E320
Revision as of 13:38, 26 June 2026 by MichaelDickens (Talk | contribs) (Schematics)
The USRP E320 brings performance to embedded software defined radios by offering four times more FPGA resources compared to the USRP E31x devices. The USRP E320 also introduces improvements in streaming, synchronization, integration, fault-recovery, and remote management capability. This field deployable SDR continues to use the flexible 2x2 MIMO AD9361 transceiver from Analog Devices, which covers frequencies from 70 MHz – 6 GHz and provides up to 56 MHz of instantaneous bandwidth.
E320
  • Xilinx Zynq 7045 SoC
    • 7 Series FPGA with 2GB DDR3 RAM
    • ARM Cortex A9 800 MHz dual-core processor
  • 2x2 MIMO transceiver
  • Up to 10 MS/s sample data transfer rate to ARM processor
  • Up to 61.44 MS/s sample data transfer to host (10Gb/SFP+)
  • RX, TX filter banks
  • Integrated GPSDO
  • 9-axis inertial measurement unit
  • RF Network on Chip (RFNoC™) FPGA development framework support
  • Board-only and Full Enclosure Options
RF Performance
  • Power Output >10dBm
  • IIP3 (@ typical NF) -20dBm
  • Typical Receive Noise Figure <8dB
Input Power Levels
  • The maximum input power for the E320 is -15 dBm.
Hardware Specifications
  • UHD version on the host computer must match what is running on the E320
E320
  • Minimum version of UHD required: 3.14.0.0
Physical Specifications
Dimensions
E320 board-only with heatsink
  • 173 x 100 x 36 mm
E320 Full enclosure
  • 175 x 106 x 38 mm
Weight
  • 0.16 kg
E320 Full enclosure
  • 0.86 kg
Drawings
E320
E320 Enclosure
CAD/STP Models
E320
E320 Enclosure
Environmental Specifications
  • 0-45 °C
Non-Operating Temperature Range
  • -40-85 °C
Operating Humidity Range
  • 10% to 90% non-condensing
Non-Operating Humidity Range
  • 5% to 95% non-condensing
Schematics and certain other more in-depth USRP documentation is available under non-disclosure agreement (NDA) and per specific request only. Please submit a request via the Support Request Manager.
GPSDO
  • Support GPSDO NMEA Strings
Sensors
Specifications
Module Specifications
1 PPS Timing Accuracy from GPS receiver <8ns to UTC RMS (1-Sigma) GPS Locked
Holdover Stability (1 week with GPS) <±50us over 3 Hour Period @+25°C (No Motion, No Airflow)
1 PPS Output 3.3VDC CMOS
Serial Port TTL Level, GPS NMEA Output with 1Hz or 5Hz update rate, Integrated into UHD
GPS Frequency L1, C/A 1574MHz
GPS Antenna Active (3V compatible) or Passive (0dB to +30dB gain)
GPS Receiver 65 Channels, QZSS, SBAS WAAS, EGNOS, MSAS capable
Supports Position and Hold over-determined clock mode
Sensitivity Acquisition -148dBm, Tracking -165dBm
TTFF Cold Start: <32 sec, Warm Start: 1 sec, Hot Start: 1 sec
ADEV 10s: <7E-011
10Ks: <2E-012 (GPS Locked, 25°C, no motion, no airflow)
Warm Up Time / Stabilization Time <10 min at +25C to 1E-09 Accuracy
Supply Voltage (Vdd) 3.3V Single-Supply, +0.2V/-0.15V
Power Consumption <0.16W
Operating Temperature -10°C to +70°C
Storage Temperature -45C to 85C
Oscillator Specifications (internal)
Frequency Output of low Phase Noise crystal 20MHz CMOS 3Vpp
20MHz Retrace ±2E-08 After 1 Hour @ +25°C without GPS
RF Output Amplitude 3Vpp CMOS
20MHz Phase Jitter (100Hz to 10MHz) <0.135ps rms
Frequency Stability Over Temperature (0°C to +60°C) ±0.1ppm (internal TCXO without GPS)
Warm Up Time < 1 min at +25C
Phase Noise at 20MHz 1Hz -65 dBc/Hz
10Hz -97 dBc/Hz
100Hz -116 dBc/Hz
1kHz -136 dBc/Hz
10kHz <-148 dBc/Hz
100 kHz <-155 dBc/Hz
Datasheet
Frontend Specifications
Tuning
Gains
Interfaces and Connectivity
  • RJ45 (1 GbE)
  • SFP+ (1/10 GbE, Aurora)
  • Type A USB Host
  • Micro-USB (serial console, JTAG)
  • GPIO
  • Integrated GPSDO
  • 9-axis IMU
Front Panel
  • PWR: Power button
  • RF A Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend side A
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend side A
  • RF B Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend B
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend B
  • PPS IN: Input port for external PPS signal
  • REF IN: Input port for external 10 MHz signal
  • GPS ANT: Connection for the GPS antenna
Rear Panel
  • POWER: 10-14v DC Power connector
  • GPIO: Mini-HDMI connector for GPIO
  • USB: USB 2.0 Port
  • 1G ETH: RJ45 port for remote management
  • SFP+: SFP+ connection for sample streaming
  • CONSOLE JTAG: Micro USB connection for serial UART/JTAG console
Power Connector
Model: PDP-40 by CUI Inc.
Power plug connectors for custom power harnesses can be purchased here: https://www.digikey.com/products/en?KeyWords=CP-7340-ND&WT.z_cid=sp_102_buynow
Assembly instructions: Media:pdp-40.pdf
Pin Detail
  • Pins #1 / #2: 12v
  • Pins #3 / #4: Ground
Guidance on SFP+ Adapters for Fiber Connectivity on USRP E320
Ettus Research currently offers direct-connect, copper cabling accessories for the USRP E320. However, it is also possible to use multi-mode fiber instead of copper connections for these devices. In this section, we will provide general guidance on the types of fiber adapters and cables that can be used with these products.
The USRP E320 USRP is compatible with most brands of SFP+ fiber adapters. In some cases, other equipment in the systems such as 1/10 Gigabit Ethernet switches are only compatible with specific brands of SFP+ adapters and cables. As a general rule, we recommend checking compatibility with the switches and network cards in your system before purchasing an adapter.
Ettus Research does test the USRP E320 USRP devices with our 10 Gigabit Ethernet Connectivity Kit and a Blade Networks G8124 1/10 GigE switch. Here are is a list of known-good cables and adapters.
Known-Good Adapters
Known-Good Cables
Guidance on 10Gb SFP+ to RJ45 Adapters
Known-Good Adapters
China RoHS
Chinese Customers
Certificate of Volatility
Found on the NI Product Certifications lookup tool here.
