OBX
The OBX 160 daughterboard is a full-duplex wideband transceiver that covers frequencies from 10 MHz to 8.4 GHz with up to 160 MHz* of instantaneous bandwidth. Coherent and phase-aligned operation across multiple OBX daughterboards enables users to explore MIMO and direction finding applications. The OBX 160 daughterboard works interchangeably with other USRP daughterboards and is compatible with the USRP X300 Series devices.
The OBX is capable of phase coherent operation, and therefore is suitable for MIMO and Phased Array applications.
For getting started information and installation instructions please visit OBX Getting Started Guides
Daughterboard Specifications
Features
Antennas
Transmit: TX/RX
Receive: TX/RX or RX2
- Note: The user may set the receive antenna to be TX/RX or RX2. However, when using a OBX board in full-duplex mode, the receive antenna will always be set to RX2, regardless of the settings.
Gains
- Transmit Gains: PGA0, Range: 0-31.5dB
Bandwidths
- OBX-160: 160 MHz, RX & TX
- Note: The OBX 160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
Sensors
LEDs
- LOCK: Synthesizer Lock Detect
- TX/RX TXD: Transmitting on TX/RX antenna port
- TX/RX RXD: Receiving on TX/RX antenna port
- RX2 RXD: Receiving on RX2 antenna port
Specifications
Please refer to the OBX specifications document OBX-160 Specifications / Datasheet
OBX-160
- Minimum version of UHD required for OBX: 4.9.0
Environmental Specifications
- 0-40 °C
Operating Humidity Range
- 10% to 90% non-condensing
Phase Synchronization
The OBX daughterboard is capable of phase-synchronous operation, and is recommended for phase-coherent applications. The UBX daughterboards are also recommended for phase-coherent applications.
If you are operating the OBX at frequencies below 1 GHz and need phase synchronization, then it is necessary to select a 20 MHz daughterboard clock rate, instead of using the default 50 MHz rate. Note that this is only required for phase synchronization below 1 GHz. The OBX can still operate below 1 GHz without setting this lower daughterboard clock rate, but it will operate without any phase synchronization capability.
If you're using a UHD program, then you can specify the lower daughterboard clock rate on the command line of the program, with --args="dboard_clock_rate=20e6".
If you're using the UHD API from a C++ program, then you can include "dboard_clock_rate=20e6" in the device arguments parameter when first invoking multi_usrp::make().
If you're using GNU Radio, then you can add "dboard_clock_rate=20e6" to the "Device Arguments" field of the properties for the UHD Sink and UHD Source blocks.
Schematics are available for legitimate reasons under NDA; please submit a request via NI Support.
Key Component Datasheets
In work, for urgent requests please contact NI Support
Mechanical Information
Drawings
China RoHS
Chinese Customers
Letter of Volatility
OBX-160
Important Notes
The OBX-160 transmitter path has 160 MHz of bandwidth throughout the full frequency range of the device; the receiver path has 84 MHz of bandwidth for center frequencies from 10 MHz to 500 MHz.
