E320
- 1 Device Overview
- 2 Key Features
- 3 RF Specifications
- 4 Hardware Specifications
- 5 Physical Specifications
- 7 Mechanical Information
- 8 Frontend Specifications
- 9 Interfaces and Connectivity
- 10 Guidance on SFP+ Adapters for Fiber Connectivity on USRP N310
- 11 Guidance on 10Gb SFP+ to RJ45 Adapters
- 12 Certifications
The USRP E320 brings performance to embedded software defined radios by offering four times more FPGA resources compared to the USRP E31x devices. The USRP E320 also introduces improvements in streaming, synchronization, integration, fault-recovery, and remote management capability. This field deployable SDR continues to use the flexible 2x2 MIMO AD9361 transceiver from Analog Devices, which covers frequencies from 70 MHz – 6 GHz and provides up to 56 MHz of instantaneous bandwidth.
E320
RF Performance
- Power Output >10dBm
- IIP3 (@ typical NF) -20dBm
- Typical Receive Noise Figure <8dB
Input Power Levels
- The maximum input power for the E320 is -15 dBm.
- UHD version on the host computer must match what is running on the E320
E320
- Minimum version of UHD required: 3.14.0.0
Dimensions
E320 board-only with heatsink
- 173 x 100 x 36 mm
E320 Full enclosure
- 175 x 106 x 38 mm
- 0-45 °C
Non-Operating Temperature Range
- -40-85 °C
Operating Humidity Range
- 10% to 90% non-condensing
Non-Operating Humidity Range
- 5% to 95% non-condensing
Weight
- 0.16 kg
E320 Full enclosure
- 0.86 kg
Tuning
Gains
- RJ45 (1 GbE)
- SFP+ (1/10 GbE, Aurora)
- Type A USB Host
- Micro-USB (serial console, JTAG)
- GPIO
- Integrated GPSDO
- 9-axis IMU
Front Panel
Rear Panel
Power Connector
Model: PDP-40 by CUI Inc.
Power plug connectors for custom power harnesses can be purchased here: https://www.digikey.com/products/en?KeyWords=CP-7340-ND&WT.z_cid=sp_102_buynow
Assembly instructions: Media:pdp-40.pdf
Pin Detail
- Pins #1 / #2: 12v
- Pins #3 / #4: Ground
Ettus Research currently offers direct-connect, copper cabling accessories for the USRP E320. However, it is also possible to use multi-mode fiber instead of copper connections for these devices. In this section, we will provide general guidance on the types of fiber adapters and cables that can be used with these products.
The USRP E320 USRP is compatible with most brands of SFP+ fiber adapters. In some cases, other equipment in the systems such as 1/10 Gigabit Ethernet switches are only compatible with specific brands of SFP+ adapters and cables. As a general rule, we recommend checking compatibility with the switches and network cards in your system before purchasing an adapter.
Ettus Research does test the USRP E320 USRP devices with our 10 Gigabit Ethernet Connectivity Kit and a Blade Networks G8124 1/10 GigE switch. Here are is a list of known-good cables and adapters.
Known-Good Adapters
Known-Good Cables
Known-Good Adapters
China RoHS
Chinese Customers
