E320
[hide]Device Overview
The USRP E320 brings performance to embedded software defined radios by offering four times more FPGA resources compared to the USRP E31x devices. The USRP E320 also introduces improvements in streaming, synchronization, integration, fault-recovery, and remote management capability. This field deployable SDR continues to use the flexible 2x2 MIMO AD9361 transceiver from Analog Devices, which covers frequencies from 70 MHz – 6 GHz and provides up to 56 MHz of instantaneous bandwidth.
E320
RF Performance
- Power Output >10dBm
- IIP3 (@ typical NF) -20dBm
- Typical Receive Noise Figure <8dB
Input Power Levels
- The maximum input power for the E320 is -15 dBm.
Hardware Specifications
- UHD version on the host computer must match what is running on the E320
E320
- Minimum version of UHD required: 3.14.0.0
Physical Specifications
Dimensions
E320 board-only with heatsink
- 173 x 100 x 36 mm
E320 Full enclosure
- 175 x 106 x 38 mm
Environmental Specifications
- 0-45 °C
Non-Operating Temperature Range
- -40-85 °C
Operating Humidity Range
- 10% to 90% non-condensing
Non-Operating Humidity Range
- 5% to 95% non-condensing
Mechanical Information
Weight
- 0.16 kg
E320 Full enclosure
- 0.86 kg
Frontend Specifications
Tuning
Gains
Interfaces and Connectivity
- RJ45 (1 GbE)
- SFP+ (1/10 GbE, Aurora)
- Type A USB Host
- Micro-USB (serial console, JTAG)
- GPIO
- Integrated GPSDO
- 9-axis IMU
Front Panel
Rear Panel
Power Connector
Model: PDP-40 by CUI Inc.
Power plug connectors for custom power harnesses can be purchased here: https://www.digikey.com/products/en?KeyWords=CP-7340-ND&WT.z_cid=sp_102_buynow
Assembly instructions: Media:pdp-40.pdf
Pin Detail
- Pins #1 / #2: 12v
- Pins #3 / #4: Ground
China RoHS
Chinese Customers
