- 1 Device Overview
- 2 Key Features
- 3 Frontend Specifications
- 4 RF Specifications
- 5 Hardware Specifications
- 6 Physical Specifications
- 8 Schematics
- 9 Key Component Datasheets
- 10 Enclosures
- 11 FPGA
- 13 Certifications
- 15 Downloads
- 16 FAQ
B200
B210
B200mini
B200mini-i
B205mini-i
B206mini-i
Tuning
The RF frontend has individually tunable receive and transmit chains. On the B200/200mini/205mini/206mini, there is one transmit and one receive RF frontend. On the B210, both transmit and receive can be used in a MIMO configuration. For the MIMO case on the B210 only, both receive frontends share the RX LO, and both transmit frontends share the TX LO. Each LO is independently tunable between 50 MHz and 6 GHz and can be used with 1 or 2 channels; all channels using the same LO must use the same sampling parameters, including the sample rate and RF center frequency.
Gains
Bandwidths
The USRP B200/210/200mini/205mini/206mini are derived from the Analog devices AD936x integrated transceiver chip. The overall RF performance of the device is largely governed by the transceiver chip itself.
RF Performance
- B206mini RF specifications
- B200mini/205mini RF specifications
- B200/210 RF specifications
- SSB/LO Suppression: It is based on the AD9364 performance. Refer AD9364 Datasheet and Reference Manual for more information.
- Tx Phase Noise:
- B200mini/205mini/206mini
Above 1.5 GHz, to achieve optimized transmit (TX) phase noise performance, it is recommended to tune the USRP device to center frequencies that are integer multiples of internal clock signals.
For best results, use tuning frequencies that are integer multiples of the following step sizes:- 1.5GHz to 3GHz: 20MHz step size
- 3GHz to 6GHz: 40MHz step size
Input/Output Impedance
All RF Ports are matched to 50 Ohm with -10dB or better return loss generally. Detailed test is pending.
Input Power Levels
- The maximum input power for the B200/210/200mini/205mini/206mini is -15 dBm.
RF Performance Data
B200mini / B205mini / B206mini
B200 / B210
B200
- Current Hardware Revision: 6
- Minimum version of UHD required: 3.8.4
- B200 Rev 5 (AD9364-based board) requires minimum UHD 3.8.4
B210
- Current Hardware Revision: 5
- Minimum version of UHD required: 3.6.0
B200mini
- Current Hardware Revision: 2
- Minimum version of UHD required: 3.9.0
B200mini-i
B205mini-i
- Minimum version of UHD required: 3.9.2
B206mini-i
- Minimum version of UHD required: 4.9.0
Dimensions
- B206mini-i
- 8.4 x 5.1 x 0.8 cm (Board-only)
- 8.5 x 5.5 x 1.8 cm (Enclosed)
- B200mini/B205mini 5.0 x 8.4 cm
- B200/B210 9.7 x 15.5 x 1.5 cm
Weight
- B206mini
- Enclosed 108 g
- Board-only 25 g
- B200mini 24.0 g
- B200/B210 350 g
Drawings
B206mini-i
B200mini
B200
B210
B200/B210 Enclosure
CAD/STP Models
B206mini-i
B200mini
B20xmini-i
B200
B210
B200/B210 Enclosure
- B200 / B210: 0 - 40 °C
- B200mini - Board Only: 0 - 40 °C
- B200mini - With Enclosure: -20 - 60°C
- B200mini-i / B205mini-i / B206mini - Board Only: 0 - 45 °C
- B200mini-i / B205mini-i / B206mini - With I-Grade Enclosure: -40 - 75°C
Operating Humidity Range
- 10% to 90% non-condensing
For detailed design files such as schematics and certain other more in-depth USRP documentation submit a request via the Support Request Manager.
| Mini-Circuits TCM1-63AX+ | Transformer | T1 (1,3); T2 (1,3) |
| Analog Devices AD9364 | RF Transceiver | U1 (2) |
| Analog Devices AD9361 | RF Transceiver | U2 (2,8) |
| AD9361/AD9364 Product Page | RF Transceiver | - |
| Xilinx Spartan-6 Product Page | FPGA | U1 (2,3,4,6); PG1 (6); U18B, U18C (7); U18D (8); U18E, U18F (9); U18G, U18H (10) |
| XC6SLX75 / XC6SLX150 | FPGA | |
| ADF4001 | Frequency Synthesizer | U101 (1) |
| CYUSB3014 | FX3: SuperSpeed USB Controller | U3 (5,6); U13 (5) |
| EZ-USB FX3™ Product Page | ||
| SKY13317 | Antenna Switch | U801, U810 (8) |
| BD3150L50100A00 | Balun | U802, U808, U809, U815 (8) |
| PGA−102+ | Amplifier | U804, U817 (8) |
| VCTCXO | VCTCXO (B200mini only) | - |
| 525L20DA40M0000 | VCTCXO (B200/B210 only) | X100 (1) |
| Jackson Labs LC_XO Spec Sheet Manual | Optional GPSDO (B200/B210 only) | U100 (1) |
Enclosures
- SMA connectors should be torqued to 4 inch-pounds
B206mini-i
B200mini
B205mini
B200/B210
- USRP B200/B210 Enclosure
- Full Steel Enclosure
- Compatible with green USRP B200 and B210 devices (revision 6 or later)
- Front and rear K-Slots for anti-theft protection
FPGA
- Utilization statistics are subject to change between UHD releases. This information is current as of UHD 3.9.4.
B200
Device utilization summary:
Selected Device : 6slx75fgg484-3
Slice Logic Utilization:
Number of Slice Registers: 15781 out of 93296 16%
Number of Slice LUTs: 19987 out of 46648 42%
Number used as Logic: 15983 out of 46648 34%
Number used as Memory: 4004 out of 11072 36%
Number used as RAM: 972
Number used as SRL: 3032
Slice Logic Distribution:
Number of LUT Flip Flop pairs used: 24062
Number with an unused Flip Flop: 8281 out of 24062 34%
Number with an unused LUT: 4075 out of 24062 16%
Number of fully used LUT-FF pairs: 11706 out of 24062 48%
Number of unique control sets: 434
IO Utilization:
Number of IOs: 172
Number of bonded IOBs: 155 out of 280 55%
IOB Flip Flops/Latches: 124
Specific Feature Utilization:
Number of Block RAM/FIFO: 144 out of 172 83%
Number using Block RAM only: 144
Number of BUFG/BUFGCTRLs: 4 out of 16 25%
Number of DSP48A1s: 76 out of 132 57%
B210
Selected Device : 6slx150fgg484-3
Number of Slice Registers: 29310 out of 184304 15%
Number of Slice LUTs: 36486 out of 92152 39%
Number used as Logic: 29279 out of 92152 31%
Number used as Memory: 7207 out of 21680 33%
Number used as RAM: 1752
Number used as SRL: 5455
Number of LUT Flip Flop pairs used: 43635
Number with an unused Flip Flop: 14325 out of 43635 32%
Number with an unused LUT: 7149 out of 43635 16%
Number of fully used LUT-FF pairs: 22161 out of 43635 50%
Number of unique control sets: 723
IO Utilization:
Number of IOs: 180
Number of bonded IOBs: 163 out of 338 48%
IOB Flip Flops/Latches: 148
Number of Block RAM/FIFO: 186 out of 268 69%
Number using Block RAM only: 186
Number of DSP48A1s: 152 out of 180 84%
B200mini
Selected Device : 6slx75csg484-3
Number of Slice Registers: 15949 out of 93296 17%
Number of Slice LUTs: 19963 out of 46648 42%
Number used as Logic: 16140 out of 46648 34%
Number used as Memory: 3823 out of 11072 34%
Number used as SRL: 2851
Number of LUT Flip Flop pairs used: 23859
Number with an unused Flip Flop: 7910 out of 23859 33%
Number with an unused LUT: 3896 out of 23859 16%
Number of fully used LUT-FF pairs: 12053 out of 23859 50%
Number of unique control sets: 429
IO Utilization:
Number of IOs: 123
Number of bonded IOBs: 114 out of 328 34%
IOB Flip Flops/Latches: 147
Number of Block RAM/FIFO: 110 out of 172 63%
Number using Block RAM only: 110
Number of BUFG/BUFGCTRLs: 6 out of 16 37%
Number of PLL_ADVs: 1 out of 6 16%
B205mini/B206mini
Selected Device : 6slx150csg484-3
Number of Slice Registers: 15949 out of 184304 8%
Number of Slice LUTs: 19963 out of 92152 21%
Number used as Logic: 16140 out of 92152 17%
Number used as Memory: 3823 out of 21680 17%
IO Utilization:
Number of IOs: 123
Number of bonded IOBs: 114 out of 338 33%
Number of Block RAM/FIFO: 110 out of 268 41%
Number of DSP48A1s: 76 out of 180 42%
B200/B210/B200mini/B206mini - USB 3.0
GPIO
Power on state
Output Current
The GPIOs are configured as LVCMOS33 outputs with pull-ups on the B2xx. The strength for LVCMOS and LVTTL on Spartan 6 is 12 mA if not otherwise specified.
Timing Reference Input
B200mini/B200mini-i/B205mini-i/B206mini-i
- 1-PPS or 10 MHz input
1-PPS
- Maximum: -5V / +5V
- Minimum: 0V / +2.5V
10 MHz
- Maximum: 0V / +5V
- Minimum: 0V / +1.8V
OR
- +10dBm ~ +27dBm
B200/B210
1-PPS
- Maximum: 5V
10 MHz
- Maximum: 15dBm (3.5Vpp into 50 ohms)
China RoHS
Chinese Customers
Certifications for European Union
In order to ensure compliance with EU certifications for radio equipment, a ferrite bead (included in kits with NI part number 785825-01 and 785826-01) should be affixed onto the GPIO cable, if in use. This is achieved by opening the snap-on ferrite bead and enclosing it around the GPIO cable(s).
In addition to the part numbers listed above, these ferrite beads can be sourced through Fair-Rite using part number 0443164251.
Found on the NI Product Certifications lookup tool:
Downloads
FAQ
This is a list of frequently asked questions on the USRP B200/B210/B200mini. If you have questions that are not answered in this document, please contact us - [email protected].
The performance and throughput of USB 3.0 can vary between host controllers. Ettus Research recommends using the Intel Series 7, 8, and 9 USB controllers. In Linux, the command lspci will show the USB controller on the system.
When can I power the USRP B200/B210/B200mini off USB?
The experience will vary across various controllers. Generally speaking, bus-power is ideal for SISO operation. If you are using both channels of a USRP B210 we recommend an external power supply. We sell an external power supply that works with a variety of USRPs.
MIMO operation with the USRP B210 is not recommended when using the USRP B210 on bus-power. It is also not recommended to run the B210 on bus-power if a GPS-disciplined oscillator is installed.
| 5 Msps | 15.36 Msps | 30.72 Msps | 56 Msps | 61.44 Msps | |
| 1 RX | 1.92 | 2.112 | 2.184 | 2.508 | |
| 2 RX | 2.148 | 2.436 | 2.508 | 2.64 | |
| 1 TX | 2.184 | 2.34 | 2.352 | 2.22 | |
| 2 TX | 2.76 | 2.88 | 2.904 | 2.64 | |
| Full Duplex (1x1) | 2.508 | 2.736 | 2.796 | 3.168 | |
| 2x2 MIMO | 3.252 | 3.588 | 3.672 | 4.11 | 4.092 |
The USRP B200/B210 is supported on Linux, OSX (MacOSX / macOS) and Windows.
