Multichannel RF Reference Architecture
Revision as of 08:15, 14 April 2022 by JovianWysocki (Talk | contribs) (→‎Optimizing the Host System: Formatting)
This document provides guidance for designing a system that uses the NI Multichannel RF Reference Architecture version 1.1.
This document describes how to design a system that enables synchronization between Receive (Rx) channels, Transmit (Tx) channels, and Transmit-Receive (Tx-Rx) channels, as well as high-throughput data sample transport from the software-defined radio (SDR) to a server system over 10 GbE data links. This document provides a starting point in the creation of your specific system configuration. A basic understanding of Linux, command line, C++, Git, and networking is required to build and develop on the NI Multichannel RF Reference Architecture system.
Architecture Overview
The Multichannel RF Reference Architecture allows engineers to quickly scale from software simulation to hardware demonstration. It features direct conversion RF sampling (200 MHz instantaneous bandwidth) with NI USRPs for L-band, S-band, and C-band radar applications, enabling coherent operation through shared local oscillator (LO), PPS, and 10 MHz reference clock signals.
Figure 1. System Overview
  • Document, bill of materials, and interconnect diagrams that describe how to set up a system with up to 32 channels of Rx-Rx, Tx-Rx, and Tx-Tx synchronization.
  • Documentation that lists installation and configuration information for a 32x32 system, as well as best practices for development and validation of the system. NxM refers to systems, where N is the number of transmit channels and M is the number of receive channels.
  • Synchronization between 32 Rx-Rx channels, 6 Tx-Tx channels, and 32 Tx-Rx channels
  • Bidirectional streaming of IQ data between 32 channels and server
The reference architecture demonstrates using RFNoC to transmit from both the replay block as well as the host.
Hardware Overview
Figure 3. Hardware Overview
For a complete list of required hardware for the Multichannel RF Reference Architecture, refer to the bill of materials in the <REFARCH>/docs/ folder, where <REFARCH> is an alias for the following GitHub file folder location:
This section describes the NI/Ettus Research products required for generating and acquiring RF signals as well as the synchronization signals—PPS, 10 MHz, and Local Oscillator (LO)—shown in Figure 3:
  • USRP N321—Networked software-defined radio with 2-channel RF front end and 250 MSample/s on both Tx and Rx. Features a power splitter for LO distribution, 10 MHz shared reference clock for coherent MIMO functionality, shared PPS for enabling shared triggering, dual 10 GbE ports for data transfer, and an RJ45 management port for device management.
  • USRP N320—Networked software-defined radio with 2-channel RF front end and 250 MSample/s on both Tx and Rx. Features LO sharing and 10 MHz shared reference clock for coherent MIMO functionality, shared PPS for enabling shared triggering, dual 10 GbE ports for data transfer, and an RJ45 management port for device management.
  • CDA-2990 with GPSDO—Clock distribution device called an OctoClock that generates and distributes the GPSDO signals—10 MHz reference (REF) and 1 Hz (PPS)—and features a management port.
  • NI RF Torque Screwdriver and SMA Driver Bit (NI part number 780895-01)—A torque screwdriver is strongly recommended to securely tighten all connections to/from the USRPs in the system. You can also order the RF SMA Driver Bit Only (NI part number 780894-01).
Validated Hardware
Testing and deploying a system requires hardware from both NI and third-party vendors. The following component options have been validated and are recommended for most Multichannel RF Reference Architecture systems:
  • Server
o Supermicro 4124GS-TNR—Server with dual AMD EPYC processors and 10 PCIe 4 x16 slots. Numerous PCIe lanes from the CPU support many 10 GbE connections and the PCIe processing required for high-channel-count systems.
o Trenton Systems BAM3U—Server with Intel dual 3rd generation Xeon Ice Lake processors, 11 Gen 4.0 PCIe slots (5 x16 slots, 6 x8 slots), and 24x DDR4-3200 ECC RDIMM slots for high-channel-count systems.
o Intel X710-DA4—Network card that supports x4 10 GbE connections.
o Intel E810-CQDA2—Network card that supports two 100 GbE connections, or, with a breakout cable, x8 10 GbE connections.
  • Storage
o HighPoint SSD7505—PCIe carrier board that holds x4 M.2 drives and supports either a software or hardware RAID configuration.
o Sabrent 2TB Rocket 4 PLUS—NVME M.2 SSD drive that supports consecutive writes rates of over 6 GB/s.
  • Power Splitter/Combiners
o Mini-Circuits 8-Way ZN8PD1-63W-S+—DC pass, 8-way -0°, 50 Ω, 500 MHz to 6,000 MHz power splitter/combiner.
o Mini-Circuits 4-Way ZN4PD1-63HP-S+—High power, DC pass, 4-way -0°, 50 Ω, 30 W, 500 MHz to 6,000 MHz power splitter/combiner.
  • Cabling
o SMA Cable, Loop Back Cable Kit (NI part number 782781-01)—Loopback cable kit includes 2 SMA-M to SMA-M cables (60 cm/2 ft) and 2 SMA-F to SMA-M Attenuators (30 dB, 50 Ohm, DC-6 GHz).
o SFP+ Cable, 10 Gigabit Ethernet Cable w/ SFP+ Terminations (1 Meter) (NI part number 783343-01)—SFP+ cable recommended for USRPs with 10 GigE interfaces. It can be used to connect the USRP to a 10 GigE switch or network adapter.
  • Rack Accessories
o Tripp Lite Rackmount Rack Extension Bracket (B018-000-1P5)—Bracket required to mount the USRPs in a rack.
o Z-Bracket—Bracket required to mount the USRPs in a rack to meet environmental specifications.
Software Overview
The reference software, shown in Figure 2, consists of a C++ reference library and examples, using USRP Hardware Driver (UHD) version 4.1. The reference software is supported on Ubuntu Linux 20.04. It demonstrates how to assemble multi-USRP systems through the UHD RFNoC API and replay block. It contains a Python-based binary int16 data file (.dat) generator and viewer. The reference software is written to be scalable for systems 2x2 to 32x32 and beyond, as well as Tx or Rx only (2 to 32 channels and beyond).
The software provides examples that stream data from the replay block as well as the host, as shown in the following figures.
Figure 4. Data Movement
Figure 5. Stream from Host Data Movement
Building the System
The following figures show a 32x32 system layout. NI recommends using a rack for this system to simplify connections between the different hardware components.
Figure 6. Multichannel RF Reference Architecture System
Figure 7. Rear View of System with Cabling
Figure 8. Rack Layout for 32x32 System
  • Number and label the USRPs with serial numbers on the front of the devices. Visit <REFARCH>/docs/32_Channel_Template_layout_BOM_and_wiring.ods for a customizable template.
  • While running the system in loopback, attach 30 dB attenuators to all output channels to prevent damage to the USRPs.
  • Arrange the equipment in the rack to optimize proper airflow. USRP N321s and USRP N320s facilitate airflow from right to left, and the server facilitates airflow from front to back. NI recommends using Z-brackets to vertically stagger installation of USRPs.
  • Label the NICs and 10 GbE cables to identify each USRP connection, as described in Connecting the SFP+ Ports.
  • Connect the RX LO OUT and TX LO OUT cabling from Distribution Tier of USRP N321s to the nearest USRP N320 devices, as described in Connecting the LO Distribution
  • Keep the end-to-end path of each Rx, Tx, LO, PPS, and 10 MHz signal identical in length, using the shortest cable possible per tier, as described in Cabling the Hardware.
NoteEnsure that you use a calibrated torque wrench for all cabling connections. NI recommends the RF Torque Screwdriver and SMA Driver Bit (NI part number 780895-01).
(Optional) Connecting the RF RX-TX Ports for a MIMO Loopback
You can use the MIMO loopback to validate the setup of the system and provide a baseline for synchronization calibration. Create the MIMO loopback by connecting the USRP TX/RX connectors (used for transmitting signals) to a combiner, connecting the combiner to a splitter, and connecting the splitter to the USRP RX2 connectors (used for receiving signals).
Notice 30 dB attenuators must be used on every TX to ensure safe use of the MIMO loopback. Using the system without attenuators will overload the RX and will permanently damage the USRPs.
The 8x8 system requires one 8-way splitter and one 8-way combiner. To set up the MIMO loopback, connect the RF 0/1 TX/RX and RX2 connectors on the USRP to an 8-way splitter and an 8-way combiner, as shown in Figure 8. All cables connecting between tiers must be the same length and type.
Figure 9. MIMO Loopback (8x8)
Figure 10. MIMO Loopback (16x16)
Figure 11. MIMO Loopback (32x32)
Connecting 10 MHz and PPS
Figure 12. 10 MHz and PPS Connections (4x4)
The 8x8 system requires one OctoClock with GPSDO, four USRPs, and uses four 10 MHz and four PPS OUT SMA connectors. Ensure that the source selection switch is set to internal on OctoClock 0 prior to power up.
Figure 13. 10 MHz and PPS Connections (8x8)
Figure 14. 10 MHz and PPS Connections (16x16)
Figure 15. 10 MHz and PPS Connections (32x32)
Connect the TX LO OUT, RX LO IN, and TX LO IN connectors on the USRPs for LO distribution.
Note This configuration is used to synchronize both the Rx and Tx to the same LO resulting in the same center frequencies for both Tx and Rx. To synchronize different frequencies, connect RX LO OUT to RX LO IN and TX LO OUT to TX LO OUT. Refer to USRP N320/N321 LO Distribution for connection diagrams.
While connecting the LO distribution, adhere to the following best practices:
Table 5. Streaming to Memory Data Transfer Rate
2x2 LO Source (0) 1 —
4x4 LO Source (0), 1 1 1
8x8 LO Source (0), 1, 2 2 2
16x16 LO Source (0), 1, 2 3 5
Figure 16. LO Sharing (2x2)
Figure 17. LO Sharing (4x4)
Figure 18. LO Sharing (8x8)
Table 6. LO Sharing Cabling (8x8)
Figure 19. LO Sharing (16x16)
Table 7. LO Sharing Cabling (16x16)
Figure 20. LO Sharing (32x32)
Table 8. LO Sharing Cabling (32x32)
Make the following RJ45 connections to allow USRP file system configuration and updates later in the process.
Note The network port on the USRPs in this system use DHCP by default. You must either have a DHCP server running on an upstream networked device or set a static IP address for each USRP.
Figure 21. Overview of Dataflow between the USRPs and the Server
Connecting to Power
Installing and Configuring the Software
    chmod +x setup_script.sh
    sudo ./setup_script.sh
  • examples—Contains reference architecture examples and configuration files.
Setting Up the First USRP
The following procedure references the USRP N300/N310/N320/N321 Getting Started Guide. Follow the https://kb.ettus.com/USRP_N300/N310/N320/N321_Getting_Started_Guide procedure with the specific steps below.
Note When you run the scripts in this section, all USRPs connected to the host are updated. Run the uhd_find_devices example for a list of USRPs that are connected to the host.
Note If the procedure in Updating the file system with Mender fails, you must follow the process in Updating the files system by writing the disk image. For a script that updates all USRPs connected to the system, refer to <REFARCH>/config/usrp_filesystem.sh in the GitHub repository.
  1. Follow the procedure in Updating the Network Configurations. Set the MTU to 9000. Every USRP SFP+ ports IP address must have a unique subnet. Change the subnet by replacing XXX in the address, for example, 192.168.XXX.2. If you make any changes to the network configurations, NI recommends that you restart the USRP for those changes to take effect.
Note NI recommends that you create a document for tracking USRP serial numbers with assigned network addresses. Visit the <REFARCH>/docs/ folder for a customizable template. For network addresses, NI recommends that you assign static IP addresses for the management port IPs. Refer to the procedure in Updating the Network Configurations to update eth0.network file on the USRP.
For a script to update the SFP ports on all USRPs automatically, refer to <REFARCH>/config/usrp_ip_config.sh in the GitHub repository. The script changes the sfp1 port by default but can be modified to change the sfp0 port. You still need to manually configure the host as listed in step 5.
  1. Follow the Network Mode FPGA Image Update procedure in Updating the FPGA Image to update to the XG image. Use the following command to configure both SFP ports to 10 Gb links:
    where <N3xx_IP_ADDR> is the actual IP address of the USRP being updated. You can find this address by correlating the serial number on the device with the IP address returned by the command uhd_find_devices.
Note For a script to update the FPGA images on all USRPs connected to the system, refer to <REFARCH>/config/usrp_image_loader.sh on the GitHub repository.
  1. Follow the Dual 10Gb Streaming SFP Ports 0/1 procedure in Setting Up a Streaming Connection to configure the host Ethernet adapters for 10 GbE connection to the USRP.
Note Ubuntu Linux uses Netplan to manage IP addresses of network cards, however, other operating systems may configure the network interfaces differently. Visit the <REFARCH>/config/ folder to find a customizable template .yaml file. Each host port and the USRP to which it is paired must have a matching subnet. After the .yaml file is configured, copy it to the /etc/netplan directory—overwriting 01-network-manager-all.yaml, if necessary. Then use the following command to apply the network configuration:
$ sudo netplan apply
Setting Up Additional USRPs
After setting up the first USRP, follow the procedure in Setting Up the First USRP for the remaining USRPs with the specific details listed below.
  • Updating the Linux File System
  • Updating the Network Configurations—Each USRP port must be configured to have a different subnet.
  • Updating the FPGA Image
  • Increase the ring buffer for each interface by executing the following command in a terminal
where <interface> is the network interface of the specific USRP. You can find this interface through the Network Manager or by executing the following command in a terminal ifconfig.
Note Increasing the ring buffer of an interface results in more memory reserved. When setting the ring buffer, make sure to monitor your memory usage. A large number of interfaces can result in hundreds of GB of memory usage. You may need to restart the host system to clear the allocated memory.
Note This command is executed once for each interface being used. For example, a system with 16 USRPs and 16 interfaces runs 16 times and results in around 65 GB of memory usage. A script has been provided to assist with these settings. The user is required to insert the names of the host interfaces. Refer to nicrb.sh in the <REFARCH>/config/ folder for more information. This script may need to be run after each host reboot. You can reference the interface names in the .yaml file configured in Setting Up the First USRP Device.
  • Enable hyperthreading on the server to improve multi-threaded performance. Refer to the server BIOS settings for information.
Using the Software
Example Source Code
Multichannel RF Reference Architecture is built using the RFNoC API that ships with the USRP Hardware Driver (UHD).
  • UHD RFNoC Example Source Code— NI recommends that users who are new to UHD or the RFNoC API begin with the following UHD RFNoC examples, located in the uhd/host/examples directory:
  • rfnoc_radio_loopback.cpp—This example uses the RFNoC API to connect an Rx radio to a Tx radio and run a loopback.
  • rfnoc_replay_samples_from_file.cpp—This example uses the replay block to replay data from a file.
  • rfnoc_rx_to_file.cpp— This example uses the RFNoC API to demonstrate the radio receiving and writing to file.
  • Reference Architecture Example Source Code— The following examples, located in the <REFARCH>/examples/ folder, demonstrate synchronized Tx-Rx operation scalable from 2x2 up to 32x32 systems:
  • Arch_iterative_loopback.cpp—This example cycles through each Tx channel to all Rx channels.
  • Arch_multifreq_loopback.cpp—This example cycles through different frequencies and calls rfnoc_txrx_loopback.cpp.
  • Arch_rfnoc_txrx_loopback.cpp—This example demonstrates a single Tx to all Rx loopback file using a multithreaded implementation.
  • Arch_rfnoc_txrx_loopback_mem.cpp—This example demonstrates a single Tx to all Rx loopback to memory using a multithreaded implementation.
  • Arch_rx_to_mem.cpp—This ­example demonstrates receiving on all channels to memory.
  • Arch_txrx_fullduplex.cpp—This example demonstrates simultaneously transmitting to and receiving from the host.
  • Arch_dynamic_tx.cpp—This example is written for a four-channel system. It demonstrates the ability to stream different files and/or have different logic in each transmit thread. Four (potentially) different transmit threads are spawned, one to each USRP channel. Each thread can be customized as needed. You can apply this example to higher channel count systems, as well as receive threads if needed.
20x18px Note The provided examples use the same LO and Tx frequency transmitted across all channels and devices. You must modify this reference architecture if you want to transmit different frequencies across channels.
Building Examples
The reference architecture examples are compiled when you run the following setup script, setup_script.sh.
If you need to make changes to the examples, you must recompile the code.
  1. Navigate to <REFARCH>/build/ to recompile the provided examples.
  2. Execute the following commands in the terminal:
cmake ..
make –j
If a custom example needs to be compiled, you must modify <REFARCH>/CMakeLists.txt to be used with cmake. To build a new example titled new_example.cpp, complete the following steps.
  1. Add the following lines to <REFARCH>/CMakeLists.txt:
add_executable(new_example {relative File Location}/new_example.cpp)
message(STATUS "New Example")
target_link_libraries(new_example PRIVATE UHD_BOOST Arch_lib)
  1. Navigate to <REFARCH>/build/.
  2. Execute the command make –j in the terminal to compile the custom examples.
Configuration Files
  • Refer to the example runconfig.cfg file for a detailed explanation of each argument.
  • The reference architecture uses a multiple RAID 0 system to increase the number of parallel writes and, thus, achieve higher data rates. You must configure the rx-file-location variable in the runconfig.cfg file. Refer to the configuration file for more information.
20x18px Note Ensure that the management address for each USRP is specified in the configuration file as demonstrated in the runconfig.cfg example. Not specifying a management address can lead to loss of performance.
Running the Examples
  2. Run an example using the --cfgFile=runconfig.cfg command. For example, run rfnoc_txrx_loopback.cpp by executing the following command in a terminal:
  • Sample data files should contain sc16 data samples and should be a multiple of two samples (8 bytes) in size because the replay block records and plays back in multiples of 8 bytes. Refer to samples_generator.py in the <REFARCH>/tools/ folder for an example of a sine wave generation. Refer to the Using the RFNoC Replay Block Knowledge Base article for more information.
Viewing Data Files
Received data files consist of interleaved int16 IQ data (IQIQI...). You can view data and helpful phase information with the python-based readDatFile.py example, located in the <REFARCH>/tools/oarer_dat_analysis folder. Refer to the comments in readDatFile.py for more information about the use of the program.
Measured Performance
Definitions
System Characteristics
RF frequency coverage 400 MHz
Configuration plane 1 GbE
Data plane 10 GbE
Processing nodes
On USRP FPGA
On server CPU
Data storage and streaming
Format Binary
Type Complex interleaved U16
Synchronization
Synchronization Terminology
  • Average channel-to-channel phase skew—The average phase offset between two channels. Described by how it varies over time or from run to run.
  • Standard deviation of channel-to-channel skew—One number that describes the variation of phase offset between channels around the average skew over time or from run to run.
Synchronization Methodology
Skew measurements are made based on IQ data files generated using the reference software provided as part of the Multichannel RF Reference Architecture. The measured system uses the MIMO loopback configuration, described in Connecting the RF RX-TX Ports for a MIMO Loopback, to route signals from all Tx ports to all Rx ports with a consistent path length. To measure the phase skew, the Angle-FFT method is used, wherein the IQ data generated from each channel is measured against the relevant reference signal for each measurement. The FFT method is used to extract the frequency and phase components of each signal in the vicinity of the signal’s fundamental frequency. This information is used to determine the magnitude of the phase offset between two signals in each measurement period. To compare signals throughout their entire duration, each signal is split into shorter measurement windows in which the instantaneous phase is calculated using the method described above.
Rx Phase Coherence One-Hour Stability[2]
  • Configuration:
  • Single device: Stimulus simultaneously received at two Rx channels on the same USRP
  • System: Stimulus simultaneously received at two Rx channels on arbitrary separate USRPs
  • Analysis:
  • µn – µ0 is the average skew relative to t0
20x18px Note Rx channels on the same USRP internally share the RX LO input to that device as shown in the following figure.
Figure 22. RF Configuration for Stability Measurements
431x239px
Figure 23. Average Channel-to-Channel Phase Skew between Two Rx Channels on the Same Device over One Hour, Relative to t0
611x224px
Range, single device 0.139°
Figure 24. Average Channel-to-Channel Phase Skew between Two Rx Channels on Separate Devices over One Hour, Relative to t0
615x226px
Range, system 0.167°
  • Analysis:
Figure 25. Standard Deviation in Short-Term Rx-Rx Phase Skew as a Function of Carrier Frequency
448x323px
  • 10 runs
  • Analysis:
  • rn = Max(Abs({mn0, mn1, … mn9} – mn0)) is the range from run to run of Rx-Rx skew for channel n
Maximum of 32 channels 0.145°
Average of 32 channels 0.070°
Maximum of 32 channels 0.483°
20x18px Note In each run analyzed here, the carrier frequency is 2.0 GHz. Users must recharacterize channel-to-channel skew when using different carrier frequencies, because average channel-to-channel skew in the system deviates by >>1° per channel.
Maximum of 32 channels 0.066°
Average of 32 channels 0.067°
Maximum of 32 channels 0.169°
Tx Phase Coherence One-Hour Stability
  • Configured carrier frequency: 1 GHz
  • Configured baseband stimulus: 500 kHz sine wave, continuously transmitted at 250 MSample/s for 1 hour, sampled at 3.2 GSample/s in finite windows
  • Measurement window: 35 ms (120,000 samples)
  • Configuration:
  • Transmitters: Stimulus simultaneously transmitted from any two channels
  • Receivers: Stimulus simultaneously received at two Rx channels on external acquisition device
  • Analysis:
Figure 26. Average Channel-to-Channel Phase Skew between Two Tx Channels on the Same Device over One Hour, Relative to t0
612x225px
Range, single device 0.128°
Figure 27. Average Channel-to-Channel Phase Skew between Two Tx Channels on Separate Devices over One Hour, Relative to t0
615x226px
Range, system 0.115°
Repeatability of Tx-Tx Phase Coherence
  • 50 runs
  • Transmit from 4 Tx
  • Configured baseband stimulus: 35 µs, sampled at 3.4 GSample/s
  • Measurement window: 35 µs (120,000: samples)
  • Analysis:
  • Where mnx is Tx n-to-Tx 0 average skew in run x
  • sdn = σ{mn0, mn1, … mn9} is the standard deviation from run to run of Tx-Tx skew for channel n
  • rn = Max(Abs({mn0, mn1, … mn9} - mn0)) is the range from run to run of Tx-Tx skew for channel n
  • µ{sd1, sd2,…,sd32} is the system average standard deviation of Tx-Tx skew
  • Maximum{ sd1, sd2,…,sd32} is the system maximum standard deviation of Tx-Tx skew
  • µ{r1, r2,…,r32} is the system average range of Tx-Tx skew
  • Maximum{ r1, r2,…,r32} is the system maximum range of Tx-Tx skew
Average over 4 channels 0.012°
Maximum of 4 channels 0.020°
Range of average channel-to-channel skew over 50 runs (rn)
Average of 4 channels 0.039°
Maximum of 4 channels 0.089°
Average over 4 channels 0.014°
Average of 4 channels 0.041°
Maximum of 4 channels 0.059°
Streaming
  • Number of channels: Varied
  • Duration: Single run, 10 s
33.33 32 10
50 16 10
122.88 8 10
20x18px Note For more information about supported sampling and master clock rates, refer to the USRP N300/N310/N320/N321 Getting Started Guide.
33.33 32 10
50 16 10
62.5 8 10
Streaming Simultaneously to/from Disk Rate[8]
11.11 32 10
25 16 10
62.5 8 10
62.5 4 10
Appendix: Creating High‑Channel‑Count Systems
NI tested and configured the Multichannel RF Reference Architecture for a 32x32 system. It is possible to build a 64x64 (or greater) system.
Connection Considerations for High‑Channel‑Count Systems
LO Distribution for High‑Channel‑Count Systems
Refer to Connecting the LO Distribution for information about LO distribution connections and best practices.
20x18px Note This configuration is used to synchronize both the Rx and Tx to the same LO resulting in the same center frequencies for both Tx and Rx. To synchronize different frequencies, connect RX LO OUT to RX LO IN and TX LO OUT to TX LO OUT. Refer to USRP N320/N321 LO Distribution for connection diagrams.
For the 64x64 system, all RX LO OUT cables originating from the LO Source USRP N321 must be the same length. All RX LO OUT and TX LO OUT cables originating from the Tier 1 USRP N321s must be the same length. All RX LO OUT and TX LO OUT cables originating from the Tier 2 USRP N321s must be the same length. Note that you cannot combine LO signals.
Figure 28. LO Sharing (64x64)
587x323px
13x13px LO Source Tier 0 4
13x13px Distribution Tier 1, RX LO OUT 8
13x13px Distribution Tier 1, TX LO OUT 8
13x13px Distribution Tier 2, RX LO OUT 32
13x13px Distribution Tier 2, TX LO OUT 32
Additional Resources
Related Documentation
Refer to the following documents to learn more about the Multichannel RF Reference Architecture, software, and hardware components:
Training Resources
  1. ↑
    The USRP N320/N321 LO Distribution Knowledge Base article does not show one LO signal shared across Tx and Rx.
  2. ↑ Stability reports variation in the value of average channel-to-channel phase skew over a long (>>1 s) duration.
  3. ↑ Short-term describes variation in channel-to-channel phase skew over a short duration (<100 µs).
  4. ↑ A USRP session is a period in which communication links between chips in the USRP are established and not changed. Session reset is accomplished by restarting the reference software for each run.
  5. ↑ A USRP configuration is a period in which the digital path within the USRP is configured and not changed. Configuration reset is accomplished by changing carrier frequency from 2.0 GHz to 2.1 GHz and back to 2.0 GHz between runs.
  6. ↑ Streaming to memory is measured as the sustained data transfer rate without any overflows.
  7. ↑ Streaming to disk is measured as the sustained data transfer rate without any overflows.
  8. ↑ Streaming simultaneously to/from disk is defined as streaming from the host to the radio for transmission, while simultaneously receiving on the radio to a file on the host. The rates are measured as sustained data transfer rates without any overflows.
