Open Architecture For Radar and EW Research
Revision as of 12:13, 13 October 2021 by MichaelDickens (Talk | contribs) (→‎Synchronization Terminology: fix formatting)
Application Note Number and Author
AN-822 by Michael Dickens, Neel Pandeya, and Jovian Wysocki
This document provides guidance for designing a system that uses the NI Open Architecture for Radar and EW Research.
This user manual describes how to design a system that enables synchronization between Receive (Rx) channels and Transmit-Receive (Tx-Rx) channels, as well as high-throughput data sample transport from the software-defined radio (SDR) to a server system over 10 GbE data links. The purpose of this document is to provide a starting point in the creation of your specific system configuration.
Architecture Overview
The Open Architecture for Radar and EW Research allows engineers to quickly scale from software simulation to hardware demonstration. It features direct conversion RF sampling (200 MHz instantaneous bandwidth) with NI USRPs for L-band, S-band, and C-band radar applications, enabling coherent operation through shared local oscillator (LO) , PPS, and 10 MHz reference clock signals.
Figure 1. System Overview
  • User manual, bill of materials, and interconnect diagrams that describe how to set up a system with up to 32 channels of Rx-Rx and Tx-Rx synchronization.
  • Documentation that lists installation and configuration information, best practices, and known issues encountered during development and validation of an 32x32 system. nxn refers to systems where n is the number of transmit and receive channels.
o Synchronization between 32 Rx-Rx channels and 32 Tx-Rx channels.
o Streaming IQ data from 32 channels to a server for further processing.
The reference architecture demonstrates waveform generation from file using RFNoC replay blocks.
Hardware Overview
Figure 3. Hardware Overview
For a complete list of required hardware for the Open Architecture for Radar and EW Research, refer to the bill of materials in the <REFARCH>/docs/ folder, where <REFARCH> is an alias for the following GitHub file folder location:
This section describes the NI/Ettus Research products required for generating and acquiring RF signals as well as the synchronization signals — PPS, 10 MHz, and Local Oscillator (LO) — shown in Figure 3:
  • USRP N321 — Networked software-defined radio with 2-channel RF front end and 250 MSample/s on both Tx and Rx. Features a power splitter for LO distribution, 10 MHz shared reference clock for coherent MIMO functionality, shared PPS for enabling shared triggering, dual 10 GbE ports for data transfer, and an RJ45 management port for device management.
  • USRP N320 — Networked software-defined radio with 2-channel RF front end and 250 MSample/s on both Tx and Rx. Features LO sharing and 10 MHz shared reference clock for coherent MIMO functionality, shared PPS for enabling shared triggering, dual 10 GbE ports for data transfer, and an RJ45 management port for device management.
  • CDA-2990 with GPSDO — Clock distribution device called an OctoClock that generates and distributes 10 MHz reference clock and PPS signals and features a management port.
  • NI RF Torque Screwdriver and SMA Driver Bit (NI part number 780895-01) — Torque screwdriver recommended to securely tighten all connections to/from the USRPs in the system. You can also order the RF SMA Driver Bit Only (NI part number 780894-01).
Validated Hardware
Testing and deploying a system requires hardware from both NI and third-party vendors. The following component options have been validated and are recommended for most Open Architecture for Radar and EW Research systems:
  • Server
o Supermicro 4124GS-TNR — Server with dual AMD EPYC processors and 10 PCIe 4 x16 slots. Numerous PCIe lanes from the CPU support many 10 GbE connections and the PCIe processing required for high-channel-count systems.
o Intel X710-DA4 — Network card that supports x4 10 GbE connections.
o Intel E810-CQDA2 — Network card that supports two 100 GbE connections, or, with a breakout cable, x8 10 GbE connections.
  • Storage
o HighPoint SSD7505 — PCIe carrier board that holds x4 M.2 drives and supports either a software or hardware RAID configuration.
o Sabrent 2TB Rocket 4 PLUS — NVME M.2 SSD drive that supports consecutive writes rates of over 6 GB/s.
  • Power Splitter/Combiners
o Mini-Circuits 8-Way ZN8PD1-63W-S+ — DC pass, 8-way -0°, 50 Ω, 500 MHz to 6,000 MHz power splitter/combiner.
o Mini-Circuits 4-Way ZN4PD1-63HP-S+ — High power, DC pass, 4-way -0°, 50 Ω, 30 W, 500 MHz to 6,000 MHz power splitter/combiner.
  • Cabling
o SMA Cable, Loop Back Cable Kit (NI part number 782781-01) — Loopback cable kit includes 2 SMA-M to SMA-M cables (60 cm/2 ft) and 2 SMA-F to SMA-M Attenuators (30 dB, 50 Ohm, DC-6 GHz).
o SFP+ Cable, 10 Gigabit Ethernet Cable w/ SFP+ Terminations (1 Meter) (NI part number 783343-01) — SFP+ cable recommended for USRPs with 10 GigE interfaces. It can be used to connect the USRP to a 10 GigE switch or network adapter.
  • Rack Accessories
o Tripp Lite Rackmount Rack Extension Bracket (B018-000-1P5) — Bracket required to mount the USRPs in a rack.
o Z-Bracket — Bracket required to mount the USRPs in a rack to meet environmental specifications. Contact NI for more information about how to procure Z-brackets.
Software Overview
The reference software, shown in Figure 2, consists of a reference library and examples, written in C++, using USRP Hardware Driver (UHD) version 4.0. The reference software is supported on Ubuntu Linux 20.04. It demonstrates how to assemble multi-USRP systems through the UHD RFNoC API and replay block. It contains a Python-based binary int16 data file (.dat) generator and viewer. The reference software is written so it is scalable for systems beyond the validated 32x32 system.
The software demonstrates a Tx-Rx loopback across a system of USRPs. To maximize Rx bandwidth, the replay block is used to reduce host processing and network traffic for Tx. Data moves through the system as shown in the following figure.
Figure 4. Data Movement
Building the System
The following figure shows a 32x32 system layout. NI recommends using a rack for this system to simplify connections between the different hardware components.
Figure 5. Rack Layout for 32x32 System
  • Arrange the equipment in the rack to optimize proper airflow. USRP N321s and USRP N320s facilitate airflow from right to left, and the server facilitates airflow from front to back. NI recommends using Z-brackets to vertically stagger installation of USRPs. Contact NI for more information about how to procure the Z-brackets.
  • Number and label the USRPs with serial numbers. Visit the <REFARCH>/docs/ folder for a customizable template.
  • Label the NICs and 10 GbE cables to identify each USRP connection, as described in Connect the SFP+ Ports.
  • Connect the RX LO OUT and TX LO OUT cabling from Distribution Tier of USRP N321s to the nearest USRP N320 devices, as described in Connect the LO Distribution.
  • Keep signal path of all Rx, Tx, LO, PPS, and 10 MHz signals identical, using the shortest cable possible per tier, as described in Cabling the Hardware.
Note Ensure that you use a calibrated torque wrench for all cabling connections. NI recommends the RF Torque Screwdriver and SMA Driver Bit (NI part number 780895-01).
Connecting the RF RX-TX Ports for a MIMO Loopback
Use the MIMO loopback to validate the setup of the system and provide a baseline for synchronization calibration. Create the MIMO loopback by connecting the USRP TX/RX connectors (used for transmitting signals) to a combiner, connecting the combiner to a splitter, and the splitter to the USRP RX2 connectors (used for receiving signals).
The 8x8 system requires one 8-way splitter and one 8-way combiner. To set up the MIMO loopback, connect the RF 0/1 TX/RX and RX2 connectors on the USRP to an 8-way combiner and an 8-way splitter. All cables connecting between tiers, shown in the following figure, must be the same length and type.
Figure 6. MIMO Loopback (8x8)
Figure 7. MIMO Loopback (16x16)
Figure 8. MIMO Loopback (32x32)
Connecting 10 MHz and PPS
Figure 9. 10 MHz and PPS Connections (4x4)
The 8x8 system requires one OctoClock with GPSDO, four USRPs, two USRPs, and uses four 10 MHz and four PPS OUT SMA connectors. Ensure that the source selection switch is set to internal on OctoClock 0 prior to power up.
Figure 10. 10 MHz and PPS Connections (8x8)
Figure 11. 10 MHz and PPS Connections (16x16)
Figure 12. 10 MHz and PPS Connections (32x32)
Connecting the LO Distribution
Connect the TX LO OUT, RX LO IN, and TX LO IN connectors on the USRPs for LO distribution. While connecting the LO distribution, adhere to the following:
Table 1. LO Sources and Tiers
2x2 LO Source (0) 1 —
4x4 LO Source (0), 1 1 1
8x8 LO Source (0), 1, 2 2 2
16x16 LO Source (0), 1, 2 3 5
Figure 13. LO Sharing (2x2)
Figure 14. LO Sharing (4x4)
Figure 15. LO Sharing (8x8)
Table 2. LO Sharing Cabling (8x8)
Figure 16. LO Sharing (16x16)
Table 3. LO Sharing Cabling (16x16)
Figure 17. LO Sharing (32x32)
Table 4. LO Sharing Cabling (32x32)
Make the following RJ45 connections to configure and update the file system on the USRPs. The network port on the USRPs in this system use DHCP by default. You must either have a DHCP server running on an upstream networked device or set static IP address for each USRP.
Connecting the SFP+ Ports
Figure 18. Overview of Dataflow between the USRPs and the Server
Connecting to Power
Setting Up and Configuring the Software
    chmod +x setup_script.sh
    sudo ./setup_script.sh
  • config — Contains script files that assist with the software installation process.
  • docs — Contains system bill of materials and reference architecture template.
  • examples — Contains reference architecture example and configuration files.
  • lib — Contains the library source files.
  • tools — Contains Python-based data file generator and viewer.
Setting Up the First USRP
The following procedure references the USRP N300/N310/N320/N321 Getting Started Guide. Follow the procedure with the specific steps listed in this document.
    Note If the procedure in Updating the file system with Mender fails, you must follow the process in Updating the files system by writing the disk image.
  3. Follow the procedure in Updating the Network Configurations. Set the MTU to 9000. If you make any changes to the network configurations, NI recommends that you restart the USRP for those changes to take effect.
    Note NI strongly recommends that you create a document for tracking USRP serial numbers with assigned network addresses. Visit the <REFARCH>/docs/ folder for a customizable template. NI recommends that you assign static IP addresses for the management port IPs. This procedure is not included in this documentation.
  4. Follow the Network Mode FPGA Image Update procedure in Updating the FPGA Image to update to the XG image. Use the following command to configure both SFP ports to 10 Gb links:
    where <N3xx_IP_ADDR> is the actual IP address of the USRP being updated; you can find this address by correlating the serial number on the device with the IP address returned by the command uhd_find_devices.
  5. Follow the Dual 10Gb Streaming SFP Ports 0/1 procedure in Setting Up a Streaming Connection to configure the host Ethernet adapters for 10 GbE connection to the USRP.
    Note Ubuntu Linux uses Netplan to manage IP addresses of network cards (other operating systems may configure the network interfaces differently). Visit the <REFARCH>/config/ folder to find a customizable template .yaml file. The ports on the host require an IP address that matches the USRP it connects to. Once the .yaml file is configured, copy it to the /etc/netplan directory (overwriting 01-network-manager-all.yaml, if necessary). Then use the following command to apply the network configuration:
    sudo netplan apply
  6. Follow the procedure in Verifying Device Operation.
  7. (Optional) Follow the procedure in USRP N3xx Device Specific Operations to configure USRP settings.
Setting Up Additional USRPs
After setting up the first USRP, follow the complete procedure in Setting Up the First USRP Device for the remaining USRPs with the specific details listed here.
o Updating the Linux File System
o Updating the Network Configurations — Each USRP port must be configured to have a different subnet.
o Updating the FPGA Image
Optimizing the Host System
  • Increase the ring buffer for each interface by calling the following command:
where <interface> is the network interface of the specific USRP; you can find this interface through the Network Manager or by calling the command ifconfig.
Note This command is executed once for each interface being used. For example, a system with 16 USRPs with 16 interfaces runs 16 times. A script has been provided that can assist with these settings. The user is required to insert the names of the host interfaces. Refer to nicrb.sh in the <REFARCH>/config/ folder for more information. This script may need to be run after each host reboot. You can reference the interface names in the .yaml file configured in Setting Up the First USRP Device.
  • Enable hyperthreading on the server. Refer to server BIOS settings for information.
  • Enable C states on the server. Refer to server BIOS settings for information.
Using the Software
Getting Started Examples
Open Architecture for Radar and EW Research is built using the RFNoC API that ships with the USRP Hardware Driver (UHD).
  • UHD RFNoC Examples — NI recommends that users who are new to USRP Hardware Driver or the RFNoC API begin with the following UHD RFNoC examples, located in the UHD installation folder, uhd/host/examples:
o rfnoc_radio_loopback.cpp — This example uses the RFNoC API to connect an Rx radio to a Tx radio and run a loopback.
o rfnoc_replay_samples_from_file.cpp — This example uses the replay block to replay data from a file.
o rfnoc_RX_to_file.cpp — This example uses the RFNoC API to demonstrate the radio receiving and writing to file.
  • Reference Architecture Examples — The examples, located in the <REFARCH>/examples/ folder, demonstrate synchronized Tx-Rx operation scalable from 2x2 up to 32x32 systems:
o iterative_loopback_singlethread.cpp — This example cycles through each Tx channel to all Rx channels.
o multifreq_loopback.cpp — This example cycles through different frequencies and calls rfnoc_txrx_loopback.cpp.
o rfnoc_txrx_loopback.cpp — This example demonstrates a single Tx to all Rx loopback file using a multithreaded implementation.
o rfnoc_txrx_loopback_mem.cpp — This example demonstrates a single Tx to all Rx loopback to memory using a multithreaded implementation.
Configuration Files
  • Refer to the example runconfig.cfg configuration file for a detailed explanation of each argument.
  • The reference architecture uses a multiple RAID 0 system to increase the number of parallel writes, and thus achieve higher data rates. This requires user configuration to receivefunctions.cpp in the <REFARCH>/lib/ folder before building the examples. Refer to receivefunctions.cpp for more information.
Note Ensure that the management address for each USRP is specified in the configuration file as demonstrated in the runconfig.cfg example. Not specifying a management address can lead to loss of performance.
Running the Examples
  2. Run an example using the --cfgFile=runconfig.cfg command. For example, run rfnoc_txrx_loopback.cpp by calling
  • Sample data files should contain sc16 data samples and should be a multiple of 2 samples (8 bytes) in size because the replay block records and plays back in multiples of 8 bytes. Refer to samples_generator.py in the <REFARCH>/tools/ folder for an example of a sine wave generation.
  • Use the replay example to generate a waveform. Refer to the Using the RFNoC Replay Block Knowledge Base article for more information.
Viewing Data Files
Received data files consist of interleaved int16 IQ data (IQIQI...). Refer to the readDatFile.py example in the <REFARCH>/tools/ folder for more information about viewing data files.
Measured Performance
Definitions
Warranted specifications describe the performance of the system under stated operating conditions and are covered by the system warranty. Warranted specifications account for measurement uncertainties, temperature drift, and aging. Warranted specifications are ensured by design or verified during production and calibration.
Typical   specifications describe the performance met by a majority of systems.
Nominal  specifications describe an attribute that is based on design, conformance testing, or supplemental testing.
Measured  specifications describe the measured performance of a representative system.
Specifications are  Measured  unless otherwise noted.
System Characteristics
RF frequency coverage 3 MHz to 6 GHz
Configuration plane 1 GbE
Data plane 10 GbE
Processing nodes
On USRP FPGA
On server CPU
Data storage and streaming
Format Binary
Type Complex interleaved U16
Synchronization
  • Average channel-to-channel phase skew — The average phase offset between two channels. Described by how it varies over time, or from run to run.
  • Standard deviation of channel-to-channel skew — One number that describes the variation of phase offset between channels around the average skew over time, or from run to run.
  • Rx-Rx — Channel-to-channel specifically referring to Rx channels.
Synchronization Methodology
Skew measurements are made based on IQ data files generated using the reference software provided as part of the Open Architecture for Radar and EW Research. The measured system uses the MIMO loopback configuration, described in Connecting the RF RX-TX Ports for a MIMO Loopback, to route signals from all Tx ports to all Rx ports with a consistent path length. To measure the phase skew, the Angle-FFT method is used, wherein the IQ data generated from each channel is measured against the relevant reference signal for each measurement. The FFT method is used to extract the frequency and phase components of each signal in the vicinity of the signal’s fundamental frequency. This information is used to determine the magnitude of the phase offset between two signals in each measurement period. To compare signals throughout their entire duration, each signal is split into shorter measurement windows in which the instantaneous phase is calculated using the method described above.
Phase Coherence One-Hour Stability[2]
  • Configuration:
  • Single device: Stimulus simultaneously received at two Rx channels on the same USRP
  • System: Stimulus simultaneously received at two Rx channels on arbitrary separate USRPs
  • Analysis:
  • µn – µ0 is the average skew relative to t0
20x18px
Note
Rx channels on the same USRP internally share the RX LO input to that device as shown in the following figure.
Figure . RF Configuration for Stability Measurements
Figure . Average Channel-to-Channel Phase Skew between Two Rx Channels on the Same Device over One Hour, Relative to t0
Range, single device 0.139°
Figure . Average Channel-to-Channel Phase Skew between Two Rx Channels on Separate Devices over One Hour, Relative to t0
Range, system 0.167°
  • Analysis:
Figure . Standard Deviation in Short-Term Rx-Rx Phase Skew as a Function of Carrier Frequency
  • 10 runs
  • Analysis:
  • rn = Max(Abs({mn0, mn1, … mn9} - mn0)) is the range from run to run of Rx-Rx skew for channel n
Maximum of 32 channels 0.145°
Average of 32 channels 0.070°
Maximum of 32 channels 0.483°
20x18px
Note
In each run analyzed here, the carrier frequency is 2.0 GHz. Users must recharacterize channel-to-channel skew when using different carrier frequencies, because average channel-to-channel skew in the system deviates by >>1°per channel. This was tested using a 32x32 MIMO loopback and sweeping carrier frequency from 1.0 GHz to 5.5 GHz.
Maximum of 32 channels 0.066°
Average of 32 channels 0.067°
Maximum of 32 channels 0.169°
Streaming
  • Number of channels: Varied
  • Duration: Single run, 10 s
33.33 32 10
50 16 10
122.88 8 10
20x18px
Note
For more information about supported sampling and master clock rates refer to the USRP N300/N310/N320/N321 Getting Started Guide at [https://kb.ettus.com/USRP_N300/N310/N320/N321_Getting_Started_Guide https://kb.ettus.com/USRP_N300/N310/N320/N321_Getting_
Started_Guide].
33.33 32 10
50 16 10
62.5 8 10
Appendix: Creating High-Channel-Count Systems
NI tested and configured the Open Architecture for Radar and EW Research for a 32x32 system. It is possible to build a 64x64 (or greater) system.
Connection Considerations for High-Channel-Count Systems
LO Distribution for High-Channel-Count Systems
Refer to Connect the LO Distribution for information about LO distribution connections and best practices.
For the 64x64 system, all RX LO OUT cables originating from the LO Source N321 must be the same length. All RX LO OUT and TX LO OUT cables originating from the Tier 1 N321s must be the same length. All RX LO OUT and TX LO OUT cables originating from the Tier 2 N321s must be the same length. Note that you cannot combine LO signals.
Figure . LO Sharing (64x64)
Additional Resources
Related Documentation
Refer to the following documents to learn more about the Open Architecture for Radar and EW Research, software, and hardware components:
Training Resources
    The LO Distribution Knowledge Base article at https://kb.ettus.com/USRP_N320/N321_LO_Distribution does not show one LO signal shared across Tx and Rx.
  • ↑ Stability reports variation in the value of average channel-to-channel phase skew over a long (>>1 s) duration.
  • ↑ Short-term describes variation in channel-to-channel phase skew over a short duration (<100 µs).
  • ↑ A USRP session is a period in which communication links between chips in the USRP are established and not changed. Session reset is accomplished by restarting the reference software for each run.
  • ↑ A USRP configuration is a period in which the digital path within the USRP is configured and not changed. Configuration reset is accomplished by changing carrier frequency from 2.0 GHz to 2.1 GHz and back to 2.0 GHz between runs.
  • ↑ Streaming to memory is measured as the sustained data transfer rate without any overflows.
  • ↑ Streaming to disk is measured as the sustained data transfer rate without any overflows.
