TwinRX Getting Started Guides
Revision as of 15:52, 26 June 2026 by MichaelDickens (Talk | contribs)
Kit Contents
  • TwinRX Daughterboard
  • Two Front panel cables (1.4” SMA BH female to MMCX RA male)
  • Two Front panel washer and bolts
  • Two LO sharing cables (5” MMCX RA male to MMCX RA male)
  • Screw kit
  • Hardware installation guide
  • Getting started guide
USRP Compatibility
  • USRP X300/X310
Hardware Setup
For complete step by step instructions to installing a daughterboard, please see the TwinRX Module Installation Guide, or the USRP X Series Quick Start (Daughterboard Installation) guide.
Local Oscillator Connectors
Note: LO sharing cables are not required for a single TwinRX setup. LO sharing cables are only required with two TwinRX daughterboards in a single USRP X300/X310.
Connector Description Min Nominal Damage
J1 LO2 Export 0 dBm 0 dBm NA (Output)
J2 LO2 Input 0 dBm +20dBm
J3 LO1 Export -12 dBm +5 dBm NA (Output)
J4 LO1 Input -10 dBm -5 dBm +10dBm
LO Sharing with Neighbour TwinRXs
TwinRX (A Slot) TwinRX (B Slot)
J1 LO2 Export J2 LO2 Input
J2 LO2 Input J1 LO2 Export
J3 LO1 Export J4 LO1 Input
J4 LO1 Input J3 LO1 Export
Software Setup
Minimum Versions
  • USRP Hardware Driver™ (UHD): 3.10.0.0
  • GNU Radio: 3.7.10
In order to use your TwinRX, you must have the software tools correctly installed and configured on your host computer. A step-by-step guide for doing this is available at the "Building and Installing the USRP Open-Source Toolchain (UHD and GNU Radio) on Linux, OS X and Windows" Application Notes. UHD Release 3.10.0.0 or later is required; it is recommended to use the latest stable version of UHD that is available. The minimum version supported by GNU Radio is 3.7.10.
Test and Verify the Operation of the USRP
The UHD driver includes several example programs, which may serve as test programs or the basis for your application program. These example programs are already included with the UHD driver installation, and the source code can be obtained from the UHD repository on GitHub at: https://github.com/EttusResearch/uhd/tree/master/host/examples Additional information on usage to verify the USRP operating is available at the Verifying the Operation of the USRP Using UHD and GNU Radio Application Note.
Once you have the UHD driver installed, you can quickly verify the operation of your TwinRX by running the rx_ascii_art_dft UHD example program. The rx_ascii_art_dft program is included with the UHD driver and is located in the $install_prefix/lib/uhd/examples folder.
The rx_ascii_art_dft utility is a simple console-based, real-time FFT display tool. It is not graphical in nature, so it can be easily run over an SSH connection within a terminal window, and does not need any graphical capability, such as X Windows, to be installed.
You can run a simple test of the TwinRX device by connecting an antenna to the RX1 port and observing the spectrum of a commercial FM radio station in real-time. Please follow the steps listed below.
1. Attach an antenna to the RX1 antenna port of the TwinRX.
2. At a terminal prompt, run:
   /usr/local/lib/uhd/examples/rx_ascii_art_dft --freq 88.1e6 --rate 1e6 --gain 70 --ref-lvl -30 --subdev "A:0" --ant RX1
  • This step assumes that the TwinRX is installed in daughterboard slot A.
  • To test the RX2 channel, change the antenna flag to RX2, and change the subdev spec to A:1
3. Modify the command-line argument --freq above to specify a tuning frequency for a strong local FM radio station.
4. You should see a real-time FFT display of 1 MHz of spectrum, centered at the specified tuning frequency.
5. Type "Q" or Ctrl-C to stop the program and to return to the Linux command line.
6. You can adjust the size of your terminal window and then re-run the command to enlarge or shrink the FFT display.
7. You can run with the --help option to see a description of all available command-line options.
Once you have installed GNU Radio, you can run the graphical tool uhd_fft to provide a GUI based real time FFT tool. To run uhd_fft, run the command below in a terminal:
   uhd_fft -s 1e6 -g 70 -f 88.1e6 --spec "A:0" -A RX1
  • Modify the command-line argument -f above to specify a tuning frequency for a strong local FM radio station.
Proper Care and Handling
All Ettus Research products are individually tested before shipment. The TwinRX is guaranteed to be functional at the time it is received by the customer. Improper use or handling of the TwinRX can easily cause the device to become non-functional. Listed below are some examples of actions which can prevent damage to the unit:
Never apply more than +10 dBm of power into any RF input.
