E310/E312
[hide]Device Overview
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment. The flexible 2x2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest.
- Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 667 MHz dual-core processor
- Analog Devices AD9361 RFIC direct-conversion transceiver
- Frequency range: 70 MHz - 6 GHz
- Up to 56 MHz of instantaneous bandwidth
- 2x2 MIMO transceiver
- Up to 10 MS/s sample data transfer rate to ARM processor
- RX, TX filter banks
RF Performance
- Power Output >10dBm
- IIP3 (@ typ NF) -20dBm
- Typical Noise Figure <8dB
Digital Specifications
Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum? Lorem ipsum dolor sit amet, consectetur adipisicing elit. Quod voluptates molestias excepturi nisi ea minus hic iste velit optio doloremque similique ab nulla, beatae obcaecati! Nobis, at dolorum id nostrum?
Physical Specifications
Dimensions
- 133 x 68 x 26.4 mm
Environmental Specifications
- E310 0-40 °C
E310
Key Components
Datasheets
InvenSense MPU-9150 Product Page
Request a detailed whitepaper covering features and components from info@ettus.com
Mechanical Info
Weight
- Partial Enclosure 225 g
- Full Enclosure 375 g
Drawings
- E310 Drawings - File:E310 Dimensional Sketches.pdf
FPGA (MB only)
Interfaces and Connectivity
- 10/100/1000 BASE-T Ethernet
- Stereo audio out, mono mic in
- Integrated GPS receiver
- Host USB support
- 9-axis IMU
Performance Data (DB only)
Downloads
[ ADD E310 FPGA IMAGES ]
