Revision as of 10:25, 24 March 2026 by MichaelDickens (Talk | contribs) (Operating Temperature Range: update B2x0 temp range to match that (roughly) of other B* USRPs)
B200
B210
B200mini
B200mini-i
B205mini-i
B206mini-i
Frontend Specifications
Tuning
The RF frontend has individually tunable receive and transmit chains. On the B200/200mini/205mini/206mini, there is one transmit and one receive RF frontend. On the B210, both transmit and receive can be used in a MIMO configuration. For the MIMO case on the B210 only, both receive frontends share the RX LO, and both transmit frontends share the TX LO. Each LO is independently tunable between 50 MHz and 6 GHz and can be used with 1 or 2 channels; all channels using the same LO must use the same sampling parameters, including the sample rate and RF center frequency.
Gains
Bandwidths
The USRP B200/210/200mini/205mini/206mini are derived from the Analog devices AD936x integrated transceiver chip. The overall RF performance of the device is largely governed by the transceiver chip itself.
RF Performance
  • B206mini RF specifications
  • B200mini/205mini RF specifications
  • B200/210 RF specifications
  • SSB/LO Suppression: It is based on the AD9364 performance. Refer AD9364 Datasheet and Reference Manual for more information.
  • Tx Phase Noise:
    • B200mini/205mini/206mini
      Above 1.5 GHz, to achieve optimized transmit (TX) phase noise performance, it is recommended to tune the USRP device to center frequencies that are integer multiples of internal clock signals.
      For best results, use tuning frequencies that are integer multiples of the following step sizes:
      • 1.5GHz to 3GHz: 20MHz step size
      • 3GHz to 6GHz: 40MHz step size
Input/Output Impedance
All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
  • The maximum input power for the B200/210/200mini/205mini/206mini is -15 dBm.
RF Performance Data
B200mini / B205mini / B206mini
B200 / B210
Hardware Specifications
B200
  • Current Hardware Revision: 6
  • Minimum version of UHD required: 3.8.4
  • B200 Rev 5 (AD9364-based board) requires minimum UHD 3.8.4
B210
  • Current Hardware Revision: 5
  • Minimum version of UHD required: 3.6.0
B200mini
  • Current Hardware Revision: 2
  • Minimum version of UHD required: 3.9.0
B200mini-i
B205mini-i
  • Minimum version of UHD required: 3.9.2
B206mini-i
  • Minimum version of UHD required: 4.9.0
Physical Specifications
Dimensions
  • B206mini-i
    • 8.4 x 5.1 x 0.8 cm (Board-only)
    • 8.5 x 5.5 x 1.8 cm (Enclosed)
Weight
  • B206mini
    • Enclosed 108 g
    • Board-only 25 g
  • B200mini 24.0 g
  • B200/B210 350 g
Drawings
B206mini-i
B200mini
B200
B210
B200/B210 Enclosure
CAD/STP Models
B206mini-i
B200mini
B20xmini-i
B200
B210
B200/B210 Enclosure
Environmental Specifications
  • B200 / B210: 0 - 40 °C
  • B200mini - Board Only: 0 - 40 °C
  • B200mini - With Enclosure: -20 - 60°C
  • B200mini-i / B205mini-i / B206mini - Board Only: 0 - 45 °C
  • B200mini-i / B205mini-i / B206mini - With I-Grade Enclosure: -40 - 75°C
Operating Humidity Range
  • 10% to 90% non-condensing
B200mini/B200mini-i/B205mini-i
B200mini/B200mini-i/B205mini-i Schematics
B200/B210
B200/B210 Schematics
Key Component Datasheets
Mini-Circuits TCM1-63AX+ Transformer T1 (1,3); T2 (1,3)
Analog Devices AD9364 RF Transceiver U1 (2)
Analog Devices AD9361 RF Transceiver U2 (2,8)
AD9361/AD9364 Product Page RF Transceiver -
Xilinx Spartan-6 Product Page FPGA U1 (2,3,4,6); PG1 (6); U18B, U18C (7); U18D (8); U18E, U18F (9); U18G, U18H (10)
XC6SLX75 / XC6SLX150 FPGA
ADF4001 Frequency Synthesizer U101 (1)
CYUSB3014 FX3: SuperSpeed USB Controller U3 (5,6); U13 (5)
EZ-USB FX3™ Product Page
SKY13317 Antenna Switch U801, U810 (8)
BD3150L50100A00 Balun U802, U808, U809, U815 (8)
PGA−102+ Amplifier U804, U817 (8)
VCTCXO VCTCXO (B200mini only) -
525L20DA40M0000 VCTCXO (B200/B210 only) X100 (1)
Jackson Labs LC_XO Spec Sheet Manual Optional GPSDO (B200/B210 only) U100 (1)
Enclosures
  • SMA connectors should be torqued to 4 inch-pounds
B206mini-i
B200mini
B205mini
B200/B210
  • USRP B200/B210 Enclosure
    • Full Steel Enclosure
FPGA
  • Utilization statistics are subject to change between UHD releases. This information is current as of UHD 3.9.4.
B200
Device utilization summary:
Slice Logic Utilization:
Slice Logic Distribution:
IO Utilization:
Specific Feature Utilization:
B210
IO Utilization:
B200mini
IO Utilization:
B205mini/B206mini
IO Utilization:
Interfaces and Connectivity
B200/B210/B200mini/B206mini - USB 3.0
GPIO
Power on state
Output Current
The GPIOs are configured as LVCMOS33 outputs with pull-ups on the B2xx. The strength for LVCMOS and LVTTL on Spartan 6 is 12 mA if not otherwise specified.
Timing Reference Input
B200mini/B200mini-i/B205mini-i/B206mini-i
  • 1-PPS or 10 MHz input
1-PPS
  • Maximum: -5V / +5V
  • Minimum: 0V / +2.5V
10 MHz
  • Maximum: 0V / +5V
  • Minimum: 0V / +1.8V
OR
  • +10dBm ~ +27dBm
B200/B210
1-PPS
  • Maximum: 5V
10 MHz
  • Maximum: 15dBm (3.5Vpp into 50 ohms)
China RoHS
Chinese Customers
Certifications for European Union
In order to ensure compliance with EU certifications for radio equipment, a ferrite bead (included in kits with NI part number 785825-01 and 785826-01) should be affixed onto the GPIO cable, if in use. This is achieved by opening the snap-on ferrite bead and enclosing it around the GPIO cable(s).
In addition to the part numbers listed above, these ferrite beads can be sourced through Fair-Rite using part number 0443164251.
Certificate of Volatility
Found on the NI Product Certifications lookup tool:
Downloads
FPGA Resources
UHD Stable Binaries
UHD Source Code on Github
FAQ
The performance and throughput of USB 3.0 can vary between host controllers. Ettus Research recommends using the Intel Series 7, 8, and 9 USB controllers. In Linux, the command lspci will show the USB controller on the system.
When can I power the USRP B200/B210/B200mini off USB?
The experience will vary across various controllers. Generally speaking, bus-power is ideal for SISO operation. If you are using both channels of a USRP B210 we recommend an external power supply. We sell an external power supply that works with a variety of USRPs.
MIMO operation with the USRP B210 is not recommended when using the USRP B210 on bus-power. It is also not recommended to run the B210 on bus-power if a GPS-disciplined oscillator is installed.
1 RX 1.92 2.112 2.184 2.508
2 RX 2.148 2.436 2.508 2.64
1 TX 2.184 2.34 2.352 2.22
2 TX 2.76 2.88 2.904 2.64
The USRP B200/B210 is supported on Linux, OSX (MacOSX / macOS) and Windows.
