B100
Revision as of 14:23, 26 June 2026 by MichaelDickens (Talk | contribs)
End-of-Life (EOL)
Please note that this product is now End-of-Life (EOL), and is no longer available for sale through Ettus Research, and is not recommended for use in new designs or in new projects.
USRP B100
- 16 MHz of RF bandwidth with 8 bit samples
- 8 MHz of RF bandwidth with 16 bit samples
- USB 2.0 high speed connectivity
- Motherboard has one RTX daughterboard slot (1 RX + 1 TX connectors)
- Onboard FPGA processing
- FPGA: Xilinx Spartan 3A-1400 FPGA
- ADCs: 12-bits 64 MS/s
- DACs: 14-bits 128 MS/s
- Ability to lock to external 5 or 10 MHz clock reference
- TCXO Frequency Reference (~2.5ppm)
- Flexible clocking from 10 MHz to 64 MHz
- FPGA code can be changed with Xilinx® ISE® WebPACK™ tools
FPGA
- Utilization statistics are subject to change between UHD releases, current as of UHD 3.9.4
B100
Device utilization summary:
Selected Device : 3s1400aft256-4
Number of Slices: 10238 out of 11264 90%
Number of Slice Flip Flops: 12136 out of 22528 53%
Number of 4 input LUTs: 18184 out of 22528 80%
Number used as logic: 15003
Number used as Shift registers: 2605
Number used as RAMs: 576
Number of IOs: 150
Number of bonded IOBs: 148 out of 161 91%
IOB Flip Flops: 140
Number of BRAMs: 31 out of 32 96%
Number of MULT18X18SIOs: 20 out of 32 62%
Number of GCLKs: 2 out of 24 8%
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The USRP B100 is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the USRP B100 can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
| Never apply more than -15 dBm of power into any RF input. | |
