and charging.
- Fast Blinking Green: Indicates device is on and charging.
- Solid Green: Indicates device is on and not charging (Battery is finished charging).
- Solid Orange: Indicates device is on and discharging.
- Fast Blinking Orange: Indicates device is on, discharging, and charge is below 10% charge.
- Fast Blinking Red: Indicates an error code:
- Low Voltage Error
- Regulator Low Voltage Error
- FPGA Power Error
- DRAM Power Error
- 1.8V Power Rail Error
- 3.3V Power Rail Error
- Daughterboard / TX Power Error
- Charger Error
- Charger Temperature Error
- Battery Low Error
- Fuel Gauge Temperature Error
- Global (Enclosure) Temperature Error
The battery life of the USRP E312 in idle mode is approximately 5 1/2 hours. The battery will enable the USRP E312 to operate for approximately 2 hours 20 minutes, when transmitting and receiving on both channels (2x2 MIMO), with maximum gain settings, at 5 GHz center frequency, and 1 MS/s sample rate. When the power button status LED is in the “Fast Blinking Orange” mode, plug the USRP E312 into an AC power source as soon as possible to recharge the battery.
If the power button status LED indicates a “Low Voltage Error” (codes 1, 2, 3, 4, 5, 6, 7) or a “Battery Low Error” (code 10), plug the USRP E312 into an AC power source as soon as possible to recharge the battery.
When the power button status LED indicates at “Temperature Error” or “Charger Error” (codes 8, 9, 11, or 12), power off the USRP E312 unit and allow it to cool down to room temperature. Then, plug in the USRP E312 to and AC power source and fully charge the battery.
If error codes persist after cooling down and/or recharging the USRP E312, please contact support@ettus.com.
You can purchase a replacement battery for the E312 at https://www.ettus.com/product/details/E312-battery.
An Application Note covering the replacement of the E312 battery can be found at USRP E312 Battery Replacement Instructions.
E310
E312
SD Card Images
This folder linked above contains SD card images and the SDK (OE cross-compiler build environment) for the USRP E310 and E312. There is a manifest file that shows which packages, and which versions, are included in the OE build within each folder.
The "alpha
", "beta
", "e3xx-release-001
", "e310-release-002
", "e3xx-release-3
" folders contain older versions which are currently obsolete. We do not suggest that customers use these files. These versions are no longer supported. They are provided here for archival purposes only.
The current version is Release 4, which located in the "e3xx-release-4
" folder. We recommend the customers use this version. It is fine if you are already successfully using an older version, but at some point it is recommended that you upgrade to this current version so that you benefit from the latest bug fixes, new features, stability improvements, and other enhancements.
The Release 4 image includes UHD 3.9.2 and GNU Radio 3.7.9, and also includes the corresponding FPGA image file.
Note: An 8 GB SD card is required for the Release 4 image.
The SD card image contains both the FPGA image and the OS for the E310/E312. The FPGA images are located in the file system of the E310/E312 in the /usr/local/share/uhd/images
folder.
There are two SD card image files for each version of the image, which include the text "-dev
" and "-demo
" in the filename. The "-dev
" flavor lacks some graphical packages, such as X Windows and QT, which the "-demo
" flavor includes. The two flavors are otherwise functionally equivalent, although the "-demo
" flavor takes some additional space on the SD card and some additional memory to run.
The Release 4 image comes in two varieties. The variety that you will need depends on the product number of your E310 or E312, which is printed on the bottom of the device.
For the E310, the product number will be 156333X-01L
, where X is a letter from A to Z. For devices where X is A, B, C, D, the images under the "ettus-e3xx-sg1
" folder should be used. For devices where X is E or later, the images under the "ettus-e3xx-sg3
" folder should be used. You must use the appropriate image for your specific device. The incorrect image will not work, and will only boot as far as the U-Boot boot loader before stopping.
For the E312, the product number will be 140605X-01L
, where X is a letter from A to Z. The images under the "ettus-e3xx-sg3
" folder should be used for all E312 devices.
You can burn the image to an SD card using either the "dd
" or the "bmaptool
" tool. Instructions on how to use these tools are at the links below.
The SD image files have an *.xz extension, as they are compressed using the LZMA/LZMA2 compression algorithms. You can uncompress these files with tools such as 7-Zip and the XZ Utils. Please see the links below for further information.
7-Zip
XZ Utils
The folder structure is listed below.
. |-- alpha | |-- dizzy-test | | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest | | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh | | |-- sdimage-gnuradio-demo.direct.xz | | `-- sdimage-gnuradio-dev.direct.xz | |-- fido-rfnoc-test | | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest | | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh | | |-- sdimage-gnuradio-demo.direct.xz | | |-- sdimage-gnuradio-demo.direct.xz.md5 | | |-- sdimage-gnuradio-dev.direct.xz | | `-- sdimage-gnuradio-dev.direct.xz.md5 | |-- fido-test | | |-- ettus-e3xx-sg1 | | | |-- sdimage-gnuradio-demo.direct.xz | | | |-- sdimage-gnuradio-demo.direct.xz.md5 | | | |-- sdimage-gnuradio-dev.direct.xz | | | `-- sdimage-gnuradio-dev.direct.xz.md5 | | |-- ettus-e3xx-sg3 | | | |-- sdimage-gnuradio-demo.direct.xz | | | |-- sdimage-gnuradio-demo.direct.xz.md5 | | | |-- sdimage-gnuradio-dev.direct.xz | | | `-- sdimage-gnuradio-dev.direct.xz.md5 | | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest | | `-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh | `-- fosphor-testing | |-- fosphor.direct.xz | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.host.manifest | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.target.manifest | |-- sdimage-gnuradio-demo.direct.xz | |-- sdimage-gnuradio-demo.direct.xz.md5 | |-- sdimage-gnuradio-dev.direct.xz | `-- sdimage-gnuradio-dev.direct.xz.md5 |-- beta | |-- dizzy-test | | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest | | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh | | |-- sdimage-gnuradio-demo.direct.xz | | `-- sdimage-gnuradio-dev.direct.xz | `-- dizzy-test-wifi | `-- sdimage-gnuradio-dev.direct.xz |-- e310-release-002 | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh | |-- sdimage-gnuradio-demo.direct.xz | |-- sdimage-gnuradio-demo.direct.xz.md5sum | |-- sdimage-gnuradio-dev.direct.xz | `-- sdimage-gnuradio-dev.direct.xz.md5sum |-- e3xx-release-001 | |-- e300-gnuradio-dev-image-release1.bz | `-- nodistro-eglibc-x86_64-gnuradio-dev-image-armv7ahf-vfp-neon-toolchain-nodistro.0.sh |-- e3xx-release-3 | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest | |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh | |-- sdimage-gnuradio-demo.direct.xz | `-- sdimage-gnuradio-dev.direct.xz `-- e3xx-release-4 |-- ettus-e3xx-sg1 | |-- sdimage-gnuradio-demo.direct.xz | |-- sdimage-gnuradio-demo.direct.xz.md5 | |-- sdimage-gnuradio-dev.direct.xz | `-- sdimage-gnuradio-dev.direct.xz.md5 |-- ettus-e3xx-sg3 | |-- sdimage-gnuradio-demo.direct.xz | |-- sdimage-gnuradio-demo.direct.xz.md5 | |-- sdimage-gnuradio-dev.direct.xz | `-- sdimage-gnuradio-dev.direct.xz.md5 |-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.manifest `-- oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
