USRP N300/N310/N320/N321 Getting Started Guide
Revision as of 14:17, 18 June 2020 by MichaelDickens (Talk | contribs) (set MTU to 9000 per UHD 3.15 requirements)
Kit Contents
N300
  • USRP N300
  • DC Power Supply (12V, 7A)
  • 1 RJ45 – SFP+ Adapter
  • 1 Gigabit Ethernet Cat-5e Cable (3m)
  • Getting Started Guide
  • Ettus Research Sticker
N310
  • USRP N310
N320
  • USRP N320
N321
  • USRP N321
You Will Need
  • microSD Card Writer
  • For Network Mode: A host computer with an available 1 or 10 Gigabit Ethernet interface for sample streaming. In addition to the Ethernet interface used for sampling streaming, your host computer will require a separate 1 Gigabit Ethernet interface for command and control streaming.
  • For Stand-Alone Embedded Mode: A host computer with an available 1 Gigabit Ethernet port or a USB 2.0 port to remotely access the embedded Linux operating system running on ARM CPU.
Proper Care and Handling
In order to use your Universal Software Radio Peripheral (USRP™), you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows Application Notes.
To find the latest release of UHD, see the UHD repository at https://github.com/EttusResearch/uhd.
The USRP N310 requires UHD version 3.11.0.0 or later.
The USRP N300 requires UHD version 3.12.0.0 or later.
The USRP N320/N321 requires UHD version 3.14.0.0 or later.
White Rabbit Ethernet-Based Synchronization of the N3xx USRP requires UHD version 3.12.0.0 or later. For additional details on White Rabbit Ethernet-Based Synchronization, please see the application note, Using Ethernet-Based Synchronization on the USRP™ N3xx Devices.
When you receive a brand-new device, it is strongly recommended that you download the most recent filesystem image from the Ettus Research website and write it to the SD card that comes with the unit. It is not recommended that you use the SD card from the factory as-is. Instructions on downloading the latest filesystem image and writing it to the SD card are listed below.
Note that if you are operating the device in Network Mode, the version of UHD running on the host computer and the USRP N3xx must match.
Connecting the Device
Interfaces Overview
Listed below are the interfaces to connect to the USRP N3xx. Each interface has specific functionality, limitations and purpose.
Serial Console
The Serial Console provides a low level interface to the device typically used for debugging.
1 Gigabit RJ45 Connection
The 1 Gigabit RJ45 Connection interfaces with the on-board ARM CPU. When operated in "Network mode", this interface can optionally be used for UHD management traffic. Regardless of the operation mode (Network vs Embedded) this interface can be used to connect to the ARM via SSH. By default, the 1Gb RJ45 connection is configured to use a DHCP assigned IP address.
Dual SFP+ Connections
The Dual SFP+ Connections support multiple configurations for streaming high-speed, low-latency data, depending upon the FPGA image which is loaded.
QSFP+ Connection (N320/ N321 Only)
The QSFP+ Connection supports 2 x 10Gb lanes for streaming high-speed, low-latency data, while the onboard SFP0 connection is used for White Rabbit Ethernet-Based Synchronization.
It is possible to gain shell access to the device using a serial terminal emulator via the Serial Console port. Most Linux, OSX, or other Unix based operating systems have a tool called screen which can be used for this purpose.
If you do not have screen installed, it can be installed via your package manager. For Ubuntu/Debian based operating systems it can be installed with apt such as:
   sudo apt install screen
   $ ls /dev/serial/by-id
   usb-Digilent_Digilent_USB_Device_25163511FE00-if00-port0
   usb-Digilent_Digilent_USB_Device_25163511FE00-if01-port0
   usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if00-port0
   usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6CB5-if01-port0
Every N3XX series device connected to USB will by default show up as four different devices. The devices labeled "USB_to_UART_Bridge_Controller" are the devices that offer a serial prompt. The first (with the if00 suffix) connects to the ARM CPU, whereas the second connects to the STM32 Microcontroller.
If you have multiple N3xx Serial Consoles connected to a single host, you may have to empirically test nodes.
Upon starting the USRP N3xx, boot messages will appear and rapidly update. Once the boot process successfully completes, a login prompt like the following should appear:
   OpenEmbedded test ni-n3xx-313ABDA ttyPS0
   ni-n3xx-313ABDA login:
Enter the username: ​root​
   root@ni-n3xx-<motherboard serial #>:~#
Using the default configuration, the serial console will show all kernel log messages (which are not available when using SSH), and give access to the boot loader (U-boot prompt). This can be used to debug kernel or boot-loader issues more efficiently than when logged in via SSH.
Using the Serial Console interface, it is possible to connect to the STM32 microcontroller with the command below. The STM32 controls the power sequencing and several other low level device operations.
Connecting to the ARM via SSH
By default, the RJ45 1Gb management interface is configured to be assigned a DHCP IP address.
If you have access to a network which provides a DHCP server (such as a common router's LAN), attach the RJ45 1Gb port to this network. Details vary by vendor, however, most router management interfaces will provide a list of attached devices to the LAN including their IP address.
Example Output:
# ip a
3: sfp0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 9000 qdisc pfifo_fast qlen 1000
4: sfp1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 9000 qdisc pfifo_fast qlen 1000
   $ sudo dnsmasq -i <ETHERNET_ADAPTER_NAME> --dhcp-range=192.168.1.151,192.168.1.254 --except-interface=lo --bind-dynamic --no-daemon
After the device has obtained an IP address, you can remotely log into it from a Linux or macOS system with SSH, as shown below:
   $ ssh [email protected]
NOTE: The root password default password is empty/blank.
On Microsoft Windows, the SSH connection can be established using the third-party program ​Putty​.
After logging in, you should be presented with a shell like the following:
Updating the Linux File System
Before operating the device, it is​ ​strongly​ recommended to update to the latest version of the Embedded Linux file system. If you are operating the device in Network Mode, the version of UHD running on the host machine and N3xx USRP must match.
There is two ways to update the file system for the N3xx USRP:
1. Mender
File System Partition Layout
The SD Card is divided into four partitions. There is two root file system partitions, a boot partition and a data partition.
Any data you would like to preserve through Mender updates should be saved to the data partition, which is mounted at /data.
Updating the file system with Mender
Mender is third-party software that enables remote updating of the root file system without physically accessing the device (see also the Mender website https://mender.io). Mender can be executed locally on the device, or a Mender server can be set up which can be used to remotely update an arbitrary number of USRP devices. Users can host their own local Mender server, or use servers hosted by Mender as a paid service; contact Mender for more information.
Mender Update Process
   $ sudo uhd_images_downloader -t mender -t n3xx --yes
Example Output:
   451639 kB / 451639 kB (100%) n3xx_common_mender_default-v3.14.0.0.zip
Next, you will need to copy this Mender file system image to the USRP N3xx. This can be done with the Linux utility scp.
   $ scp /usr/local/share/uhd/images/usrp_n3xx_fs.mender [email protected]:~/.
Note: The path and IP may different for your configuration, the command above assumes you're using the default installation path of /usr/local and that the N3xx's IP is 192.168.1.51.
After copying the Mender file system image to the N3xx, connect to the N3xx using either the Serial Console, or via SSH to gain shell access.
On the N3xx, run mender -rootfs /path/to/latest.mender to update the file system:
   root@ni-n3xx-serial:~# mender -rootfs /home/root/usrp_n3xx_fs.mender
Example Output:
INFO[0000] Configuration file does not exist: /var/lib/mender/mender.conf  module=config
INFO[0000] Loaded configuration file: /etc/mender/mender.conf  module=config
INFO[0000] Mender running on partition: /dev/mmcblk0p2   module=main
INFO[0000] Start updating from local image file: [/home/root/usrp_n3xx_fs.mender]  module=rootfs
Installing update from the artifact of size 460989952
INFO[0000] no public key was provided for authenticating the artifact  module=installer
INFO[0000] opening device /dev/mmcblk0p3 for writing     module=block_device
INFO[0000] partition /dev/mmcblk0p3 size: 7851737088     module=block_device
................................   0% 1024 KiB
................................   0% 2048 KiB
................................   0% 3072 KiB
[truncated for readability]
................................  99% 448512 KiB
................................  99% 449536 KiB
................................ 100% 450185 KiB
INFO[3004] wrote 7851737088/7851737088 bytes of update to device /dev/mmcblk0p3  module=device
INFO[3009] Enabling partition with new image installed to be a boot candidate: 3  module=device
   $ mender -rootfs http://server.name/path/to/latest.mender
   $ reboot
   $ mender -commit
To identify the currently installed Mender artifact from the command line, the following file can be queried on the N3xx:
If you are using a Mender server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and you can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is a simple way to update groups of rack-mounted USRPs with custom file systems.
For more information on updating the file-system, refer to the UHD Manual at ​https://uhd.ettus.com.
Updating the files system by writing the disk image
Please see the separate application note, Writing the USRP File System Disk Image to a SD Card, for step-by-step instructions on writing the file system image to the SD card.
The USRP N3xx systemd network configuration files are located at: /etc/systemd/network/
   # ls /etc/systemd/network/
   eth0.network  sfp0.network  sfp1.network
eth0 (DHCP):
    [Match]
    Name=eth0
    [Network]
    DHCP=ipv4
    [DHCP]
    UseHostname=false
sfp0 (static):
    [Match]
    Name=sfp0
    [Network]
    Address=192.168.10.2/24
    [Link]
    MTUBytes=9000
sfp1 (static):
    [Match]
    Name=sfp1
    [Network]
    Address=192.168.20.2/24
    [Link]
    MTUBytes=9000
  • Streaming via SFP0 at 1 Gb rates requires a MTU of 1500
  • Streaming via SFP0 at 10 Gb rates requires a MTU of 9000
For addition details on network configuration here: https://files.ettus.com/manual/page_usrp_n3xx.html#n3xx_network_configuration
Updating the FPGA Image
Network Mode FPGA Image Update
The FPGA image should match the version of UHD installed on the host computer, when operated in Network mode. Connect the device to the host computer using either the RJ45 or SFP+ port, refer to the section above for detailed instructions.
To obtain all the FPGA images for a specific version of UHD, run the following command on the host computer with internet access:
Example Output:
   00006 kB / 00006 kB (100%) usrp1_b100_fw_default-g6bea23d.zip
   19810 kB / 19810 kB (100%) x3xx_x310_fpga_default-gf1ba32fe.zip
   02757 kB / 02757 kB (100%) usrp2_n210_fpga_default-g6bea23d.zip
   02123 kB / 02123 kB (100%) n230_n230_fpga_default-ge57dfe0.zip
   00522 kB / 00522 kB (100%) usrp1_b100_fpga_default-g6bea23d.zip
   00491 kB / 00491 kB (100%) b2xx_b200_fpga_default-ge57dfe0.zip
   02415 kB / 02415 kB (100%) usrp2_n200_fpga_default-g6bea23d.zip
   08988 kB / 08988 kB (100%) e3xx_e320_fpga_default-g3de8954a.zip
   23045 kB / 23045 kB (100%) n3xx_n310_fpga_default-g3de8954a.zip
   00523 kB / 00523 kB (100%) b2xx_b205mini_fpga_default-ge57dfe0.zip
   18937 kB / 18937 kB (100%) x3xx_x300_fpga_default-gf1ba32fe.zip
   00017 kB / 00017 kB (100%) octoclock_octoclock_fw_default-g14000041.zip
   00007 kB / 00007 kB (100%) usrp2_usrp2_fw_default-g6bea23d.zip
   00009 kB / 00009 kB (100%) usrp2_n200_fw_default-g6bea23d.zip
   00450 kB / 00450 kB (100%) usrp2_usrp2_fpga_default-g6bea23d.zip
   00144 kB / 00144 kB (100%) b2xx_common_fw_default-ga69ab0c.zip
   25107 kB / 25107 kB (100%) n3xx_n320_fpga_default-g3de8954a.zip
   00464 kB / 00464 kB (100%) b2xx_b200mini_fpga_default-ge57dfe0.zip
   00319 kB / 00319 kB (100%) usrp1_usrp1_fpga_default-g6bea23d.zip
   04839 kB / 04839 kB (100%) usb_common_windrv_default-g14000041.zip
   00009 kB / 00009 kB (100%) usrp2_n210_fw_default-g6bea23d.zip
   16065 kB / 16065 kB (100%) n3xx_n300_fpga_default-g3de8954a.zip
   05578 kB / 05578 kB (100%) e3xx_e310_fpga_default-g4bc2c6f.zip
   00885 kB / 00885 kB (100%) b2xx_b210_fpga_default-ge57dfe0.zip
NOTE: In the above example output, the Images Destination folder is printed:
To list the N3xx FPGA images with a full path, run the command:
   $ ls -w 1 /usr/local/share/uhd/images/usrp_n3*.bit
   /usr/local/share/uhd/images/usrp_n300_fpga_AA.bit
   /usr/local/share/uhd/images/usrp_n300_fpga_HG.bit
   /usr/local/share/uhd/images/usrp_n300_fpga_WX.bit
   /usr/local/share/uhd/images/usrp_n300_fpga_XG.bit
   /usr/local/share/uhd/images/usrp_n310_fpga_AA.bit
   /usr/local/share/uhd/images/usrp_n310_fpga_HG.bit
   /usr/local/share/uhd/images/usrp_n310_fpga_WX.bit
   /usr/local/share/uhd/images/usrp_n310_fpga_XG.bit
   /usr/local/share/uhd/images/usrp_n320_fpga_AQ.bit
   /usr/local/share/uhd/images/usrp_n320_fpga_HG.bit
   /usr/local/share/uhd/images/usrp_n320_fpga_WX.bit
   /usr/local/share/uhd/images/usrp_n320_fpga_XG.bit
   /usr/local/share/uhd/images/usrp_n320_fpga_XQ.bit
To update the default HG variant of FPGA image, run the command:
   $ uhd_image_loader --args "type=n3xx,addr=<N3xx_IP_ADDR>,fpga=HG"
Example Output:
   uhd_image_loader --args "type=n3xx,addr=192.168.1.151,fpga=HG"
   [INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.11.1.HEAD-0-gad6b0935
   [INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.151,type=n3xx,product=n310,serial=313ABDA,claimed=False,skip_init=1
   [INFO] [MPM.main] Launching USRP/MPM, version: 3.11.1.0-gunknown
   [INFO] [MPM.main] Spawning RPC process...
   [INFO] [MPM.PeriphManager] Device serial number: 313ABDA
   [INFO] [MPM.PeriphManager] Found 2 daughterboard(s).
   [INFO] [MPM.RPCServer] RPC server ready!
   [INFO] [MPM.RPCServer] Spawning watchdog task...
To load a different default FPGA image (i.e. XG, WG), modify the device argument fpga= to a value of fpga=XG or fpga=WG.
   $ uhd_image_loader --args "type=n3xx,addr=<N3xx_IP_ADDR>" --fpga-path=/path/to/custom/fpga.bit
The Verilog code for the FPGA in the USRP N3xx is open-source, and users are free to modify and customize it for their needs. However, certain modifications may result in either bricking the device, or even in physical damage to the unit. Please note that modifications to the FPGA are made at the risk of the user, and may not be covered by the warranty of the device.
It is possible to update the FPGA image when operated in Embedded mode. Connect to the ARM CPU via Serial Console or SSH as detailed in the section above.
Updating the FPGA image from the ARM CPU is the same as detailed above for a Network mode update, except it is not required to provide an addr device argument.
   uhd_image_loader --args "type=n3xx,fpga=HG"
root@ni-n3xx-313ABDA:~# uhd_image_loader --args "type=n3xx,fpga=HG"
[INFO] [UHD] linux; GNU C++ version 7.2.0; Boost_106400; UHD_3.11.1.0-0-unknown
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=127.0.0.1,type=n3xx,product=n310,serial=313ABDA,claimed=False,skip_init=1
For more information on updating the FPGA image, refer to the UHD Manual at http://uhd.ettus.com .
The device supports multiple, high-speed, low-latency interfaces on the SFP+ ports for streaming samples to the host computer.
1Gb Streaming SFP Port 0
Complete the steps below to set up a streaming connection over the 1 Gigabit Ethernet interface on SFP Port 0.
When streaming via SFP Port 0 at 1 Gb speeds, it is important that the connection is direct between the Host and USRP. Placing a switch or other network gear between the Host and USRP can reduce throughput of the transport link. It is also generally recommended to avoid using USB to Ethernet Adapters for the high speed streaming interface, as they may limit performance or cause periodic flow control errors.
NOTE: The HG FPGA image must be loaded for SFP Port 0 to operate at 1Gb speeds. If the XG image is loaded, the port will be unresponsive at 1Gb speeds.
1. Configure your Host's Ethernet adapter as shown below. This interface should be separate from the 1Gb NIC/network which is connected to the 1Gb RJ45 management interface.
   IP Address: 192.168.10.1
   Subnet Mask: 255.255.255.0
   Gateway: 0.0.0.0
   MTU: 1500
NOTE: When operating SFP Port 0 at 1Gb speeds, it is important to set a MTU of 1500 and not a value of automatic.
2. Insert the ​ RJ45 – SFP+ adapter ​into​ SFP Port 0​ .
3. Connect the adapter to a host computer using the Ethernet cable to SFP0.
The ​ Green LED​ above ​SFP Port 0​ should illuminate.
   $ ping 192.168.10.2
   ^C
Proceed to the next section "Verifying Device Operation".
10Gb Streaming SFP Port 1
Complete the steps below to set up a streaming connection over the 10 Gigabit Ethernet interface on SFP Port 1.
NOTE: Both the HG and XG FPGA images support 10Gb speeds over SFP Port 1.
1. Configure your Host's 10Gb Ethernet adapter as shown below.
   IP Address: 192.168.20.1
   Gateway: 0.0.0.0
   MTU: 9000
NOTE: When operating at 10Gb speeds, it is important to set a MTU of 9000 and not a value of automatic.
2. Connect the USRP to a host computer using either a 10Gb SFP or Fiber cable to SFP Port 1.
The ​ Green LED​ above ​SFP Port 1​ should illuminate.
3. To test the connection,​ ​ping​ the device at address 192.168.20.2​ from the host, as shown below:
   $ ping 192.168.20.2
Dual 10Gb Streaming SFP Ports 0/1
Complete the steps below to set up a streaming connections over the Dual 10 Gigabit Ethernet interface on SFP Ports 0/1.
NOTE: The XG FPGA image must be loaded for SFP Port 0 to operate at 10 Gb speeds. If the HG image is loaded, the port will be unresponsive at 10 Gb speeds.
1. Configure your Host's #1 10Gb Ethernet adapter as shown below.
   Gateway: 0.0.0.0
   MTU: 9000
2. Configure your Host's #2 10Gb Ethernet adapter as shown below.
   Gateway: 0.0.0.0
   MTU: 9000
3. Connect the USRP to a host computer using either a 10Gb SFP or Fiber cables to SFP Ports 0/1.
The ​Green LEDs​ above ​SFP Ports 0/1​ should illuminate.
4. To test the SFP Port 0 connection,​ ​ping​ the device at address 192.168.10.2​ from the host, as shown below:
   $ ping 192.168.10.2
5. To test the SFP Port 1 connection,​ ​ping​ the device at address 192.168.20.2​ from the host, as shown below:
   $ ping 192.168.20.2
For more details on Network Setup and Configuration, please see the “Interfaces and Connectivity” section on the N300/N310 or N320/N321 hardware resources pages.
N300
The USRP N300 contains 2 channels, each represented on the front panel as RF0-1. Below is the subdev mapping of RF Ports.
  • RF0 = A:0
  • RF1 = A:1
N310
The USRP N310 contains 4 channels, each represented on the front panel as RF0-3. Below is the subdev mapping of RF Ports.
UHD 3.11.x.x - 3.12.x.x
  • RF0 = A:0
  • RF1 = B:0
  • RF2 = C:0
  • RF3 = D:0
UHD 3.13.x.x+
  • RF0 = A:0
  • RF1 = A:1
  • RF2 = B:0
  • RF3 = B:1
N320
The USRP N320 contains 2 channels, each represented on the front panel as RF0-1. Below is the subdev mapping of RF Ports.
  • RF0 = A:0
  • RF1 = B:0
N321
The USRP N321 contains 2 channels, each represented on the front panel as RF0-1. Below is the subdev mapping of RF Ports.
  • RF0 = A:0
  • RF1 = B:0
Supported Sample Rates
The USRP N300/N310 supports the three fixed Master Clock Rates listed below.
  • 122.88 MHz
  • 125.00 MHz
  • 153.60 MHz
The USRP N320/N321 supports the three fixed Master Clock Rates listed below.
  • 200.00 MHz
  • 245.76 MHz
  • 250.00 MHz
Example Sample Rates
Listed below are common sample rates for the given master clock rates. This is not a complete listing of the supported sample rates.
Master Clock Rate Decimation / Interpolation Rate
Host Sample Rate [Msps]
1 2 4 6 8 10 12 14 16 18 20 30 32 64 100 128 200 256 512 1024
122.88e6 61.44e6 30.72e6 20.48e6 15.36e6 12.288e6 10.24e6 8.7771e6 7.68e6 6.8267e6 6.144e6 4.096e6 3.84e6 1.92e6 1.2288e6 960e3 614.4e3 480e3 240e3 120e3
125e6 62.5e6 31.25e6 20.833e6 15.625e6 12.5e6 10.417e6 8.9286e6 7.8125e6 6.9444e6 6.25e6 4.1667e6 3.90625e6 1.953125e6 1.25e6 976.5625e3 625e3 488.28125e3 244.14e3 122.07e3
153.6e6 76.8e6 38.4e6 25.6e6 19.2e6 15.36e6 12.8e6 10.971e6 9.6e6 8.5333e6 7.68e6 5.12e6 4.8e6 2.4e6 1.536e6 1.2e6 768e3 600e3 300e3 150e3
N320/N321 Example Sample Rates
200e6 100e6 50e6 33.33e6 25e6 20e6 16.66e6 14.2857e6 12.5e6 11.11e6 10e6 6.667e6 6.25e6 3.125e6 2e6 1.5625e6 1e6 781.25e3 390.625e3 195.3125e3
245.76e6 122.88e6 61.44e6 30.72e6 20.48e6 15.36e6 12.288e6 10.24e6 8.7771e6 7.68e6 6.8267e6 6.144e6 4.096e6 3.84e6 1.92e6 1.2288e6 960e3 614.4e3 480e3 240e3
250e6 125e6 62.5e6 31.25e6 20.833e6 15.625e6 12.5e6 10.417e6 8.9286e6 7.8125e6 6.9444e6 6.25e6 4.1667e6 3.90625e6 1.953125e6 1.25e6 976.5625e3 625e3 488.28125e3 244.14e3
Probe the USRP
N300/N310
$  uhd_usrp_probe
[INFO] [UHD] linux; GNU C++ version 5.4.0 20160609; Boost_105800; UHD_3.13.1.HEAD-0-ga0a71d10
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.10.2,type=n3xx,product=n310,serial=313ABDA,claimed=False,addr=192.168.10.2
[INFO] [MPM.main] Launching USRP/MPM, version: 3.13.1.0-gd3b7e90a
[INFO] [MPM.PeriphManager] Initialized 2 daughterboard(s).
[INFO] [MPM.PeriphManager] init() called with device args `time_source=internal,clock_source=internal'.
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1355 MB/s)
[INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=192.168.10.2,clock_source=internal,time_source=internal,product=n310'.
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1358 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1345 MB/s)
[INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000011312)
[INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000011312)
[INFO] [0/DDC_1] Initializing block control (NOC ID: 0xDDC0000000000000)
[INFO] [0/DUC_1] Initializing block control (NOC ID: 0xD0C0000000000002)
|       Device: N300-Series Device
|   |       Mboard: ni-n3xx-313ABDA
|   |   eeprom_version: 1
|   |   mpm_version: 3.13.1.0-gd3b7e90a
|   |   pid: 16962
|   |   product: n310
|   |   rev: 3
|   |   serial: 313ABDA
|   |   type: n3xx
|   |   MPM Version: 1.2
|   |   FPGA Version: 5.2
|   |   RFNoC capable: Yes
|   |   Time sources:  internal, external, gpsdo, sfp0
|   |   Sensors: gps_tpv, ref_locked, gps_time, gps_locked, temp, gps_sky, fan
|   |   |       RX Dboard: A
|   |   |   |   Antennas: TX/RX, RX2, CAL, LOCAL
|   |   |   |   Sensors: lo_locked, ad9371_lo_locked, lowband_lo_locked
|   |   |   |   Freq range: 1.000 to 6000.000 MHz
|   |   |   |   Gain range all: 0.0 to 75.0 step 0.5 dB
|   |   |   |   Gain range rfic: 0.0 to 0.0 step 0.0 dB
|   |   |   |   Gain range dsa: 0.0 to 0.0 step 0.0 dB
|   |   |   |   Gain range amp: 0.0 to 0.0 step 0.0 dB
|   |   |   |   Bandwidth range: 20000000.0 to 100000000.0 step 0.0 Hz
|   |   |   |       RX Frontend: 1
|   |   |   |   Name: AD9371 Dual ADC
|   |   |       RX Dboard: B
|   |   |   |       RX Frontend: 1
|   |   |       TX Dboard: A
|   |   |   |   Gain range all: 0.0 to 65.0 step 0.5 dB
|   |   |   |       TX Frontend: 1
|   |   |   |   Name: AD9371 Dual DAC
|   |   |       TX Dboard: B
|   |   |   |       TX Frontend: 1
|   |   |   * DmaFIFO_0
|   |   |   * Radio_0
|   |   |   * Radio_1
|   |   |   * DDC_0
|   |   |   * DDC_1
|   |   |   * DUC_0
|   |   |   * DUC_1
N320
$ uhd_usrp_probe
[INFO] [UHD] linux; GNU C++ version 7.3.0; Boost_106600; UHD_3.14.0.0-0-g6875d061
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=127.0.0.1,type=n3xx,product=n320,serial=3181FFA,claimed=False
[INFO] [MPM.main] Launching USRP/MPM, version: 3.14.0.0-g6875d061
[INFO] [MPM.PeriphManager] Device serial number: 3181FFA
[INFO] [MPM.Rhodium-0] Successfully loaded all peripherals!
[INFO] [MPM.Rhodium-1] Successfully loaded all peripherals!
[INFO] [MPM.PeriphManager] No QSFP board detected: Assuming it is disabled in the device tree overlay (e.g., HG, XG images).
[INFO] [MPM.Rhodium-0] init() called with args `time_source=internal,clock_source=internal'
[INFO] [MPM.Rhodium-1] init() called with args `time_source=internal,clock_source=internal'
[INFO] [MPM.Rhodium-0.init.LMK04828] LMK initialized and locked!
[INFO] [MPM.Rhodium-1.init.LMK04828] LMK initialized and locked!
[INFO] [MPM.Rhodium-1.DAC37J82] DAC PLL Locked!
[INFO] [MPM.Rhodium-1.AD9695] ADC PLL Locked!
[INFO] [MPM.Rhodium-1.init] JESD204B Link Initialization & Training Complete
[INFO] [MPM.Rhodium-0.DAC37J82] DAC PLL Locked!
[INFO] [MPM.Rhodium-0.AD9695] ADC PLL Locked!
[INFO] [MPM.Rhodium-0.init] JESD204B Link Initialization & Training Complete
[INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=127.0.0.1,clock_source=internal,time_source=internal,product=n320'.
[INFO] [MPM.Rhodium-0] init() called with args `mgmt_addr=127.0.0.1,clock_source=internal,time_source=internal,product=n320'
[INFO] [MPM.Rhodium-1] init() called with args `mgmt_addr=127.0.0.1,clock_source=internal,time_source=internal,product=n320'
[INFO] [0/Replay_0] Initializing block control (NOC ID: 0x4E91A00000000004)
[INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000320)
[INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000000320)
[INFO] [0/DDC_0] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_1] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DUC_0] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_1] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/FIFO_0] Initializing block control (NOC ID: 0xF1F0000000000000)
[INFO] [0/FIFO_1] Initializing block control (NOC ID: 0xF1F0000000000000)
|   |       Mboard: ni-n3xx-3181FFA
|   |   eeprom_version: 2
|   |   mpm_version: 3.14.0.0-g6875d061
|   |   pid: 16962
|   |   product: n320
|   |   rev: 6
|   |   rpc_connection: local
|   |   serial: 3181FFA
|   |   type: n3xx
|   |   MPM Version: 1.2
|   |   FPGA Version: 5.3
|   |   FPGA git hash: 3de8954.clean
|   |   RFNoC capable: Yes
|   |   Sensors: gps_tpv, temp, gps_sky, fan, gps_time, gps_locked, ref_locked, gps_gpgga
|   |   |       RX Dboard: A
|   |   |   Serial: 3175A79
|   |   |   |   Antennas: TX/RX, RX2, CAL, TERM
|   |   |   |   Sensors: lo_locked
|   |   |   |   Gain range all: 0.0 to 60.0 step 1.0 dB
|   |   |   |   Bandwidth range: 250000000.0 to 250000000.0 step 0.0 Hz
|   |   |   |   Connection Type:
|   |   |       RX Dboard: B
|   |   |   Serial: 3175A67
|   |   |   |   Sensors: lo_locked
|   |   |   |   Connection Type:
|   |   |       TX Dboard: A
|   |   |   Serial: 3175A79
|   |   |   |   Antennas: TX/RX, CAL, TERM
|   |   |   |   Sensors: lo_locked
|   |   |   |   Connection Type:
|   |   |       TX Dboard: B
|   |   |   Serial: 3175A67
|   |   |   |   Sensors: lo_locked
|   |   |   |   Connection Type:
|   |   |   * Replay_0
|   |   |   * Radio_0
|   |   |   * Radio_1
|   |   |   * DDC_0
|   |   |   * DDC_1
|   |   |   * DUC_0
|   |   |   * DUC_1
|   |   |   * FIFO_0
|   |   |   * FIFO_1
N321
$ uhd_usrp_probe
[INFO] [UHD] linux; GNU C++ version 7.3.1 20180712 (Red Hat 7.3.1-6); Boost_106400; UHD_3.14.0.0-0-g6875d061
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.20.2,type=n3xx,product=n320,serial=3166646,claimed=False,addr=192.168.20.2
[INFO] [MPM.PeriphManager] init() called with device args `time_source=internal,clock_source=internal,product=n320,mgmt_addr=192.168.20.2'.
[INFO] [MPM.Rhodium-0] init() called with args `time_source=internal,clock_source=internal,product=n320,mgmt_addr=192.168.20.2'
[INFO] [MPM.Rhodium-1] init() called with args `time_source=internal,clock_source=internal,product=n320,mgmt_addr=192.168.20.2'
|   |       Mboard: ni-n3xx-3166646
|   |   eeprom_version: 2
|   |   pid: 16962
|   |   product: n320
|   |   rev: 6
|   |   serial: 3166646
|   |   type: n3xx
|   |   MPM Version: 1.2
|   |   FPGA Version: 5.3
|   |   RFNoC capable: Yes
|   |   Sensors: gps_sky, gps_time, gps_gpgga, gps_locked, fan, gps_tpv, ref_locked, temp
|   |   |       RX Dboard: B
|   |   |   Serial: 316D814
|   |   |   |   Sensors: lo_locked
|   |   |   |   Connection Type:
|   |   |       RX Dboard: A
|   |   |   Serial: 316D810
|   |   |   |   Sensors: lo_locked
|   |   |   |   Connection Type:
|   |   |       TX Dboard: B
|   |   |   Serial: 316D814
|   |   |   |   Sensors: lo_locked
|   |   |   |   Connection Type:
|   |   |       TX Dboard: A
|   |   |   Serial: 316D810
|   |   |   |   Sensors: lo_locked
|   |   |   |   Connection Type:
|   |   |   * Replay_0
|   |   |   * Radio_0
|   |   |   * Radio_1
|   |   |   * DDC_0
|   |   |   * DDC_1
|   |   |   * DUC_0
|   |   |   * DUC_1
|   |   |   * FIFO_0
|   |   |   * FIFO_1
If you see warnings such as:
   [WARNING] [UDP] The recv buffer could not be resized sufficiently.
You need to resize the socket buffers for your network interface card:
   sudo sysctl -w net.core.rmem_max=288000
   sudo sysctl -w net.core.wmem_max=288000
ASCII Art Example
You can quickly verify the operation of your USRP N3xx by running the rx_ascii_art_dft UHD example program.
You can run a simple test of the N3xx USRP by connecting an antenna and observing the spectrum of a commercial FM radio station in real-time, following the steps below:
1. Attach an antenna to the Ch0/RX2­ antenna port of the N3xx.
N300/N310
$ /usr/local/lib/uhd/examples/rx_ascii_art_dft --args "master_clock_rate=125e6,mgmt_addr=192.168.1.151,addr=192.168.10.2" --freq 98.5e6 --rate 2.5e6 --gain 50 --ref-lvl="-50" --dyn-rng 90 --ant "RX2" --subdev "A:0"
N320/N321
$ /usr/local/lib/uhd/examples/rx_ascii_art_dft --args "master_clock_rate=250e6,mgmt_addr=192.168.1.151,addr=192.168.10.2" --freq 98.5e6 --rate 2.5e6 --gain 50 --ref-lvl="-50" --dyn-rng 90 --ant "RX2" --subdev "A:0"
NOTE: Modify the command­ line argument freq ​above to specify a tuning frequency for a strong local FM radio station. You will also need to update the IP Address to match your device IP.
3. You should see a real-time FFT display of 2.5 MHz of spectrum, centered at the specified tuning frequency.
4. Type "Q" or Ctrl­-C to stop the program and to return to the Linux command line.
Example Output:
Creating the usrp device with: master_clock_rate=125e6,mgmt_addr=192.168.1.151,addr=192.168.10.2...
[INFO] [MPMD] Initializing 1 device(s) in parallel with args: mgmt_addr=192.168.1.151,type=n3xx,product=n310,serial=313ABDA,claimed=False,master_clock_rate=125e6,addr=192.168.10.2
[INFO] [MPM.PeriphManager] init() called with device args `mgmt_addr=192.168.1.151,product=n310,master_clock_rate=125e6'.
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1336 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1338 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1346 MB/s)
[INFO] [0/DmaFIFO_0] BIST passed (Throughput: 1350 MB/s)
[INFO] [0/Radio_0] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_1] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_2] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/Radio_3] Initializing block control (NOC ID: 0x12AD100000000310)
[INFO] [0/DDC_2] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DDC_3] Initializing block control (NOC ID: 0xDDC0000000000001)
[INFO] [0/DUC_2] Initializing block control (NOC ID: 0xD0C0000000000000)
[INFO] [0/DUC_3] Initializing block control (NOC ID: 0xD0C0000000000000)
Using Device: Single USRP:
  Mboard 0: ni-n3xx-313ABDA
  RX Channel: 0
    RX DSP: 0
    RX Dboard: A
    RX Subdev: Magnesium
  TX Channel: 0
    TX DSP: 0
    TX Dboard: A
    TX Subdev: Magnesium
  TX Channel: 1
    TX DSP: 0
    TX Dboard: B
  TX Channel: 2
    TX DSP: 0
    TX Dboard: C
  TX Channel: 3
    TX DSP: 0
    TX Dboard: D
Setting RX Rate: 2.500000 Msps...
Actual RX Rate: 2.500000 Msps...
Setting RX Gain: 50.000000 dB...
Actual RX Gain: 50.000000 dB...
Done!
Benchmarking your system
1 Gb Interface
NOTE: This example requires the HG FPGA image to be loaded.
N300/N310
This example will test one full-duplex stream using "RF0/A:0", at a rate of 3.84 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,master_clock_rate=122.88e6" \
   --duration 60 \
   --channels "0" \
   --rx_rate 3.84e6 \
   --rx_subdev "A:0" \
   --tx_rate 3.84e6 \
   --tx_subdev "A:0"
N310
This example will test four full-duplex streams at 1.25 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,master_clock_rate=125e6" \
   --duration 60 \
   --channels "0,1,2,3" \
   --rx_rate 1.25e6 \
   --rx_subdev "A:0 A:1 B:0 B:1" \
   --tx_rate 1.25e6 \
   --tx_subdev "A:0 A:1 B:0 B:1"
N320/N321
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,master_clock_rate=245.76e6" \
   --duration 60 \
   --channels "0" \
   --rx_rate 3.84e6 \
   --rx_subdev "A:0" \
   --tx_rate 3.84e6 \
   --tx_subdev "A:0"
10 Gb Interface SFP 1
NOTE: This example will work with either the HG or XG FPGA image.
N300/N310
This example will test one full-duplex stream using "RF0/A:0", at a rate of 31.25 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=125e6" \
   --duration 60 \
   --channels "0" \
   --rx_rate 31.25e6 \
   --rx_subdev "A:0" \
   --tx_rate 31.25e6 \
   --tx_subdev "A:0"
N320/N321
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=250e6" \
   --duration 60 \
   --channels "0" \
   --rx_rate 31.25e6 \
   --rx_subdev "A:0" \
   --tx_rate 31.25e6 \
   --tx_subdev "A:0"
N310
This example will test four full-duplex streams at 30.72 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=122.88e6" \
   --duration 60 \
   --rx_rate 30.72e6 \
   --tx_rate 30.72e6 \
N320/N321
This example will test two full-duplex streams at 30.72 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.20.2,master_clock_rate=245.76e6" \
   --duration 60 \
   --rx_rate 30.72e6 \
   --rx_subdev "A:0 B:0" \
   --tx_rate 30.72e6 \
   --tx_subdev "A:0 B:0"
Dual 10 Gb Interface
NOTE: This example requires the XG FPGA image to be loaded.
N310
This example will test four full-duplex streams at 62.5 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,second_addr=192.168.20.2,master_clock_rate=125e6" \
   --duration 60 \
   --rx_rate 62.5e6 \
   --tx_rate 62.5e6 \
N320/N321
This example will test two full-duplex streams at 62.5 MS/s, for 60 seconds:
   --args "type=n3xx,mgmt_addr=192.168.1.151,addr=192.168.10.2,second_addr=192.168.20.2,master_clock_rate=250e6" \
   --duration 60 \
   --rx_rate 62.5e6 \
   --tx_rate 62.5e6 \
USRP N3xx Device Specific Operations
N320/N321
Turning the Device Off/On
   shutdown ­-h now
Enable Auto Booting
Auto booting of the N3xx when power is applied can be configured by enabling the flag on the device's EEPROM with the following command:
   eeprom-set-flags 0x1
Default Password
Example Output:
   root@ni-n3xx-serial:~# passwd
   Changing password for root
   New password:
   Re-enter new password:
   passwd: password changed.
Legal Considerations
Sales and Ordering Support
Terms and Conditions of Sale
