Power Monitoring for Energy Efficient 5G/6G with OAI and USRP
- 1 Application Note Number and Authors
- 2 Authors
- 3 Executive Summary
- 4 Demonstrator Scope and Overview
- 5 Demonstrator System Architecture
- 6 1. 5G/6G Base Station Prototype (gNB)
- 7 2. NI CompactRIO Power Measurement System
- 8 3. NI Data Recording Entity / Server
- 9 4. 5G User Terminal (UE)
- 10 Overall Workflow
- 11 Demonstrator Setup
- 12 1. Device Under Test (DUT): 5G Base Station
- 13 2. NI cRIO Power Measurement System
- 14 3. Data Recording Entity
- 15 5G User Terminal (UE)
- 16 5G Sub‑System Demo Configuration (gNB + UE)
- 17 Hardware System Block Diagram Explanation
- 18 RF and Network Connections Overview
- 19 Network Interfaces
- 20 RF Signal Chain
AN-844
Authors
Executive Summary
Energy efficiency is becoming a critical KPI for 5G-Advanced and 6G systems, especially in Open RAN, AI-driven PHY, and Integrated Sensing and Communication (ISAC) testbeds.
Real-time power monitoring enables:
- Evaluation of baseband processing efficiency
- Measurement of RF front-end power consumption
- AI accelerator energy profiling
- Optimization of system-level energy-per-bit metrics
This application note demonstrates how to implement accurate power monitoring in a 5G/6G testbed using NI measurement hardware and software tools.
This demonstrator implements a measurement framework to synchronously monitor and measure power and energy consumption across multiple heterogeneous components of a wireless system.
5G/6G Base Station Prototype, consisting of:
- Linux server (baseband processing platform)
- OpenAirInterface (OAI) base station stack
- NI USRP (RF front-end)
- External switchable power amplifier (PA)
Demo Use Cases
1. 3GPP-Aligned Demo Use Case
Energy Savings via Enhanced Cell Sleep Mechanisms
- Demonstrates energy reduction at the base station power amplifier.
- Evaluates increased cell sleep opportunities.
- Quantifies real-time power savings during inactive traffic periods.
2. AI-RAN Demo Use Case
Energy Profiling of AI-Native vs. Traditional Receiver
- Measures energy consumption of:
- AI-native base station receiver
- Traditional (e.g., LMMSE-based) receiver
Key Feature of the Measurement Framework
All power and energy measurements are:
- Fully synchronized to a common time grid
- Aligned with the 500 µs slot grid of the 5G NR system
This synchronization enables:
- Slot-level energy analysis
- Accurate correlation between radio activity and power consumption
- Fine-grained energy profiling of PHY processing, RF transmission, and AI inference workloads
The DUT includes power sensors (GPU, CPU), a power supply, and an open-source 5G/6G stack from OpenAirInterface. It connects to NI USRP hardware and an external power amplifier. Power channels (AC/DC) are monitored for measurement.
- cRIO Controller 9047 for power calculation and data aggregation
- Measurement modules:
- NI-9244 — AC voltage (400 Vrms)
- NI-9238 — AC current (±500 mV)
- NI-9229 — DC voltage (±60 V)
- NI-9227 — DC current (5 Arms)
- Collects voltage and current measurements from gNB components
This Linux server handles:
- System configuration
- Test execution
- Data recording
- Data visualization
All measurement data is stored in a data lake with timestamps and metadata.
The UE runs an open-source 5G stack from OpenAirInterface and communicates with the gNB via NI USRP hardware over a wired or wireless RF channel.
Overall Workflow
The gNB and UE communicate over RF. The CompactRIO system measures power data from the gNB and sends it to the centralized data server for recording and analysis.
Demonstrator Setup
The left side of the setup contains the 5G base station prototype with an external switchable power amplifier. A computing platform equipped with an NVIDIA RTX 4090 GPU runs the 5G gNB software stack. Multiple cables connect the DUT to measurement equipment and RF interfaces.
The central upper part of the setup features the NI cRIO system with an attached breakout box for sensor connections. This equipment measures voltage, current, and power consumption from the DUT and forwards the data to the recording server.
The central lower section includes the NI Data Recording Entity, responsible for data orchestration, logging, aggregation, and visualization. A monitor above shows dashboards and measurement results.
On the right side is the 5G User Terminal (UE), which acts as the RF counterpart to the DUT. It connects through RF interfaces for 5G communication testing.
1. Wireless Scenario
- Single link between one gNB and one UE
- Wired RF connection
- No interference from:
- Neighboring cells
- Other UEs
2. Radio Configuration
Operating Band
- NR Band: n78
Waveform & Numerology
- Subcarrier Spacing (SCS): 30 kHz
- Waveform: CP‑OFDM
- Channel Bandwidth: 40 MHz
- Maximum PRBs: 106
3. Downlink (DL) Scheduling
- Scheduled DL PRBs:
- 20 PRBs
- 80 PRBs
- Switch interval: Every 10 frames
4. Uplink (UL) Scheduling
- Scheduled UL PRBs: 6 (kept low to ensure gNB Neural Rx real‑time performance)
- UL transmission bandwidth: ~2.16 MHz
5. TDD Configuration
DL/UL periodicity: 5 ms
TDD Slot & Symbol Structure
| Parameter | Value |
| nrofDownlinkSlots | 7 |
| nrofDownlinkSymbols | 6 |
| nrofUplinkSlots | 2 |
| nrofUplinkSymbols | 4 |
6. PUSCH Configuration
- Mapping type: B
- PUSCH duration: 13 OFDM symbols
- DMRS configuration:
- Type 1
dmrs-AdditionalPosition = pos2- DMRS positions: Symbols 0, 5, 11
1. OAI Base Station (gNB) – Linux Server 1
This server runs the OpenAirInterface gNB software stack. It includes an NVIDIA RTX 4000 GPU and connects to a USRP X410 via high-bandwidth 4×25 GbE (QSFP28 to 4×SFP28). RF paths pass through 20 dB attenuators and HDMI breakout connectors.
2. OAI Soft User Terminal (UE) – Linux Server 2
This subsystem runs the OAI software UE. It connects to another USRP X410 using dual-port 25 GbE NICs and the same 4×25 GbE optical links.
3. USRP X410 Radios
Two USRP X410 SDR units are used—one for the gNB and one for the UE. They interface via optical fiber and RF lines routed through attenuation and power amplification modules.
4. Data Recording – Linux Server 3
This server includes quad-port 10 GbE NICs and 10/25 GbE SFP28 links for capturing IQ, logs, and network traffic. USB-A to USB-C serial connections provide PA control. It exchanges control and logging data via 1GE Ethernet.
5. Fast Switching Power Amplifier
A Skyworks SKY67154 fast-switching PA is shown between RF attenuation blocks. It provides controlled RF gain for more realistic testing scenarios.
6. RF Attenuators and Breakout Hardware
The RF path includes multiple fixed 20 dB attenuators and adjustable 15–20 dB attenuators. HDMI breakout connectors are used for additional RF signal routing and measurement.
7. High-Speed NICs and Optical Links
The system uses QSFP28 to 4×SFP28 breakout cables, 10/25 GbE NICs, and quad-port NICs to transport high-rate IQ and control messages between servers and USRPs.
Power Monitoring Demonstrator – Materials Summary
The Power Monitoring Demonstrator integrates high‑performance servers, SDR radios, RF components, and NI measurement hardware to evaluate and monitor the power consumed during wireless 5G/6G operation. Servers provide compute and networking, USRPs generate and receive RF signals, and the cRIO system captures accurate AC/DC measurements. RF attenuators, cables, and accessories ensure safe and controlled signal flow during operation.
| Equipment | Type | Quantity |
| Server | Dell Precision 5860 Tower | 3 |
| Network Card (10GbE SFP+) | Intel X710 Quad Port 10GbE SFP+ Adapter | 1 |
| Eth Cable (SFP+) | 10G Eth Cable SFP+ 2m | 2 |
| SFP-to-RJ45 Adapter | SFP 1 Gigabit Ethernet Interface Kit / FCLF8522P2BTL | 1 |
| Network Card (25GbE SFP28) | Mellanox NIC 2×1/10/25GbE SFP28 (MCX512A-ACAT) | 4 |
| QSFP28 → 4×SFP28 Cable |
NVIDIA MCP7F00-A003R26N 100GbE to 4×25GbE, 3m or NI QSFP28→4×SFP28 Breakout (PN 788214-01) |
2 |
| NVIDIA GPU | NVIDIA GeForce RTX 4090 Founders Edition | 1 |
| Extra GPU Power Cable | COMeap 10‑pin to 8‑pin PCIe Cable (not required for Dell 5860) | 1 |
| NI USRP | USRP X410 | 2 |
| External Clock + PPS Source | OctoClock‑G CDA‑2990 | 1 |
| cRIO Power Measurement System | cRIO 9047 + NI 9238, NI‑9244, NI‑9229, NI‑9227 modules | 1 |
| RF Cables | SMA(M)‑to‑SMA(M) RF Cables (1m) | 7 |
| 20 dB RF Attenuators | SMA‑F to SMA‑M Attenuators | 2 |
| 10 dB RF Attenuators | SMA‑F to SMA‑M Attenuators | 2 |
| Switchable Power Amplifier | Skyworks PA SKY67154 | 1 |
| AC Current Clamps | Magnelab SCT‑0750‑020 | 2 |
| HDMI Breakout Connector | 19‑pin HDMI Terminal Block Adapter | 1 |
| USB‑C to USB‑A Cable | Standard | 1 |
| Network Switch (Optional) | 4+ Ethernet Ports (for demo / remote access) | 1 |
| 1G Ethernet Cables | Standard | 4 |
System Overview
This testbed implements a complete 5G NR gNB ↔ UE link in a wired back-to-back configuration using Open Air Interface (OAI) software. Three Linux servers handle baseband processing, user terminal emulation, and data recording respectively. Two USRP X410 units serve as the RF front-ends, connected through attenuators and a fast-switching power amplifier.
Hardware Components
Linux Server 1 - OAI Base Station
- Runs the OAI gNB 5G NR stack
- Equipped with Nvidia RTX 4090 GPU for real-time baseband acceleration (LDPC, FFT, channel estimation)
- Connected to USRP X410 via 4×25GbE QSFP28 → 4×SFP28 breakout cable
- Controls the Fast Switching PA via HDMI breakout connector + GPIO wires
Linux Server 2 - OAI Soft User Terminal (UE)
- Runs the OAI UE software stack (soft user terminal)
- Mirror configuration to Server 1
Linux Server 3 — Data Recording
- Central logging, packet capture, and experiment orchestration server
- Connects to both Server 1 and Server 2 via 10/25GbE SFP28 or 10GbE SFP+
- Connects to auxiliary small chassis via 1GbE and USB-A → USB-C serial
USRP X410 (×2)
- NI/Ettus Software Defined Radio units acting as the RF front-end
- One unit per server (gNB side and UE side)
- I/Q samples streamed over high-speed SFP28 links
Fast Switching PA — Skyworks SKY67154
- Wideband GaAs power amplifier on a custom breakout PCB
- GPIO-controlled via HDMI breakout from Server 1
- Enables TDD-synchronized TX/RX switching aligned to 5G NR slot timing
Attenuators
| Position | Value | Purpose |
| gNB TX output | 20 dB | Prevent USRP X410 TX overdrive |
| PA output (DL) | 15–20 dB | Protect UE-side USRP RX input |
| UE TX output (UL) | 20 dB | Protect gNB-side USRP RX input |
NI cRIO (CompactRIO)
Connected to Server 3 via 1GbE (192.168.120.2) and USB-C serial console. The NI cRIO acts as a real-time embedded controller used for low-latency hardware control, timing synchronization, and auxiliary I/O management within the testbed.
Network Interfaces
Server 1 ↔ Server 3 (Management / Data)
| Parameter | Value |
| Server 1 IP | 192.168.100.2
| Server 3 IP | 192.168.100.1
| Link Type | 10/25GbE SFP28 or 10GbE SFP+ |
Server 2 ↔ Server 3 (Management / Data)
| Parameter | Value |
| Server 2 IP | 192.168.110.2
| Server 3 IP | 192.168.110.1
Server 1 ↔ USRP X410 (Fronthaul)
| Parameter | Value |
| Server 1 IPs | 192.168.10.2 / 192.168.11.2
| USRP X410 IPs | 192.168.10.1 / 192.168.11.1
| Link Type | 4×25GbE QSFP28 → 4×SFP28 |
Server 2 ↔ USRP X410 (Fronthaul)
| Parameter | Value |
| Server 2 IPs | 192.168.10.2 / 192.168.11.2
Server 3 ↔ NI cRIO
| Parameter | Value |
| Server 3 IP | 192.168.120.1
| NI cRIO IP | 192.168.120.2
| Link Type | 1GbE + USB-A → USB-C Serial |
RF Signal Chain
Downlink (gNB TX → UE RX)
USRP X410 (Server 1)
20 dB Attenuator
Fast Switching PA (Skyworks SKY67154)
15–20 dB Attenuator
USRP X410 (Server 2)
Uplink (UE TX → gNB RX)
20 dB Attenuator
Note: The Fast Switching PA is only in the downlink path. The HDMI breakout connector carries GPIO control signals from Server 1 to enable time-synchronized PA switching per 5G TDD frame structure.
IP Address Reference
| Device | Interface | IP Address |
| Server 1 | To Server 3 | 192.168.100.2
| Server 1 | To USRP P1 | 192.168.10.2
| Server 1 | To USRP P2 | 192.168.11.2
| Server 2 | To Server 3 | 192.168.110.2
| Server 2 | To USRP P1 | 192.168.10.2
| Server 2 | To USRP P2 | 192.168.11.2
| Server 3 | To Server 1 | 192.168.100.1
| Server 3 | To Server 2 | 192.168.110.1
| Server 3 | To NI cRIO | 192.168.120.1
| USRP X410 (gNB) | P1 | 192.168.10.1
| USRP X410 (gNB) | P2 | 192.168.11.1
| USRP X410 (UE) | P1 | 192.168.10.1
| USRP X410 (UE) | P2 | 192.168.11.1
| NI cRIO | To Server 3 | 192.168.120.2
